bahtiyar57 Posted February 3, 2024 Posted February 3, 2024 I used armbian-config to set up boot from EMMC. Then I run dd if=/dev/zero of=/dev/mmcblk0 bs=1024 count=2048 And re-partitioned my SD Card. Rebooting with or without SD Card not possible. 0 Quote
Gunjan Gupta Posted February 4, 2024 Posted February 4, 2024 is there any output on serial console? 0 Quote
O to the o Posted February 14, 2024 Posted February 14, 2024 Hi I'm running into the same issue, this is the output i get from the serial <\r><\n> U-Boot SPL 2024.01-armbian (Feb 10 2024 - 01:33:08 +0000)<\r><\n> DRAM: 2048 MiB<\r><\n> Trying to boot from MMC2<\r><\n> Card did not respond to voltage select! : -110<\r><\n> spl: mmc init failed with error: -95<\r><\n> SPL: failed to boot from all boot devices<\r><\n> ### ERROR ### Please RESET the board ###<\r><\n> I got no idea what to search for in this case, also somehow my emmc is mmcblk2 instead of the mmcblk1 that it's refered to in every source i found so far 0 Quote
bahtiyar57 Posted April 12, 2024 Author Posted April 12, 2024 I tried it in so many ways. Other images can be started from the emmc without any problems. It would be very nice if any one could help us. 0 Quote
bahtiyar57 Posted April 28, 2024 Author Posted April 28, 2024 Yesterday I had same problems with my on SD Card installed Armbian. It won't boot. After a few failed attempts to boot, it did after all. Surprisingly not from the SD Card. It booted from EMMC, where was a clean Armbian installation flashed. After reboot it was no more possible for me to repeat this. 0 Quote
O to the o Posted May 5, 2024 Posted May 5, 2024 What other images were you trying Bahtiyar ? I'm intending to use the banana Pi for a 3d printer and EMMC booting is the last thing holding me back. 0 Quote
bahtiyar57 Posted May 16, 2024 Author Posted May 16, 2024 Zitat What other images were you trying Bahtiyar ? Armbian-unofficial 24.5.0-trunk Jammy with Linux 6.6.26-current-sunxi 0 Quote
O to the o Posted May 19, 2024 Posted May 19, 2024 Can't find that image anywhere and no matter what i try (even the banana pi supplyed ones) refuse to boot into emmc. When going into the U-Boot shell with a SD-Card plugged in i can get this env => env print arch=arm baudrate=115200 board=sunxi board_name=sunxi boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf} boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_syslinux_conf=extlinux/extlinux.conf boot_targets=fel mmc_auto usb0 pxe dhcp bootcmd=run distro_bootcmd bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci; bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi bootcmd_mmc0=devnum=0; run mmc_boot bootcmd_mmc1=devnum=1; run mmc_boot bootcmd_mmc_auto=if test ${mmc_bootdev} -eq 1; then run bootcmd_mmc1; run bootcmd_mmc0; elif test ${mmc_bootdev} -eq 0; then run bootcmd_mmc0; run bootcmd_mmc1; fi bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi bootcmd_usb0=devnum=0; run usb_boot bootdelay=1 bootm_size=0xa000000 console=ttyS0,115200 cpu=armv7 dfu_alt_info_ram=kernel ram 0x42000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43400000 0x4000000 distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ ethaddr=02:01:7e:b0:bb:78 fdt_addr_r=0x43000000 fdtcontroladdr=bbf5e620 fdtfile=sun8i-a83t-bananapi-m3.dtb fdtoverlay_addr_r=0x43300000 kernel_addr_r=0x42000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} loadaddr=0x42000000 loadsplash= for prefix in ${boot_prefixes}; do if test -e mmc 0 ${prefix}boot.bmp; then load mmc 0 ${splashimage} ${prefix}boot.bmp; bmp d ${splashimage}; fi; done mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi mmc_bootdev=0 partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system}; preboot=usb start pxefile_addr_r=0x43200000 ramdisk_addr_r=0x43400000 scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x43100000 serial#=32c004017eb0bb78 soc=sunxi splashimage=66000000 splashpos=m,m stderr=serial stdin=serial,usbkbd stdout=serial usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3 Environment size: 4905/65532 bytes Also i can access the emmc once booted @Gunjan Gupta Do you have any idea where to go from here or where to find more info on how to maybe get it booting from emmc ? 0 Quote
O to the o Posted May 20, 2024 Posted May 20, 2024 Results of today: I found no image that would let me boot from EMMC without the micro SD, but when i edit the armbianEnv on the SD to point to the UUID of the EMMC partion with installed os it boots from the EMMC. So my conclusion is that i need to build my own U-Boot.bin to get around the poweron issue with the emmc. 0 Quote
O to the o Posted May 25, 2024 Posted May 25, 2024 So far no, but I'm reading up on it and plan to 0 Quote
O to the o Posted May 26, 2024 Posted May 26, 2024 So I figured out how to test uboot.bin's with the fel mode, but so far couldn't build my own uboot for the a83t. Also i dug around in the image and it seems like the banana pi m3 images doesn't have the uboot for the a83t (might be wrong there) 0 Quote
O to the o Posted May 29, 2024 Posted May 29, 2024 Now looking at the DTS for the banana pi M3 (sun8i-a83t-bananapi-m3.dts) turns out the emmc is mmc2 not mmc1. Got no idea what mmc1 could be but it uses the wi-fi's power sequence 0 Quote
going Posted May 29, 2024 Posted May 29, 2024 (edited) 05.05.2024 в 10:36, O to the o сказал: I'm intending to use the banana Pi for a 3d printer and EMMC booting is the last thing holding me back. Starting the OS from the SD card: Password: ____ ____ _ __ __ _____ | __ )| _ \(_) | \/ |___ / | _ \| |_) | | | |\/| | |_ \ | |_) | __/| | | | | |___) | |____/|_| |_| |_| |_|____/ Welcome to Armbian 23.10 Bookworm with Linux 6.4.16 No end-user support: built from trunk & unsupported (bookworm) userspace! System load: 22% Up time: 0 min Memory usage: 5% of 1.96G IP: 192.168.100.101 CPU temp: 34�°C Usage of /: 14% of 7.2G Starting the OS with EMMC: ____ ____ _ __ __ _____ | __ ) __ _ _ __ __ _ _ __ __ _ | _ \(_) | \/ |___ / | _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | | | |\/| | |_ \ | |_) | (_| | | | | (_| | | | | (_| | | __/| | | | | |___) | |____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_| |_| |_| |_|____/ Welcome to ARMBIAN 5.87 user-built Ubuntu 18.04.2 LTS 4.19.43-ipipe-sunxi System load: 1.05 0.27 0.09 Up time: 0 min Memory usage: 6 % of 2012MB IP: 192.168.100.101 Usage of /: 15% of 7.0G I remember that I recorded the image on the SD card using "dd" and the standard procedure at the first start. Then, on my desktop machine, I started "mc" and connected to the device via SSH. I copied the image file to the home directory. Then I wrote it to "/dev/mmcblk2" using the "dd" command. Link to my image Best regards Edited May 29, 2024 by going Add link to image 0 Quote
O to the o Posted May 29, 2024 Posted May 29, 2024 U-Boot SPL 2022.07-armbian (Jan 30 2024 - 11:01:03 +0000) DRAM: 2048 MiB Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Thanks @going, i tried your image but it didn't work for me. Can you explain the copy process a bit more ? I used this command dd if=xxx.img of=/dev/mmcblk2 bs=10M to copy it 0 Quote
going Posted May 29, 2024 Posted May 29, 2024 47 минут назад, O to the o сказал: Can you explain the copy process a bit more ? dd if=/dev/zero of=/dev/mmcblk2 bs=1M count=10; sync dd if=YYY.img of=/dev/mmcblk2 bs=1M; sync On my device, a rather old image is recorded in EMMC. I'll check tomorrow how the new one will work. One more nuance. These sections are completely empty for me: mmcblk2boot0 179:16 0 4M 1 disk mmcblk2boot1 179:24 0 4M 1 disk 0 Quote
going Posted May 30, 2024 Posted May 30, 2024 14 часов назад, O to the o сказал: U-Boot SPL 2022.07-armbian (Jan 30 2024 - 11:01:03 +0000) DRAM: 2048 MiB Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Yes, I confirm. U-boot does not support (not configured during compilation) booting from EMMC. Today I will fix it for Armbian and for my image. Wait a bit. 2 Quote
O to the o Posted May 30, 2024 Posted May 30, 2024 vor 5 Stunden schrieb going: Yes, I confirm. U-boot does not support (not configured during compilation) booting from EMMC. Today I will fix it for Armbian and for my image. Wait a bit. Mind elaborating a bit what needs to be changed about the uboot to make booting from EMMC possible ? I've been poking in the dark for a few days now, learned a bit and really like to know what i'm missing 0 Quote
going Posted May 31, 2024 Posted May 31, 2024 22 часа назад, O to the o сказал: Mind elaborating a bit what needs to be changed about the uboot to make booting from EMMC possible ? I've been poking in the dark for a few days now, learned a bit and really like to know what i'm missing Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices The SPL must supply power for the chip to work. He doesn't seem to know where to go. Unfortunately, I don't remember how I did it in the old u-boot. I have no records left, which means that everything was very simple. But the code has changed and additional settings may be required for the default configuration. We'll have to wait a bit while I test my changes. 0 Quote
O to the o Posted May 31, 2024 Posted May 31, 2024 Thanks, i looked at the scematics doesn't seem like there is a voltage select that is just for the emmc 0 Quote
bahtiyar57 Posted June 3, 2024 Author Posted June 3, 2024 @going it's not a good solution for me to use a pre-build image. Is there an option to make it work with any image? 0 Quote
going Posted June 3, 2024 Posted June 3, 2024 1 час назад, bahtiyar57 сказал: it's not a good solution for me to use a pre-build image. Is there an option to make it work with any image? Hello. Are we talking about starting the OS booting from eMMC? Today I can only give some recommendations in theory. My problem is that the BPI-m3 appeared to me in 2013. I have successfully completed and completed one project on it. But I forgot how I did it. And I didn't keep all the old images. Should I lay out the theoretical foundations? Today I'm trying to figure out the new u-boot code. And make the assembly within the framework of the Armbian assembly system so that the image can be loaded from both the SD card and the eMMC. 0 Quote
going Posted June 3, 2024 Posted June 3, 2024 30.05.2024 в 17:53, O to the o сказал: Mind elaborating a bit what needs to be changed about the uboot to make booting from EMMC possible ? I've been poking in the dark for a few days now, learned a bit and really like to know what i'm missing The whole problem lies in the "configure u-boot correctly" plane. 0 Quote
O to the o Posted June 3, 2024 Posted June 3, 2024 Thanks that's what my conclusion also was, I'll search my old backup drives for an old image that still could boot from emmc. Me poking at the uboot config won't do much good. If you need someone to test something ask 0 Quote
Peter Allen Posted June 13, 2024 Posted June 13, 2024 Have you made any progress with this? I've got a pretty much identical issue on a custom Allwinner S3 based board. Uboot can see mmc2, but SPL can't initialise it (same errors as you posted). I've tried a lot of different Uboot config options but made no progress... 0 Quote
going Posted August 19, 2024 Posted August 19, 2024 14.06.2024 в 01:45, Peter Allen сказал: I've got a pretty much identical issue on a custom Allwinner S3 based board. Uboot can see mmc2, but SPL can't initialise it (same errors as you posted). I've tried a lot of different Uboot config options but made no progress... At the moment, I still don't understand the reason. Please publish the name of the eMMC chip, a piece of the schematic diagram of its connection. I will deal with this further. 0 Quote
Solution going Posted September 15, 2024 Solution Posted September 15, 2024 We will be able to boot the OS from eMMC on the bananapi-m3 board after this pull request is accepted. PR (#7252) Use armbian-install. With respect. 0 Quote
