kolkolkol Posted January 26, 2017 Posted January 26, 2017 (edited) Hi all, first post here. Im Ivan, its nice to meet. So i finally came to install Debian Jessie stable, and it's good to be back.My installation is brand new and i have not a wired connection avalaible, so ill have to make things works nowired.As the title say, my card is an Intel i217-V, which in the beginning was not recognized at all by the OS.That was normal and expected, because in the installation phase Debian told that i was missing firmware files named rtlwifi/rtl8821aefw.bin.After a few search i came to download from windows (im in a dual boot system) the following packages: firmware-iwlwifi_0.43_all.deb and firmware-realtek_0.43_all.deb.I also installed this driver, that seems to fit in for my net card: https://downloadcenter.intel.com/download/15817/Intel-Network-Adapter-Driver-for-PCI-E-Gigabit-Network-Connections-under-Linux-That made my OS "graphically"recognize the net card and made me able to see avalaible connections trough it. And that, for instance, it is not completely true because at the present day connections appear just for a while, like 3 or 4 minutes after the boot, then totally disappear and i have to reboot to see them again.I'm able to see my home wifi connection among others, but can't connect to it.Heres my ifconfig root@kkk:/home/kolkolkol# ifconfig eth0 Link encap:Ethernet HWaddr 1c:87:2c:cc:97:f7 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 Interrupt:20 Memory:f7200000-f7220000 eth0:avahi Link encap:Ethernet HWaddr 1c:87:2c:cc:97:f7 inet addr:169.254.11.115 Bcast:169.254.255.255 Mask:255.255.0.0 UP BROADCAST MULTICAST MTU:1500 Metric:1 Interrupt:20 Memory:f7200000-f7220000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:31 errors:0 dropped:0 overruns:0 frame:0 TX packets:31 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:3317 (3.2 KiB) TX bytes:3317 (3.2 KiB) wlan0 Link encap:Ethernet HWaddr dc:85:de:ef:dd:31 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 iwconfig root@kkk:/home/kolkolkol# sudo iwconfig lo no wireless extensions. wlan0 IEEE 802.11abgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr=2347 B Fragment thr:off Encryption key:off Power Management:off eth0 no wireless extensions. As i understood there isnt any statement on this about my netcard. Like eth1, 2, etcetera. Am i right?interfaces /etc/network/interfaces/ /etc/network/interfaces/ # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # The loopback network interface allow-hotplug eth0 iface eth0 inet dhcp and lspci -v 00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, fast devsel, latency 0 Capabilities: [e0] Vendor Specific Information: Len=0c <?> Kernel driver in use: hsw_uncore 00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 0000e000-0000efff Memory behind bridge: f6000000-f70fffff Prefetchable memory behind bridge: 00000000e8000000-00000000f1ffffff Capabilities: [88] Subsystem: ASUSTeK Computer Inc. Device 8534 Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [a0] Express Root Port (Slot+), MSI 00 Capabilities: [100] Virtual Channel Capabilities: [140] Root Complex Link Kernel driver in use: pcieport 00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05) (prog-if 30 [XHCI]) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, medium devsel, latency 0, IRQ 42 Memory at f7220000 (64-bit, non-prefetchable) [size=64K] Capabilities: [70] Power Management version 2 Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+ Kernel driver in use: xhci_hcd 00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, fast devsel, latency 0, IRQ 44 Memory at f723b000 (64-bit, non-prefetchable) [size=16] Capabilities: [50] Power Management version 3 Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+ Kernel driver in use: mei_me 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 05) Subsystem: ASUSTeK Computer Inc. Device 859f Flags: bus master, fast devsel, latency 0, IRQ 41 Memory at f7200000 (32-bit, non-prefetchable) [size=128K] Memory at f7239000 (32-bit, non-prefetchable) [size=4K] I/O ports at f040 [size=32] Capabilities: [c8] Power Management version 2 Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [e0] PCI Advanced Features Kernel driver in use: e1000e 00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05) (prog-if 20 [EHCI]) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, medium devsel, latency 0, IRQ 16 Memory at f7238000 (32-bit, non-prefetchable) [size=1K] Capabilities: [50] Power Management version 2 Capabilities: [58] Debug port: BAR=1 offset=00a0 Capabilities: [98] PCI Advanced Features Kernel driver in use: ehci-pci 00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05) Subsystem: ASUSTeK Computer Inc. Device 8692 Flags: bus master, fast devsel, latency 0, IRQ 45 Memory at f7230000 (64-bit, non-prefetchable) [size=16K] Capabilities: [50] Power Management version 2 Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [100] Virtual Channel Kernel driver in use: snd_hda_intel 00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=02, subordinate=02, sec-latency=0 I/O behind bridge: 00002000-00002fff Memory behind bridge: e0000000-e01fffff Prefetchable memory behind bridge: 00000000e0200000-00000000e03fffff Capabilities: [40] Express Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 8534 Capabilities: [a0] Power Management version 3 Kernel driver in use: pcieport 00:1c.1 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #2 (rev d5) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=03, subordinate=03, sec-latency=0 I/O behind bridge: 0000d000-0000dfff Memory behind bridge: f7100000-f71fffff Capabilities: [40] Express Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 8534 Capabilities: [a0] Power Management version 3 Kernel driver in use: pcieport 00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05) (prog-if 20 [EHCI]) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, medium devsel, latency 0, IRQ 23 Memory at f7237000 (32-bit, non-prefetchable) [size=1K] Capabilities: [50] Power Management version 2 Capabilities: [58] Debug port: BAR=1 offset=00a0 Capabilities: [98] PCI Advanced Features Kernel driver in use: ehci-pci 00:1f.0 ISA bridge: Intel Corporation C220 Series Chipset Family H81 Express LPC Controller (rev 05) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, medium devsel, latency 0 Capabilities: [e0] Vendor Specific Information: Len=0c <?> Kernel driver in use: lpc_ich 00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05) (prog-if 01 [AHCI 1.0]) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 43 I/O ports at f090 [size=8] I/O ports at f080 [size=4] I/O ports at f070 [size=8] I/O ports at f060 [size=4] I/O ports at f020 [size=32] Memory at f7236000 (32-bit, non-prefetchable) [size=2K] Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [70] Power Management version 3 Capabilities: [a8] SATA HBA v1.0 Kernel driver in use: ahci 00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05) Subsystem: ASUSTeK Computer Inc. Device 8534 Flags: medium devsel, IRQ 18 Memory at f7235000 (64-bit, non-prefetchable) [size=256] I/O ports at f000 [size=32] 01:00.0 VGA compatible controller: NVIDIA Corporation Device 1289 (rev a1) (prog-if 00 [VGA controller]) Subsystem: ASUSTeK Computer Inc. Device 866f Flags: fast devsel, IRQ 16 Memory at f6000000 (32-bit, non-prefetchable) [size=16M] Memory at e8000000 (64-bit, prefetchable) [size=128M] Memory at f0000000 (64-bit, prefetchable) [size=32M] I/O ports at e000 [size=128] Expansion ROM at f7000000 [disabled] [size=512K] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [78] Express Legacy Endpoint, MSI 00 Capabilities: [100] Virtual Channel Capabilities: [128] Power Budgeting <?> Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?> 01:00.1 Audio device: NVIDIA Corporation Device 0e0f (rev a1) Subsystem: ASUSTeK Computer Inc. Device 866f Flags: bus master, fast devsel, latency 0, IRQ 17 Memory at f7080000 (32-bit, non-prefetchable) [size=16K] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [78] Express Endpoint, MSI 00 Kernel driver in use: snd_hda_intel 03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821AE 802.11ac PCIe Wireless Network Adapter Subsystem: AzureWave Device 2161 Flags: bus master, fast devsel, latency 0, IRQ 17 I/O ports at d000 [size=256] Memory at f7100000 (64-bit, non-prefetchable) [size=16K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Device Serial Number 00-e0-4c-ff-fe-87-2b-01 Capabilities: [150] Latency Tolerance Reporting Capabilities: [158] L1 PM Substates Kernel driver in use: rtl8821ae Im going now to download and install wpasupplicant, but i think problem should be something else, that i can't get (for now); hope to solve this alone and to post the solution soon, but...with a little help from my friends could go faster!Thank you for your support and your commitment here,Ivan Edited January 26, 2017 by zador.blood.stained To the "Free" section for now
zador.blood.stained Posted January 26, 2017 Posted January 26, 2017 This doesn't look like Armbian or anything supported by Armbian? What board and OS image is this?
