John151235 Posted February 11 Share Posted February 11 I am trying to stream multiple USB cameras in Orange pi 5+, but I am getting the error: ffmpeg -f v4l2 -input_format mjpeg -video_size 640x480 -i /dev/video3 -c:v copy output2.mp4 # One process successfully started, but calling this a second time doesn't work: ... [video4linux2,v4l2 @ 0xaaab1ddcdbc0] ioctl(VIDIOC_STREAMON): No space left on device /dev/video3: No space left on device dmesg displays this: [696321.331182] usb 5-1.3.2: Not enough bandwidth for new device state. [696321.331189] usb 5-1.3.2: Not enough bandwidth for altsetting 7 I initially assumed that this was a hardware issue, but the device is able to successfully stream camera's maximum resolution 1920x1080 in raw video format, but fails to stream 2 cameras at 640x480 in MJPEG resolution. It is clear that number of bits that the bus can transfer per second is not the cause of the issue. Does anyone know what the issue may be? 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted February 18 Share Posted February 18 This is an artificial limitation on the linux uvc driver, which handles webcams Try connecting the 2nd webcam in a port in a different USB root inside your orange pi. Or try following this guide https://www.thegoodpenguin.co.uk/blog/multiple-uvc-cameras-on-linux/ 0 Quote Link to comment Share on other sites More sharing options...
