Reproach4475 Posted February 11 Share Posted February 11 (edited) I've been looking for ways to fix this all afternoon but I'm giving up. I flash the latest version of the image with BalenaEtcher, it takes about 10 min approximately to boot. I log in I do the setup, and the partition / is only 2GB, I reboot the red light stops flashing and the board stays with a steady green light does not respond to ping. I pull the cable and start in armbian the partition is still the same at 2GB, I check the resize2fs service and it does not start. I don't know what I'm doing wrong, the PSU is working properly, I did a health test to the SD is also OK. I don't know what else to check. Edited February 11 by Reproach4475 0 Quote Link to comment Share on other sites More sharing options...
