dvdspeler Posted February 12, 2024 Posted February 12, 2024 (edited) # PROBLEM: Recent bananapi m1 images (and other A20 boards?) have no kernel headers, and armbian-config is not working so no hardware support. # SOLUTION: Armbian_23.02.2_Bananapi_jammy_current_5.15.93.img.xz Take this image and install the headers manually - or update to recent ones from here (not all work). NOTE: Armbian_23.02.2_Bananapi_jammy_current_5.15.93_minimal.img.xz While is the same build, cannot unfreeze kernel changes in armbian-config gui Flash SD and drop the 3 kernel packages in /root/ After first boot run $ apt upgrade && apt upgrade --fix-missing Unfreeze kernel with $ armbian-config -> system -> unfreeze (should accept) Install kernel packages: $ dpkg -i <package-dtb.deb> <package-image.deb> <package-header.deb> reboot & freeze kernel again compare build scripts current vs minimal - and merge upstream? I am noob Please show the way. Files pack: https://www.dropbox.com/scl/fo/0bdengzqkn5x798ddxvp7/h?rlkey=i6kilnhhr6xzxgkmipfqy19pr&dl=0 credits: Note to self: I should learn how to compile and build images. Edited February 12, 2024 by dvdspeler 0 Quote
