luca219 Posted October 20, 2015 Posted October 20, 2015 hi all, if someone need, I adapted for nagios the script to monitor battery cubietruck. The script is pnp4nagios friendly. #!/bin/bash ###################################################################################### # # Battery info # /usr/sbin/i2cset -y -f 0 0x34 0x82 0xC3 # read power OPERATING MODE register @01h POWER_OP_MODE=$(/usr/sbin/i2cget -y -f 0 0x34 0x01) BAT_EXIST=$(($(($POWER_OP_MODE&0x20))/32)) # divide by 32 is like shifting rigth 5 times CHARG_IND=$(($(($POWER_OP_MODE&0x40))/64)) # divide by 64 is like shifting rigth 6 times ######################################################################################## #read battery voltage 79h, 78h 0 mV -> 000h, 1.1 mV/bit FFFh -> 4.5045 V BAT_VOLT_LSB=$(/usr/sbin/i2cget -y -f 0 0x34 0x79) BAT_VOLT_MSB=$(/usr/sbin/i2cget -y -f 0 0x34 0x78) BAT_BIN=$(( $(($BAT_VOLT_MSB << 4)) | $(($(($BAT_VOLT_LSB & 0xF0)) >> 4)) )) BAT_VOLT=$(echo "($BAT_BIN*1.1)"|bc) # store maximum battery voltage to compare to if [ -f "/etc/default/battery" ]; then source "/etc/default/battery" else echo "MAX=$BAT_VOLT" > /etc/default/battery echo "MIN=3484" >> /etc/default/battery fi # integer is enough, cut down the decimals MAX=${MAX%.*} BAT_VOLT=${BAT_VOLT%.*} # mainline kernel shows battery existence even if not exists. this is walkaround if [ "$BAT_VOLT" -ge "3200" ]; then # if we have new max value, alter defaults if [ "$BAT_VOLT" -gt "$MAX" ]; then MAX=$BAT_VOLT sed -e 's/MAX=.*/MAX='$BAT_VOLT'/g' -i /etc/default/battery fi # if we have new min value, alter defaults if [ "$BAT_VOLT" -lt "$MIN" ]; then MIN=$BAT_VOLT sed -e 's/MIN=.*/MIN='$BAT_VOLT'/g' -i /etc/default/battery fi # calculate percentage percent=$(echo "($BAT_VOLT-$MIN)*100/($MAX-$MIN)"|bc) fi # define output format output="Load : $percent% | Load_Batt=$percent;80;35;3.4;4.2;" # if load% in range 80-10 ok if [ "$percent" -ge 80 -a "$percent" -le 100 ]; then echo "OK- $output" exit 0 # if load % in range 40-79 warning elif [ "$percent" -ge 40 -a "$percent" -le 79 ]; then echo "WARNING - $output" exit 1 # if load % in range 0-39 critical elif [ "$percent" -ge 0 -a "$percent" -le 39 ]; then echo "CRITICAL - $output" exit 2 # if check non riceve data else echo "UNKNOW" exit 3 fi if run script for non admin user need add permission to /usr/sbin/iscget ex: chmod 777 /usr/sbin/iscget and change default permission for /dev/i2c-0 ex: sudo nano /lib/udev/rules.d/60-i2c-tools.rules KERNEL=="i2c-0" , GROUP="i2c", MODE="0660" to KERNEL=="i2c-0" , GROUP="i2c", MODE="0666" and reboot 3
