hi there, i was wondering if there a away to compile mosquitto 1.4. successfully  the current version is 1.3.3 ( or something like that)
when I try to compile it it seams to compile correctly and it seams to install correctly.  the broker portion works fine but the client side does not.  when you try to publish or subscribe it complains a file is missing.
I needed it for websockets
to compile id did this
  1. wget https://github.com/warmcat/libwebsockets/archive/v1.3-chrome37-firefox30.tar.gz
  2. tar xvzf v1.3-chrome37-firefox30.tar.gz
  3. cd v1.3-chrome37-firefox30
  4. mkdir build
  5. cd build
  6. cmake ..
  7. make
  8. sudo make install
  9. sudo ln -s /usr/local/lib/libwebsockets.so.4.0.0 /usr/lib/libwebsockets.so.4.0.0
  1. wget http://mosquitto.org/files/source/mosquitto-1.4.tar.gz
  2. tar xvzf mosquitto-1.4.tar.gz
  3. cd mosquitto-1.4
  4. nano config.mk  --- change it to read, "WITH_WEBSOCKETS:= yes".
  5. make
  6. sudo make install
the broker seams to work  but not the clients it complains about /usr/lib/libmosquitto.so.1: version `MOSQ_1.4' not found
does anyone have an idea where I might be going wrong
Perhaps because you built your websockets library against older libmosquitto. I would try to purge websockets lib and mosquitto and start again with building mosquitto first. This way library will link to new libmosquitto.
