ua3nbw Posted February 14, 2017 Posted February 14, 2017 Hi, How i can find information for set the fex file, kernel, etc. etc. for use the spi in userspace? root@orangepipc:~# uname -aLinux orangepipc 4.10.0-sun8i #5 SMP Tue Feb 14 02:53:01 CET 2017 armv7l armv7l armv7l GNU/Linux root@orangepipc:~# lsmod Module Size Used by sun4i_codec 28243 3 rt2800usb 16226 0 sun8i_codec_analog 13766 1 rt2800lib 57122 1 rt2800usb snd_soc_core 115473 2 sun4i_codec,sun8i_codec_analog snd_pcm_dmaengine 4221 1 snd_soc_core rt2x00usb 9245 1 rt2800usb rt2x00lib 34437 3 rt2800lib,rt2800usb,rt2x00usb mac80211 324953 3 rt2800lib,rt2x00lib,rt2x00usb snd_pcm 70145 2 snd_pcm_dmaengine,snd_soc_core input_leds 2724 0 ir_lirc_codec 4630 0 evdev 9979 0 cfg80211 192770 2 rt2x00lib,mac80211 lirc_dev 8351 1 ir_lirc_codec rfkill 10928 3 cfg80211 sunxi_cir 3825 0 sun8i_ths 3134 0 cpufreq_dt 3522 0 thermal_sys 43232 2 cpufreq_dt,sun8i_ths uio_pdrv_genirq 3354 0 uio 8012 1 uio_pdrv_genirq gpio_keys 8517 0 spidev 6382 0 uas 11678 0 orangepipc.fex [spi0] spi_used = 1 spi_cs_bitmap = 1 spi_mosi = port:PC00<3><default><default><default> spi_miso = port:PC01<3><default><default><default> spi_sclk = port:PC02<3><default><default><default> spi_cs0 = port:PC03<3><1><default><default> [spi1] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA13<2><1><default><default> spi_sclk = port:PA14<2><default><default><default> spi_mosi = port:PA15<2><default><default><default> spi_miso = port:PA16<2><default><default><default> [spi_devices] spi_dev_num = 1 [spi_board0] modalias = "spidev" max_speed_hz = 33000000 bus_num = 0 chip_select = 0 mode = 0 full_duplex = 1 manual_cs = 0 root@orangepipc:~# ls /dev/spi*ls: cannot access '/dev/spi*': No such file or directory i don't see in /dev any spidevx.0 device armbianmonitor -u ------------- http://sprunge.us/OCaP
vlad59 Posted February 14, 2017 Posted February 14, 2017 You're using mainline kernel (4.10) so the fex is not used anymore. You'll have to use some device tree overlays (search the forum for that)
