for my project I need to stream a video from IP camera and add some text from sensors into the final video.
From armbian console I have installed ffmpeg (apt-get install ffmpeg)..
The program works except the text is not included into streamed video:
Example:
ffserver.conf
HTTPPort 8090
HTTPBindAddress 0.0.0.0
MaxHTTPConnections 2000
MaxClients 1000
MaxBandwidth 10000
CustomLog -
<Feed monitoring1.ffm>
File /tmp/monitoring1.ffm
FileMaxSize 50M
ACL allow 127.0.0.1
ACL allow 192.168.0.0 192.168.255.255
</Feed>
<Stream monitoring1.mjpg>
Format mpjpeg
VideoCodec mjpeg
VideoFrameRate 22
VideoBufferSize 80
VideoSize 720x264
NoAudio
</Stream>
# Redirect index.html to the appropriate site
<Redirect index.html>
URL http://www.ffmpeg.org/
</Redirect>
Then I start a simple example as:
ffmpeg -i rtsp://mpv.cdn3.bigCDN.com:554/bigCDN/definst/mp4:bigbuckbunnyiphone_400.mp4 -vf drawtext="fontfile=/home/projekt/StreamTest/DejaVuSans.ttf: \
text='TEST TEST': fontcolor=white: fontsize=36: box=1: boxcolor=black@0.5: \
boxborderw=5: x=(w-text_w)/2: y=(h-text_h)/2" -codec:a copy http://localhost:8090/monitoring1.ffm
In Armbian console I get:
root@orangepipc:/home/projekt/StreamTest# ./test.sh
ffmpeg version 3.2.2-1~bpo8+1 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.9.2 (Debian 4.9.2-10)
  configuration: --prefix=/usr --extra-version='1~bpo8+1' --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --disable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-libopencv --enable-frei0r --enable-libx264 --enable-chromaprint --enable-shared
  libavutil      55. 34.100 / 55. 34.100
  libavcodec     57. 64.101 / 57. 64.101
  libavformat    57. 56.100 / 57. 56.100
  libavdevice    57.  1.100 / 57.  1.100
  libavfilter     6. 65.100 /  6. 65.100
  libavresample   3.  1.  0 /  3.  1.  0
  libswscale      4.  2.100 /  4.  2.100
  libswresample   2.  3.100 /  2.  3.100
  libpostproc    54.  1.100 / 54.  1.100
[rtsp @ 0xb7a0a280] UDP timeout, retrying with TCP
Input #0, rtsp, from 'rtsp://mpv.cdn3.bigCDN.com:554/bigCDN/definst/mp4:bigbuckbunnyiphone_400.mp4':
  Metadata:
    title           : http/9aaa4066-cs.mi-cdn.io/streaming/streams/flash/bigbuckbunnyiphone_400.mp4
  Duration: 00:09:56.46, start: 0.000000, bitrate: N/A
    Stream #0:0: Audio: aac (LC), 48000 Hz, stereo, fltp
    Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 320x180, 24 tbr, 90k tbn, 180k tbc
[tcp @ 0xb7a11ca0] Connection to tcp://localhost:8090 failed (Connection refused), trying next address
    Last message repeated 1 times
[swscaler @ 0xb7a61d10] deprecated pixel format used, make sure you did set range correctly
Output #0, ffm, to 'http://localhost:8090/monitoring1.ffm':
  Metadata:
    creation_time   : now
    encoder         : Lavf57.56.100
    Stream #0:0: Video: mjpeg, yuvj420p(pc), 720x264, q=2-31, 64 kb/s, 24 fps, 1000k tbn, 22 tbc
    Metadata:
      encoder         : Lavc57.64.101 mjpeg
    Side data:
      cpb: bitrate max/min/avg: 128000/0/64000 buffer size: 655360 vbv_delay: -1
Stream mapping:
  Stream #0:1 -> #0:0 (h264 (native) -> mjpeg (native))
Press [q] to stop, [?] for help
[mjpeg @ 0xb7b0f760] rc buffer underflowkB time=00:00:00.77 bitrate= 720.9kbits/s dup=0 drop=1 speed=1.51x
    Last message repeated 8 times
[mjpeg @ 0xb7b0f760] rc buffer underflowkB time=00:00:01.27 bitrate= 720.9kbits/s dup=0 drop=2 speed=1.24x
    Last message repeated 6 times
Past duration 0.719322 too large
Past duration 0.795326 too large
Past duration 0.893318 too large
[mjpeg @ 0xb7b0f760] rc buffer underflowkB time=00:00:01.77 bitrate= 739.4kbits/s dup=0 drop=3 speed=1.15x
[mjpeg @ 0xb7b0f760] rc buffer underflowkB time=00:00:02.18 bitrate= 750.9kbits/s dup=0 drop=3 speed=1.06x
    Last message repeated 3 times
frame=   53 fps= 23 q=31.4 Lsize=     224kB time=00:00:02.36 bitrate= 776.3kbits/s dup=0 drop=4 speed=1.04x
video:217kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 3.163595%
Exiting normally, received signal 2.
This is the result of "streamed" video but without embedded text 'TEST TEST'
Does anyone know what could be wrong? or how to get latest version of Ffmpeg?
