Protx Posted March 19, 2024 Posted March 19, 2024 (edited) Hi. I testing out different images for my DIY NAS project. My plan is to use the Orangepi3b board with armbian bookworm and OMV. I have built images from armbian github, (main,trunk) the edge 6.7.10 kernel is working great. But I do get some Iperf3 retries when sending from Opi3b. From Opi3b 60-70MB/s To Opi3b 110MB/s. With Orangepi own bookworm image I have 110/110 and no retries. The same with Joshua Riek's Ubuntu server image, no retries and 110/110. Orangepi3b armbian with 6.7.10 kernel orangepi@orangepi3b:~$ iperf3 -c 192.168.10.197 -f M Connecting to host 192.168.10.197, port 5201 [ 5] local 192.168.10.155 port 56514 connected to 192.168.10.197 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 74.5 MBytes 74.5 MBytes/sec 217 19.8 KBytes [ 5] 1.00-2.00 sec 75.9 MBytes 75.9 MBytes/sec 218 11.3 KBytes [ 5] 2.00-3.00 sec 79.1 MBytes 79.1 MBytes/sec 200 25.5 KBytes [ 5] 3.00-4.00 sec 73.3 MBytes 73.3 MBytes/sec 225 29.7 KBytes [ 5] 4.00-5.00 sec 79.1 MBytes 79.1 MBytes/sec 210 33.9 KBytes [ 5] 5.00-6.00 sec 77.8 MBytes 77.8 MBytes/sec 211 86.3 KBytes [ 5] 6.00-7.00 sec 77.4 MBytes 77.4 MBytes/sec 202 36.8 KBytes [ 5] 7.00-8.00 sec 76.1 MBytes 76.1 MBytes/sec 207 73.5 KBytes [ 5] 8.00-9.00 sec 75.0 MBytes 75.0 MBytes/sec 222 12.7 KBytes [ 5] 9.00-10.00 sec 73.3 MBytes 73.3 MBytes/sec 239 11.3 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 761 MBytes 76.1 MBytes/sec 2151 sender [ 5] 0.00-10.04 sec 760 MBytes 75.7 MBytes/sec receiver Orangepi3b Ubuntu with 6.1 kernel ubuntu@ubuntu:~$ iperf3 -R -c 192.168.10.197 -f M Connecting to host 192.168.10.197, port 5201 Reverse mode, remote host 192.168.10.197 is sending [ 5] local 192.168.10.154 port 42888 connected to 192.168.10.197 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 112 MBytes 112 MBytes/sec [ 5] 1.00-2.00 sec 112 MBytes 112 MBytes/sec [ 5] 2.00-3.00 sec 112 MBytes 112 MBytes/sec [ 5] 3.00-4.00 sec 112 MBytes 112 MBytes/sec [ 5] 4.00-5.00 sec 112 MBytes 112 MBytes/sec [ 5] 5.00-6.00 sec 112 MBytes 112 MBytes/sec [ 5] 6.00-7.00 sec 112 MBytes 112 MBytes/sec [ 5] 7.00-8.00 sec 112 MBytes 112 MBytes/sec [ 5] 8.00-9.00 sec 112 MBytes 112 MBytes/sec [ 5] 9.00-10.00 sec 112 MBytes 112 MBytes/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.04 sec 1.10 GBytes 112 MBytes/sec 1 sender [ 5] 0.00-10.00 sec 1.10 GBytes 112 MBytes/sec receiver So to see if the vendor kernel was different I built with the new 6.1.43-vendor-rk35xx kernel, but It will not boot. build command: ./compile.sh build BOARD=orangepi3b BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm J=4 It seems to be something with power to the NPU. ? "rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6" uart log attachment kernelpanic.log Edited March 19, 2024 by Protx To long log file 0 Quote
Solution Protx Posted March 30, 2024 Author Solution Posted March 30, 2024 (edited) I now have the Armbian-unofficial_24.5.0-trunk_Orangepi3b_bookworm_vendor_6.1.43_minimal image booting on my orangpi3b. This is an unsupported board, and the images is built from trunk and bleeding edge, so I guess it is expected to have some issues. Anyway I post my findings in case other have the same problem. Iper3 works without any retries. So next is to install OMV7 and see the file transfer speed. orangepi@orangepi3b:~$ iperf3 -c 192.168.10.10 -f M Connecting to host 192.168.10.10, port 5201 [ 5] local 192.168.10.227 port 41766 connected to 192.168.10.10 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 114 MBytes 114 MBytes/sec 0 407 KBytes [ 5] 1.00-2.00 sec 112 MBytes 112 MBytes/sec 0 407 KBytes [ 5] 2.00-3.00 sec 113 MBytes 113 MBytes/sec 0 428 KBytes [ 5] 3.00-4.00 sec 112 MBytes 112 MBytes/sec 0 428 KBytes [ 5] 4.00-5.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 5.00-6.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 6.00-7.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 7.00-8.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 8.00-9.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 9.00-10.00 sec 113 MBytes 113 MBytes/sec 0 451 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 112 MBytes/sec 0 sender [ 5] 0.00-10.04 sec 1.10 GBytes 112 MBytes/sec receiver iperf Done. I did not know that the bootloader/u-boot on the SPI and EMMC could have impact on booting of SD card, because all images with edge kernel booted just fine from SD card. I have an EMMC with armbian-bookworm-edge-minimal installed, and have flashed the SPI with the u-boot version installed on the EMMC. Error when trying to boot a vendor image from SD card: [ 9.413438] rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6 [ 9.413543] Kernel panic - not syncing: panic_on_set_idle set ... Then I tried other images, armbian with legacy kernel and ubuntu24.04beta-6.1 kernel. Both with the same error. I then flashed the ubuntu's u-boot on the SPI and removed the EMMC. Then the both images booted. But the armbian-bookworm-vendor-mininal still would not boot. But this time it stopped with another error: [ 23.575850] mtty_probe init device addr: 0x000000004f52d231 [ 23.576178] -->rfkill_bluetooth_init [ 23.576456] <--rfkill_bluetooth_init [ 23.577060] sysfs: cannot create duplicate filename '/devices/virtual/tty/ttyBT0' [ 23.577107] CPU: 1 PID: 381 Comm: systemd-modules Not tainted 6.1.43-vendor-rk35xx #1 [ 23.577127] Hardware name: Rockchip RK3566 OPi 3B (DT) [ 23.577141] Call trace: [ 23.577153] dump_backtrace+0xe4/0x108 Next I erased the SPI, and with no EMMC the only bootloader on the SBC was on the SD card. Then the armbian-bookworm-vendor-mininal image stopped with the first kernel panic again: [ 9.413438] rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6 [ 9.413543] Kernel panic - not syncing: panic_on_set_idle set ... So I made changes and reverted to an older version of uboot: BOOTBRANCH="commit:63073b4af636146d26a7f0f258610eed060c8f34" # specific commit, from "branch:rk3568-2023.10" BOOTDIR="u-boot-${BOARD}" # do not share u-boot directory BOOTPATCHDIR="v2023.10-orangepi3b" # empty, patches are already in Kwiboo's branch:rk3568-2023.10 revert-u-boot-orangepi3b.patch Again booting from SD card I got the "duplicate filename" bluetooth error again. So after scratching my head and poking around I noticed that not all the UW5622 patches was applied?: # Apply patches that adjust the driver only for rockchip platforms if [[ "$LINUXFAMILY" == rockchip* ]]; then if linux-version compare "${version}" le 6.1; then process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-pre-6.1.patch" else process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch" fi fi Since the vendor kernel is defined as "$LINUXFAMILY" == rk35xx ? this part of the patch does not get applied. And since the vendor kernel is 6.1.43, it should use the post version of the patch?, aka the "le" won't work.? I changed the script to: # Apply patches that adjust the driver only for rockchip platforms if [[ "$LINUXFAMILY" == rockchip* || "$LINUXFAMILY" == "rk35xx" ]]; then if linux-version compare "${version}" ge 6.1; then process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch" else process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-pre-6.1.patch" fi uw5622-fix-adjust-for-rockchip-post-6.1.patch Compiled, now it boots from SD and seems to work just fine. Edited March 31, 2024 by Protx 1 Quote
darcyg Posted April 18, 2024 Posted April 18, 2024 hi Protx: Hello, I have just started learning the compilation of Armbian. I am also using the OrangePI3b with the RK3566. I need to study the startup of rknpu in version 6.1.43. I downloaded the latest repository from https://github.com/armbian/build, specifically the main branch. I compiled it according to your compilation configuration. There was an error message upon booting. ** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with script Boot script loaded from mmc 1:1 155 bytes read in 3 ms (49.8 KiB/s) 8598033 bytes read in 724 ms (11.3 MiB/s) 37388800 bytes read in 3133 ms (11.4 MiB/s) 167999 bytes read in 47 ms (3.4 MiB/s) Working FDT set to a100000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=4660000 ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8597969 Bytes = 8.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000 Booting using the fdt blob at 0xa100000 Working FDT set to a100000 Loading Ramdisk to ec68e000, end ecec11d1 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 00000000ec5fc000, end 00000000ec68dfff ... OK Working FDT set to ec5fc000 Starting kernel ... [ 14.607208] Internal error: Oops: 0000000096000044 [#1] SMP [ 14.607281] pwm-backlight backlight: Looking up power-supply from device tree [ 14.607780] Modules linked in: [ 14.607848] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 14.608469] sprdbt_tty(+) [ 14.608536] pwm-backlight backlight: supply power not found, using dummy regulator [ 14.608569] fuse dm_mod ip_tables ipv6 panel_simple pwm_bl [ 14.611186] CPU: 1 PID: 312 Comm: systemd-modules Tainted: G W 6.1.43-vendor-rk35xx #1 [ 14.612092] Hardware name: Rockchip RK3566 OPi 3B (DT) [ 14.612601] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 14.613282] pc : tty_unregister_driver+0x44/0x78 [ 14.613752] lr : tty_unregister_driver+0x40/0x78 [ 14.614212] sp : ffff80000d02b7c0 [ 14.614544] x29: ffff80000d02b7c0 x28: ffff80000a10f0c8 x27: 0000000000000000 [ 14.615242] x26: 0000000000000000 x25: ffff80000a23f000 x24: ffff0000092f8400 [ 14.615937] x23: ffff80000122d000 x22: ffff80000122e178 x21: 00000000ffffffef [ 14.616632] x20: ffff80000a2272e0 x19: ffff000008c7fb00 x18: 0000000000000000 [ 14.617328] x17: 7420797274207427 x16: 6e6f64202c545349 x15: 5845452d20687469 [ 14.618028] x14: 7720305442797474 x13: 2e79726f74636572 x12: 696420656d617320 [ 14.618724] x11: 656874206e692065 x10: 6d616e20656d6173 x9 : ffff80000915ee50 [ 14.619420] x8 : 696166206c616e72 x7 : 65746e695f646461 x6 : 0000000000000000 [ 14.620115] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000 [ 14.624209] x2 : ffff000001731c80 x1 : dead000000000100 x0 : dead000000000122 [ 14.628287] Call trace: [ 14.631921] tty_unregister_driver+0x44/0x78 [ 14.635732] mtty_probe+0x1e8/0x2b0 [sprdbt_tty] [ 14.639572] platform_probe+0x70/0xc0 [ 14.643282] really_probe+0x1cc/0x390 [ 14.646981] __driver_probe_device+0x140/0x158 [ 14.650736] driver_probe_device+0x48/0xd0 [ 14.654452] __device_attach_driver+0xd8/0x128 [ 14.658174] bus_for_each_drv+0xa0/0xc8 [ 14.661870] __device_attach+0xf8/0x180 [ 14.665557] device_initial_probe+0x1c/0x28 [ 14.669266] bus_probe_device+0x38/0x9c [ 14.672951] device_add+0x550/0x688 [ 14.676590] platform_device_add+0xec/0x224 [ 14.680286] mtty_pdev_init+0x50/0x1000 [sprdbt_tty] [ 14.684061] do_one_initcall+0x94/0x1e4 [ 14.687709] do_init_module+0x58/0x1e0 [ 14.691329] load_module+0x1818/0x18e0 [ 14.694906] __do_sys_finit_module+0xf8/0x118 [ 14.698524] __arm64_sys_finit_module+0x24/0x30 [ 14.702132] invoke_syscall+0x8c/0x128 [ 14.705606] el0_svc_common.constprop.0+0xd8/0x128 [ 14.709161] do_el0_svc+0xac/0xbc [ 14.712551] el0_svc+0x2c/0x54 [ 14.715888] el0t_64_sync_handler+0xac/0x13c [ 14.719319] el0t_64_sync+0x19c/0x1a0 [ 14.722684] [ 14.722684] PC: 0xffff80000875f79c: [ 14.723515] rk_pcie_establish_link: 132 callbacks suppressed I found that the latest repository does not match your operating instructions. For example, the commit 63073b4af636146d26a7f0f258610eed060c8f34 in the Kwiboog's uboot repository branch rk3568-2023.10 is no longer found. However, the compilation does not report any errors. Could you please share your compilation repository and configuration? Thank you. @Protx kernel.log 0 Quote
Protx Posted April 18, 2024 Author Posted April 18, 2024 (edited) @darcyg First let me say that I am no expert on this. I have not tried to compile it lately, but I see that that commit does not longer exist on kwiboo's github. So I don't now if you need to revert to an older version of u-boot. And if you have an EmmC og SPI with u-boot, then it should work to boot from SC card with the new uboot anyway. My log was with debug enabled (and from uart), and I dont have that log anymore. mtty_probe+0x1e8/0x2b0 [sprdbt_tty] So I am not sure the error is the same wireless / bluetooth related error that I got . But I think it is. Make sure that the patch uw5622-fix-adjust-for-rockchip-post-6.1.patch got applied. Take a look in the /output/logs, If you have build the kernel several times it could be using a cached kernel and not included in the log!?, (look in the largest log files). And verify that uw5622-fix-adjust-for-rockchip-post-6.1.patch was included in your compilation: --> (15) INFO: Adding [ Drivers for Unisoc uwe5622 found on some Allwinner and Rockchip boards ] --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-allwinner.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-allwinner-bugfix.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-warnings.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-park-link-v6.1-post.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-v6.1.patch --> (15) INFO: * patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/wireless-uwe5622-Fix-compilation-with-6.7-kernel.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/wireless-uwe5622-reduce-system-load.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/w-wireless-fix-out-of-tree-build.patch --> (15) INFO: Preparing driver [ driver_rtl8723cs ] Edited April 18, 2024 by Protx 0 Quote
Protx Posted April 18, 2024 Author Posted April 18, 2024 (edited) @darcyg What i meant was that you manually apply the uw5622-fix-adjust-for-rockchip-post-6.1.patch before ./compile command. Then after compilation check that : --> (15) INFO: * patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch is included in the log file. BTW: Do not mind the * applying patch/misc/wireless-uwe5622/w-wireless-fix-out-of-tree-build.patch That was a patch I saw was included in the ubuntu rockchip kernel. I do not think that is needed, does not seem to make a difference. Edited April 18, 2024 by Protx 0 Quote
darcyg Posted April 19, 2024 Posted April 19, 2024 @Protx Thank you very much. I am currently compiling other systems, and I will test your solution later. Additionally, I have found that the latest official trunk403 build, as well as the previous trunk250, both exhibit this error. I am testing using an SD card. 0 Quote
