peter12 Posted February 26, 2017 Share Posted February 26, 2017 Hello, I am trying to make simple AP on my orange pi zero. sudo nmcli c add type wifi ifname '*' con-name Hotspot autoconnect no ssid Hotspotssid sudo nmcli connection modify Hotspot 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared sudo nmcli connection modify Hotspot wifi-sec.key-mgmt wpa-psk sudo nmcli connection modify Hotspot wifi-sec.psk "lepassword" sudo nmcli connection up Hotspot But after "sudo nmcli connection up Hotspot" I am getting "Error: Connection activation failed.". Any idea please? P.S. Connection to internal home wifi network works ok. Link to comment Share on other sites More sharing options...
peter12 Posted February 26, 2017 Author Share Posted February 26, 2017 Somehow it started working - when I installed dnsmasq and set listen address do 127.0.0.1 but when I want activate AP, I must stop dnsmasq first. Link to comment Share on other sites More sharing options...
tkaiser Posted February 26, 2017 Share Posted February 26, 2017 when I installed dnsmasq and set listen address do 127.0.0.1 but when I want activate AP, I must stop dnsmasq first. It seems you installed the wrong dnsmasq package. Why not simply following Armbian's documentation how to setup an AP: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration Link to comment Share on other sites More sharing options...
peter12 Posted February 26, 2017 Author Share Posted February 26, 2017 It seems you installed the wrong dnsmasq package. Why not simply following Armbian's documentation how to setup an AP: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration thanks for the link. I will check it. Link to comment Share on other sites More sharing options...
