udev rules not create SYMLINK
I create a file 98-use-serial.rules under folder /etc/udev/rules.d . But symlink not created . My purpose is to fix USB port names, As COM1 COM2 COM3
This is the content of 98-usb-serial.rules:
SUBSYSTEM=="tty",ATTRS{busnum}=="1",ATTRS{devnum}=="2",SYMLINK+="COM1"
SUBSYSTEM=="tty",ATTRS{busnum}=="4",ATTRS{devnum}=="2",SYMLINK+="COM2"
SUBSYSTEM=="tty",ATTRS{busnum}=="5",ATTRS{devnum}=="2",SYMLINK+="COM3"
I used to fix the USB port on Asus Tinker S, Khada_VIM3 , all worked fine. I have no idea why Orange Pi 4 LTD not working.
Might be related: on latest armbian, I'm
encountering two issues:
  1. Contents of /dev/serial/by-id and /dev/serial/by-path are not the same: some connected devices are missing from by-id, making it complicated to identify which /dev/ttyACMx is which.
orangepi@mypc:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 003 Device 006: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 003 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 014: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
orangepi@mypc:~$ usbreset
Usage:
  usbreset PPPP:VVVV - reset by product and vendor id
  usbreset BBB/DDD   - reset by bus and device number
  usbreset "Product" - reset by product name
Devices:
  Number 002/014  ID 1a86:55d4  USB Single Serial
  Number 003/007  ID 1a86:55d4  USB Single Serial
  Number 003/006  ID 1a86:55d4  USB Single Serial
  Number 003/002  ID 1a40:0101  USB 2.0 Hub
orangepi@mypc:~$ tree /dev/serial/
/dev/serial/
├── by-id
│   └── usb-1a86_USB_Single_Serial_535A000001-if00 -> ../../ttyACM3
└── by-path
    ├── platform-fe3a0000.usb-usb-0:1:1.0 -> ../../ttyACM3
    ├── platform-xhci-hcd.4.auto-usb-0:1.3:1.0 -> ../../ttyACM0
    └── platform-xhci-hcd.4.auto-usb-0:1.4:1.0 -> ../../ttyACM1
3 directories, 4 files
Armbian 24.5.1 bookworm
2. Simultaneously, I am encountering problems when usb-serial converter will freeze and won't respond unless I manually perform usbreset command.
udev rules (60-serial.rules) were certainly updated since armbian release ~1 year ago.
However, this might be simply related to some changes in our connected hardware. Since we added USB hub and have newer revision of these usb-serial converters, I cannot say for certain this is an OS problem.
