Gymnae Posted March 4, 2017 Posted March 4, 2017 Hi everyone, since upgrading to the new stable build DKMS refuses to compile any driver package for the 8812au Wifi chip I could find on github: make ARCH= CROSS_COMPILE= -C M=/root/rtl8812AU modules make[1]: *** M=/root/rtl8812AU: No such file or directory. Stop. Makefile:1576: recipe for target 'modules' failed make: *** [modules] Error 2 I did change the makefile to reflect compiling for ARM. This procedure worked on the old stable kernel. Is there a way to modify the Makefile or kernel sources to accept the new kernel...or is something borked with my system? The error message does not point me to a direction to check for a fix. Cheers FIX: I think I found a fix in editing the makefile, created a pullrequest with a more famous rtl8812au repo: https://github.com/diederikdehaas/rtl8812AU/pull/62
