Hi guys,
Using Debian Jessie/armbian 4.5 here. Was today using tcpdump, tested out also tshark, and aparently the BPF rules are not working... (?)
Is it just me, some kernel compiling, a bug, or am I missing something? I know for sure that in a very similar setup I have at work in Intel, I do not have this problem.
This issue is present both with libpcap 1.7.4-1 and 1.6.2-2
As an example:
rui@ruir:/etc$ sudo tcpdump -n not port 22 | egrep "22[ :]"
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
14:50:34.559080 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 4022649725:4022649913, ack 2953755432, win 335, options [nop,nop,TS val 6371162 ecr 1180556165], length 188
14:50:40.527727 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 188:408, ack 1, win 335, options [nop,nop,TS val 6371759 ecr 1180557444], length 220
14:50:41.526983 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 408:604, ack 1, win 335, options [nop,nop,TS val 6371859 ecr 1180563404], length 196
14:50:47.527292 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 604:880, ack 1, win 335, options [nop,nop,TS val 6372459 ecr 1180564390], length 276
14:50:50.527237 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 880:1076, ack 1, win 335, options [nop,nop,TS val 6372759 ecr 1180570384], length 196
14:50:53.527155 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 1076:1280, ack 1, win 335, options [nop,nop,TS val 6373059 ecr 1180573371], length 204
14:50:54.527222 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 1280:1484, ack 1, win 335, options [nop,nop,TS val 6373159 ecr 1180576370], length 204
14:50:55.527043 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 1484:1688, ack 1, win 335, options [nop,nop,TS val 6373259 ecr 1180577369], length 204
14:50:57.527493 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 1688:1892, ack 1, win 335, options [nop,nop,TS val 6373459 ecr 1180578362], length 204
14:50:58.527957 IP xx.xxx.254.104.22 > xxx.xxx.xxx.2.57030: Flags [P.], seq 1892:2096, ack 1, win 335, options [nop,nop,TS val 6373559 ecr 1180580358], length 204
I solved this myself. I suspected it was due to problems of using a toolchain in a foreign architecture, and compiled/made a deb with the debian libpcap sources myself in ARM. It is working now.
The steps to fix it are:
$apt-get source libpcap
$cd libpcap-1.6.2/
$apt-get install debhelper dh-autoreconf flex bison
$fakeroot dpkg-buildpackage -b -uc
$cd ..
$sudo dpkg -i libpcap0.8_1.6.2-2_armhf.deb
$sudo echo "libpcap0.8:armhf hold" | dpkg --set-selections
unsure what you are looking for...
if using vlan with lamobo, you need a trick to make vlan appear as tcpdump is not "meant for" vlan
sudo tcpdump -i eth0 -Uw - | tcpdump -v -en -r - vlan
sudo tcpdump -i eth0 -Uw - | tcpdump -v -en -r - vlan 102
ref.
http://virtualtechnotes.com/linux-administration/linux-networking/tcpdump-filter-802-1q-tagged-traffic
http://serverfault.com/questions/544651/vlan-tags-not-shown-in-packet-capture-linux-via-tcpdump
(same issue on linux amd64 or arm)
Edited by wildcat_paris
Interesting...the syntax seems a bit off (not working here) I will investigate it. I was already suspecting it had something to do with the VLANs/802.1Q headers. Thanks for pointing me in the right direction.
