crazyquark Posted April 20 Share Posted April 20 (edited) Hello, I would like to add support for Milk-V Mars in the Armbian build system. Right now I am building for visionfive2(build boots fine with u-boot in spi) and intend to see if I can reuse the DTBs produced by the Milk-V Mars official SDK build(https://github.com/milkv-mars/mars-buildroot-sdk/releases/). I am looking for guidance on how to proceed. The board has the same SoC as the Visionfive2 but different peripherals (USB, m.2). L.E. I realized that the bootloader from the image cannot boot the image, the “official “ u-boot from SPI flash is used instead. Possibly due to some incompatible config. Edited April 20 by crazyquark 0 Quote Link to comment Share on other sites More sharing options...
crazyquark Posted April 20 Author Share Posted April 20 Started work here: https://github.com/crazyquark/armbian-buildI forked the kernel source from the official Mars repo(split off only kernel sources). Will be building an image and testing it in my Mars board. 0 Quote Link to comment Share on other sites More sharing options...
