Problem '/dev/serial/by-id': No such file or directory
Hello!
I have Orange Pi Zero 3
I got Armbian image from this link - https://github.com/armbian/community/releases/download/24.5.0-trunk.474/Armbian_community_24.5.0-trunk.474_Orangepizero3_bookworm_current_6.6.28_minimal.img.xz
Of course I've made apt update and apt upgrade
And now I'm tying to install zigbee2mqtt using this guide -  https://www.zigbee2mqtt.io/guide/installation/01_linux.html
So, I can't list USB devices
root@orangepizero3:~# ls -l /dev/ttyACM0
ls: cannot access '/dev/ttyACM0': No such file or directory
root@orangepizero3:~# ls -l /dev/serial/by-id
ls: cannot access '/dev/serial/by-id': No such file or directory
I have tryed some tips I've found but no result, only I can see my device in this-
root@orangepizero3:~# dmesg -w
 [ 1958.349181] usb 4-1: new full-speed USB device number 2 using ohci-platform
[ 1958.585233] usb 4-1: New USB device found, idVendor=1a86, idProduct=55d4, bcdDevice= 4.42
[ 1958.585266] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1958.585286] usb 4-1: Product: SONOFF Zigbee 3.0 USB Dongle Plus V2
So, do someone have idea how to fix it and get /dev/serial/by-id****  usb addres for config need?
Thanks)
After the usb4-1 lines, you should have seen cdc_acm something
You can check that you have the acm driver with:
zcat /proc/config.gz|grep ACM
you should see config_usb_acm=m
Have you tried: ls /dev/ttyUSB* ?
When you see the ttyACM*, you should get the by-serial files appear automatically (devrules function)
