I am using orange pi pc plus after using armbian system, there is an infinite network with WLAN0 and WLAN1, but at present there is no law to use both networks at the same time and connect different SSIDs.
Error: Connection activation failed: (7) Secrets were required, but not provided.
pi@orangepipcplus:~$ cat /etc/os-release
PRETTY_NAME="Armbian 24.5.0-trunk.512 jammy"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.4 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.armbian.com"
SUPPORT_URL="https://forum.armbian.com"
BUG_REPORT_URL="https://www.armbian.com/bugs"
PRIVACY_POLICY_URL="https://www.armbian.com"
UBUNTU_CODENAME=jammy
ARMBIAN_PRETTY_NAME="Armbian 24.5.0-trunk.512 jammy"
pi@orangepipcplus:~$ uname -a
Linux orangepipcplus 6.6.29-current-sunxi #1 SMP Sat Apr 27 15:11:44 UTC 2024 armv7l armv7l armv7l GNU/Linux
pi@orangepipcplus:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.101/24 brd 192.168.1.255 scope global dynamic noprefixroute eth0
       valid_lft 4555sec preferred_lft 4555sec
    inet6 fe80::9f55:6e99:c16e:8c7/64 scope link noprefixroute
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 192.168.0.214/24 brd 192.168.0.255 scope global dynamic noprefixroute wlan0
       valid_lft 604097sec preferred_lft 604097sec
    inet6 fe80::faea:304c:b4b2:2c53/64 scope link noprefixroute
4: wlan1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
pi@orangepipcplus:~$ nmcli device wifi connect <ssid> password <pwd> ifname wlan1
At present, when I check the status of the phy controller, it is unlocked.
But I am very curious about the relationship between wdev 0x100000001 in wlan1 and wdev 0x1 in wlan0. Does this mean that wlan1 is simulated from wlan0?
pi@orangepipcplus:~$ iw dev
phy#1
        Interface wlan1
                ifindex 4
                wdev 0x100000001
                addr 12:81:64:17:13:3d
                type managed
                txpower 12.00 dBm
phy#0
        Interface wlan0
                ifindex 3
                wdev 0x1
                addr 12:81:64:17:11:3d
                ssid R15-3437
                type managed
                txpower 12.00 dBm
pi@orangepipcplus:~$ rfkill
ID TYPE DEVICE      SOFT      HARD
 0 wlan phy0   unblocked unblocked
 1 wlan phy1   unblocked unblocked
At present, I tested and found that wlan0&wlan1 can only connect to the same SSID at the same time. However, the information in iw points out that the two have different phy numbers.
