grooveman Posted May 6, 2024 Posted May 6, 2024 (edited) Hi. I installed Armbian on a raspberry pi 5. Everything went smoothly, but straight-away, I see that dmesg is filled with this error: brcmfmac: brcmf_set_channel: set chanspec 0x100c fail, reason -52 I'm noticing some inconsistencies on the network, and I'm not sure if this is behind it. I tried installing the firmware-brcm80211, but it didn't help -- in fact, I think it might have made it worse. I've looked all over, but I cannot see any useful information regarding this. It has no usb devices attached, not using and gpio pins or anything fancy. It is just a node on the network that is presenting information on a television screen in our shop. It looks like the driver is not a good match for the hardware (that's my guess, anyway). In the past, I've seen errors like this fixed with the firmware I mentioned above. No such luck this time. Any way I can fix this? Thanks. Edited May 6, 2024 by grooveman 0 Quote
c0rnelius Posted May 6, 2024 Posted May 6, 2024 Its a bug. You need to make sure the wireless country code is set, even when its not being used. 0 Quote
grooveman Posted May 7, 2024 Author Posted May 7, 2024 Yes, I saw that, but I'm not using wireless. I have wireless turned off completely in nmtui 0 Quote
c0rnelius Posted May 7, 2024 Posted May 7, 2024 Try disabling wireless completely using the config.txt: dtoverlay=disable-wifi-pi5 If you don't need bluetooth disable that to: dtoverlay=disable-bt-pi5 Not enabling it in nmtui is not enough, the module is still active 'firmware is still getting loaded' and can't find a country code. 0 Quote
