Tim Makarios Posted May 10, 2024 Posted May 10, 2024 I'm using a few Libre Computer Renegades as headless servers, and they're working well (thank you!), but I'm wanting to set one up for personal use, and I've discovered that when I plug headphones into the analog audio jack, the left and right channels are reversed. (Also, the default volume, (for example, from speaker-test in a terminal) is too loud for headphones.) sudo armbianmonitor -u Says: System diagnosis information will now be uploaded to https://paste.armbian.com/Error adding document. so I've attached armbian-hardware-monitor.log instead. armbian-hardware-monitor.log 0 Quote
