iMo Posted May 10, 2024 Posted May 10, 2024 (edited) Hi, the Armbian_community_24.5.0-trunk.563_Bananapi_jammy_current_6.6.30_xfce_desktop.img shows black screen after going to the desktop GUI (the LCD panel shows "no signal").. PS: The Armbian_23.11.1_Bananapi_jammy_current_6.1.63_xfce_desktop.img after an update/upgrade shows black screen after going to the desktop GUI (the LCD panel shows "no signal") as well.. The Armbian_22.11.0-trunk_Bananapi_bullseye_edge_5.19.6_xfce_desktop.img Armbian_23.8.2_Bananapi_jammy_current_6.1.51_xfce_desktop.img Armbian_23.11.1_Bananapi_jammy_current_6.1.63_xfce_desktop.img work. Edited May 10, 2024 by iMo added list of images tested today 0 Quote
eloirotava Posted February 28, 2025 Posted February 28, 2025 It looks like the issue is likely related to display resolution settings if you can see the initial boot text but get a black screen with "no signal" once the GUI loads. Try the following steps: Switch to a TTY session If the system is running but the display is not working, press Ctrl + Alt + F1 (or F2, F3, etc.) to access a terminal. Check the current display settings If you can log in via SSH or TTY, try running: "xrandr" This will list the available resolutions. If the default resolution is not supported by your LCD panel, you may need to adjust it manually. 0 Quote
