Hi.
My custom board has two PHY devices in the same bus. But I don´t know how to change to use the other one.
alr@lime2-emmc:~$ dmesg |grep eth0
[   10.888810] eth0: PHY ID 02430c54 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   10.893616] eth0: PHY ID 283400c2 at 8 IRQ 0 (sunxi_gmac-0:08)
Thanks!
In gmac_core.c in static int gmac_open(struct net_device *ndev)  that is placed here:
static const struct net_device_ops gmac_netdev_ops = {
	.ndo_open = gmac_open,
	.ndo_start_xmit = gmac_xmit,
	.ndo_stop = gmac_release,
	.ndo_change_mtu = gmac_change_mtu,
	.ndo_fix_features = gmac_fix_features,
	.ndo_set_rx_mode = gmac_set_rx_mode,
	.ndo_tx_timeout = gmac_tx_timeout,
	.ndo_do_ioctl = gmac_ioctl,
	.ndo_set_config = gmac_config,
#ifdef CONFIG_NET_POLL_CONTROLLER
	.ndo_poll_controller = gmac_poll_controller,
#endif
	.ndo_set_mac_address = eth_mac_addr,
Inside the ret = gmac_mdio_register(ndev);
Makes this:
	 * If we're  going to bind the MAC to this PHY bus,
			 * and no PHY number was provided to the MAC,
			 * use the one probed here.
			if ((priv->plat->bus_id == mdio_bus_data->bus_id) &&
			    (priv->plat->phy_addr == -1))
				priv->plat->phy_addr = addr;
			act = (priv->plat->bus_id == mdio_bus_data->bus_id) &&
(priv->plat->phy_addr == addr);
I would like to know how I can pass a custom address(in my case the address of the second PHY device) when the driver is loaded, to avoid the initialization of the first PHY device.
when i tried to use the ethtool
when i use the current phy address is ok, but when I use the one from the other phy device throws an error.
root@lime2-emmc:/proc# sudo ethtool -s eth0 phyad 0x00
root@lime2-emmc:/proc# sudo ethtool -s eth0 phyad 0x08
Cannot set new settings: Invalid argument
  not setting phy_address
I didn´t find any solution for this issue, but I have a possible solution:
Modify the driver to hardcode the PHY devices I´m interested to use.
Hi again,
I already change the default PHY device modify the driver, I change the gmac/gmac_mdio.c file to active the other device instead the one in 0 address.
from this:
for (addr = 0; addr < PHY_MAX_ADDR; addr++)
to this:
for (addr = PHY_MAX_ADDR; addr > -1; addr--)
but my problem is that now there is no connection.
[   10.888810] eth0: PHY ID 283400c2 at 8 IRQ 0 (sunxi_gmac-0:08) active
[   10.893616] eth0: PHY ID 02430c54 at 0 IRQ 0 (sunxi_gmac-0:00)
this is my ethtool output
root@lime2:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP AUI BNC MII FIBRE ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: No
        Advertised auto-negotiation: Yes
        Speed: 100MSpe
        Duplex: Half
        Port: MII
        PHYAD: 8
        Transceiver: external
        Auto-negotiation: off
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected
and mi ifup eth0
root@lime2:~# ifup eth0
Internet Systems Consortium DHCP Client 4.3.1
Copyright 2004-2014 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
<6>sunxi_gmac: probed
<6>eth0: PHY ID 283400c2 at 8 IRQ 0 (sunxi_gmac-0:08) active
<6>gmac_init_phy:  trying to attach to sunxi_gmac-0:08
<6>PHY_ID: sunxi_gmac-0:08
<6>ADDRCONF(NETDEV_UP): eth0: link is not ready
Listening on LPF/eth0/02:49:08:42:14:41
Sending on   LPF/eth0/02:49:08:42:14:41
Sending on   Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
<6>Trying 100/FULL
<6>PHY: sunxi_gmac-0:08 - Link is Up<c> - 100/Full<c>
<6>ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<6>PHY: sunxi_gmac-0:08 - Link is Up<c> - 100/Half<c>
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
<7>eth0: no IPv6 routers present
  DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 15
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 21
<6>Trying 100/FULL
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 13
I achieved to choose between 2 phy devices(with PHY_ADDR = 0 or PHY_ADDR =8) with the sunxi_emac driver. But the problem is during the startup, only 1 each 20 is successful, the other times lauch the next error. The only difference is the connection of the second PHY.
Starting kernel ...
<6>Booting Linux on physical CPU 0
<6>Initializing cgroup subsys cpuset
<5>Linux version 3.4.113-sun7i (root@ubuntu-dev) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #173 SMP PREEMPT Thu Jun 22 12:06:54 CEST 2017
CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: sun7i
<6>Memory Reserved:
<6>     SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
<6>     LCD  : 0x44000000 - 0x44ffffff  (  16 MB)
Memory policy: ECC disabled, Data cache writealloc
<6>sunxi: Allwinner A20 (AW1651/sun7i) detected.
<7>On node 0 totalpages: 262144
<7>free_area_init_node: node 0, pgdat c0a7b040, node_mem_map d0000000
<7>  DMA zone: 512 pages used for memmap
<7>  DMA zone: 0 pages reserved
<7>  DMA zone: 65024 pages, LIFO batch:15
<7>  Normal zone: 1008 pages used for memmap
<7>  Normal zone: 128016 pages, LIFO batch:31
<7>  HighMem zone: 528 pages used for memmap
<7>  HighMem zone: 67056 pages, LIFO batch:15
<6>PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768
<7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c>
<7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c>
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
<5>Kernel command line: root=UUID=b574c49a-b2ac-4487-9e0f-6a0419e9052f rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 l1
<6>PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>allocated 2097152 bytes of page_cgroup
<6>please try 'cgroup_disable=memory' option if you don't want memory cgroups
<6>Memory: 1024MB = 1024MB total
<5>Memory: 1004800k/1004800k available, 43776k reserved, 270336K highmem
<5>Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc09d3b0c   (10031 kB)
      .init : 0xc09d4000 - 0xc0a0b040   ( 221 kB)
      .data : 0xc0a0c000 - 0xc0a83830   ( 479 kB)
       .bss : 0xc0a83854 - 0xc0c58a30   (1877 kB)
<6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>Preemptible hierarchical RCU implementation.
<6>     RCU dyntick-idle grace-period acceleration is enabled.
<6>     Additional per-CPU info printed with stalls.
<6>NR_IRQS:192
<6>Architected local timer running at 24.00MHz.
<6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<2>start_kernel(): bug: interrupts were enabled early
<6>Console: colour dummy device 80x30
<6>console [tty1] enabled
<6>Calibrating delay loop... <c>1816.98 BogoMIPS (lpj=9084928)
<6>pid_max: default: 32768 minimum: 301
<6>Mount-cache hash table entries: 512
<6>Initializing cgroup subsys cpuacct
<6>Initializing cgroup subsys memory
<6>Initializing cgroup subsys devices
<6>Initializing cgroup subsys freezer
<6>Initializing cgroup subsys blkio
<6>Initializing cgroup subsys perf_event
<6>CPU: Testing write buffer coherency: ok
<6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
<6>Setting up static identity map for 0x4071c270 - 0x4071c2c8
CPU1: Booted secondary processor
<6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<6>Brought up 2 CPUs
<6>SMP: Total of 2 processors activated (3640.52 BogoMIPS).
<6>devtmpfs: initialized
<6>dummy:
<6>NET: Registered protocol family 16
<6>DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>hw-breakpoint: maximum watchpoint size is 8 bytes.
<6>[ccu-inf] aw clock manager init
<6>[ccu-inf] aw_ccu_init
<6>[ccu-inf] script config pll4 to 300MHz
<6>[ccu-inf] script config pll6 to 600MHz
<6>[ccu-inf] script config pll7 to 297MHz
<6>[ccu-inf] script config pll8 to 336MHz
<6>Init eGon pin module V2.0
<6>bio: create slab <bio-0> at 0
<6>sunxi_gpio driver init ver 1.3
<6>gpiochip_add: registered GPIOs 1 to 4 on device: A1X_GPIO
<5>SCSI subsystem initialized
<7>libata version 3.00 loaded.
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>Linux media interface: v0.10
<6>Linux video capture interface: v2.00
<6>Advanced Linux Sound Architecture Driver Version 1.0.25.
<6>cfg80211: Calling CRDA to update world regulatory domain
<6>Switching to clocksource arch_sys_counter
<5>FS-Cache: Loaded
<6>CacheFiles: Loaded
[usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[sw_hcd0]: usb host driver initialize........
[sw_hcd0]: open_usb_clock
[sw_hcd0]: host_init_state = 1
[sw_hcd0]: platform is usb host
[sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
[sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
<6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
<6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 1 port detected
wrn: hcd is not enable, need not start hcd
[sw_hcd0]: sw_usb_host0_disable start
-------sw_hcd0_soft_disconnect---------
is_on = 0, hcd0_set_vbus_cnt = 0
[sw_hcd_host0]: Set USB Power Off
wrn: hcd is not enable, need not stop hcd
[sw_hcd0]: close_usb_clock
[sw_hcd0]: sw_usb_host0_disable end
[sw_udc]: udc_init: version 20080411
<6>NET: Registered protocol family 2
<6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
<6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>TCP: Hash tables configured (established 131072 bind 65536)
<6>TCP: reno registered
<6>UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>RPC: Registered named UNIX socket transport module.
<6>RPC: Registered udp transport module.
<6>RPC: Registered tcp transport module.
<6>RPC: Registered tcp NFSv4.1 backchannel transport module.
<6>Trying to unpack rootfs image as initramfs...
<6>Freeing initrd memory: 3544K
<6>audit: initializing netlink socket (disabled)
<5>type=2000 audit(0.850:1): initialized
highmem bounce pool size: 64 pages
<5>VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<6>squashfs: version 4.0 (2009/01/31) Phillip Lougher
<5>NFS: Registering the id_resolver key type
<6>NTFS driver 2.1.30 [Flags: R/W].
<6>fuse init (API version 7.18)
<6>JFS: nTxBlock = 7877, nTxLock = 63021
<6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
<6>Btrfs loaded
<6>msgmni has been set to 1441
<6>alg: No test for stdrng (krng)
<6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>io scheduler noop registered
<6>io scheduler deadline registered
<6>io scheduler cfq registered (default)
<6>sunxi disp driver loaded (/dev/disp api 1.0)
<6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
<6>[uart]: used uart info.: 0x81
<6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000
<6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
<6>console [ttyS0] enabled
<6>[uart]: serial probe 7 irq 52 mapbase 0x01c29c00
<6>sunxi-uart.7: ttyS1 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A
<7>G2D: drv_g2d_init
<6>G2D: Module initialized.major:250
<6>brd: module loaded
<6>loop: module loaded
nand driver is disabled
pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10
SATA AHCI Phy Power Failed!!
SATA AHCI Phy Calibration Failed!!
<6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
<4>sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
<6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
<6>sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
<6>scsi0 : sw_ahci_platform
<6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
<6>[spi-inf] Found 2 spi devices in config files
<6>[spi-inf] boards num modalias         max_spd_hz       bus_num  cs   mode
<6>[spi-inf] spi_board0 irq gpio not used
<6>[spi-inf] 0          spidev           1000000          2        0    0x3
<6>[spi-inf] spi_board1 irq gpio not used
<6>[spi-inf] 1          spidev           1000000          1        0    0x3
<4>spi: cannot find any using configuration for                     all 4 spi controllers, return directly!
<6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
<6>Fixed MDIO Bus: probed
<6>sunxi_emac Using mii phy on PortA
<6>EMAC READ
<6>sunxi_emac Using MAC from SID: 02:89:08:42:64:e6<6>PPP generic driver version 2.4.2
<6>PPP BSD Compression module registered
<6>PPP Deflate Compression module registered
<6>PPP MPPE Compression module registered
<6>NET: Registered protocol family 24
<6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[sw-ehci1]: open clock
[sw-ehci1]: Set USB Power ON
<6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
<6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
<6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
<6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 1 port detected
[sw-ohci1]: open clock
<6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
<6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
<6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
<6>hub 3-0:1.0: USB hub found
<6>hub 3-0:1.0: 1 port detected
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>usbcore: registered new interface driver ums-alauda
<6>usbcore: registered new interface driver ums-cypress
<6>usbcore: registered new interface driver ums-datafab
<6>usbcore: registered new interface driver ums_eneub6250
<6>usbcore: registered new interface driver ums-freecom
<6>usbcore: registered new interface driver ums-isd200
<6>usbcore: registered new interface driver ums-jumpshot
<6>usbcore: registered new interface driver ums-karma
<6>usbcore: registered new interface driver ums-onetouch
<6>usbcore: registered new interface driver ums-realtek
<6>ata1: SATA link down (SStatus 0 SControl 300)
<6>usbcore: registered new interface driver ums-sddr09
<6>usbcore: registered new interface driver ums-sddr55
<6>usbcore: registered new interface driver ums-usbat
<6>mousedev: PS/2 mouse device common for all mice
===========================hv_keypad_init=====================
========HV Inital ===================
<3>tkey_fetch_sysconfig_para: tkey_unused.
hv_keypad_init: after fetch_sysconfig_para:  normal_i2c: 0x0. normal_i2c[1]: 0x0
<3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong!
<6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
<6>i2c /dev entries driver
config i2c gpio with gpio_config api
<4>i2c i2c-0: Invalid probe address 0x00
<6>I2C: i2c-0: AW16XX I2C adapter
<4>i2c i2c-1: Invalid probe address 0x00
<6>I2C: i2c-1: AW16XX I2C adapter
<4>i2c i2c-2: Invalid probe address 0x00
<6>I2C: i2c-2: AW16XX I2C adapter
<4>i2c i2c-4: Invalid probe address 0x00
<6>I2C: i2c-4: AW16XX I2C adapter
[cedar dev]: not installed! ve_mem_reserve=0
[tt]----- avs_dev driver load... ----
[tt]-----      register iomem      ----
[tt]--- avs_dev driver load ok!! -----
[ace_drv] start!!!
[ace_drv] init end!!!
[pa_drv] start!!!
[pa_drv] init end!!!
incomplete xfer (0x20)
<6>device-mapper: uevent: version 1.0.3
<6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
<6>device-mapper: multipath: version 1.3.2 loaded
<6>device-mapper: multipath round-robin: version 1.0.0 loaded
<6>device-mapper: multipath queue-length: version 0.1.0 loaded
<6>device-mapper: multipath service-time: version 0.2.0 loaded
<6>cpuidle: using governor ladder
<6>cpuidle: using governor menu
<6>[mmc-msg] sw_mci_init
<6>[mmc-msg] MMC host used card: 0x5, boot card: 0x5, io_card 0
<6>[mmc-msg] sdc0 set round clock 400000, src 24000000
<6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc0 Probe: base:0xf05e6000 irq:64 sg_cpu:f05e8000(4fc00000) ret 0.
<6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc0 power on
<6>[mmc-msg] sdc2 set round clock 400000, src 24000000
<6>[mmc-msg] sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<3>[mmc-err] smc 0 err, cmd 52,  RTO
<3>[mmc-err] smc 0 err, cmd 5,  RTO
<6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<6>[mmc-msg] sdc0 set round clock 42857143, src 600000000
<6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
<6>mmc0: new high speed SDHC card at address 0007
<6>mmcblk0: mmc0:0007 SD04G 3.70 GiB
<6> mmcblk0: p1
<3>[mmc-err] update clock timeout, fatal error
<6>[mmc-msg] sdc2 Probe: base:0xf05ea000 irq:66 sg_cpu:f05ec000(4fc01000) ret 0.
<6>[mmc-msg] sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc2 power on
[mmc_pm]: failed to fetch sdio card configuration!
<6>sunxi_leds driver init
<6>sunxi_leds_init leds_used is false. Skip leds initialization
<6>ledtrig-cpu: registered to indicate activity on CPUs
<6>usbcore: registered new interface driver usbhid
<6>usbhid: USB HID core driver
<6>ashmem: initialized
<6>logger: created 256K log 'log_main'
<6>logger: created 256K log 'log_events'
<6>logger: created 256K log 'log_radio'
<6>logger: created 256K log 'log_system'
[SPDIF] [spdif_para] isn't defined or spdif_used=0
[I2S-0] Entered sunxi_i2s_init
[I2S-0] sunxi-i2s cannot find any using configuration for controllers, return directly!
[I2S-0] sndi2s cannot find any using configuration for controllers, return directly!
[I2S-0] Entered sunxi_sndi2s_init
<6>TCP: bic registered
<6>TCP: cubic registered
<6>TCP: westwood registered
<6>TCP: highspeed registered
<6>TCP: hybla registered
<6>TCP: htcp registered
<6>TCP: vegas registered
<6>TCP: veno registered
<6>TCP: scalable registered
<6>TCP: lp registered
<6>TCP: yeah registered
<6>TCP: illinois registered
<6>Initializing XFRM netlink socket
<6>NET: Registered protocol family 10
<6>NET: Registered protocol family 17
<6>NET: Registered protocol family 15
[mmc_pm]: No sdio card, please check your config !!
<5>Registering the dns_resolver key type
<6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
<5>Registering SWP/SWPB emulation handler
<3>[cpu_freq] ERR:try to get regulator failed, core vdd will not changed!
<6>[cpu_freq] INF:-------------------V-F Table-------------------
<6>[cpu_freq] INF:      voltage = 1450mv        frequency = 1008MHz
<6>[cpu_freq] INF:      voltage = 1425mv        frequency =  912MHz
<6>[cpu_freq] INF:      voltage = 1350mv        frequency =  864MHz
<6>[cpu_freq] INF:      voltage = 1250mv        frequency =  720MHz
<6>[cpu_freq] INF:      voltage = 1150mv        frequency =  528MHz
<6>[cpu_freq] INF:      voltage = 1100mv        frequency =  312MHz
<6>[cpu_freq] INF:      voltage = 1050mv        frequency =  144MHz
<6>[cpu_freq] INF:      voltage = 1000mv        frequency =    0MHz
<6>[cpu_freq] INF:-----------------------------------------------
<6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 1008MHz, min freq: 720MHz
<6>registered taskstats version 1
<4>[DISP] *****************************************************************
<4>[DISP] ***
<4>[DISP] *** LCD Panel Parameter Check
<4>[DISP] ***
<4>[DISP] ***             by dulianping
<4>[DISP] ***
<4>[DISP] ***
<4>[DISP] *** Interface:<4>[DISP] *** Parallel HV Panel
<4>[DISP] *** Lcd Frm to RGB666
<4>[DISP] ***
<4>[DISP] *** Timing:
<4>[DISP] *** lcd_x:      800
<4>[DISP] *** lcd_y:      480
<4>[DISP] *** lcd_ht:     1055
<4>[DISP] *** lcd_hbp:    216
<4>[DISP] *** lcd_vt:     1050
<4>[DISP] *** lcd_vbp:    35
<4>[DISP] *** lcd_hspw:   0
<4>[DISP] *** lcd_vspw:   0
<4>[DISP] *** lcd_frame_frq:  16Hz
<4>[DISP] ***
<4>[DISP] *** WRN03: Recommend "lcd_dclk_frq = 33"
<4>[DISP] ***
<4>[DISP] *** LCD Panel Parameter Check End
<6>[mmc-msg] sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>Console: switching to colour frame buffer device 100x30
<6>I2C: i2c-3: HDMI I2C adapter
<6>console [netcon0] enabled
<6>netconsole: network logging started
<3>otg_wakelock_init: No USB transceiver found
<6>ALSA device list:
<6>  #0: sunxi-CODEC  Audio Codec
<6>Freeing init memory: 220K
Loading, please wait...
<30>systemd-udevd[90]: starting version 215
done.
Begin: Will now check root file system ... fsck from util-linux 2.25.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 48573/226896 files, 274036/920320 blocks
done.
<6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
done.
Begin: Running /scripts/init-bottom ... <3>[mmc-err] update clock timeout, fatal error
done.
<6>[mmc-msg] sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc2 power off
<30>systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
<30>systemd[1]: Detected architecture 'arm'.
Welcome to Debian GNU/Linux 8 (jessie)!
<30>systemd[1]: Set hostname to <lime2>.
<28>systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
<30>systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
<30>systemd[1]: Started Forward Password Requests to Wall Directory Watch.
<30>systemd[1]: Expecting device dev-ttyS0.device...
<30>systemd[1]: Starting Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems (Pre).
<30>systemd[1]: Reached target Remote File Systems (Pre).
<30>systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary Executable File Formats F...utomount Point.
<30>systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
<30>systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
<30>systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
<30>systemd[1]: Starting Paths.
[  OK  ] Reached target Paths.
<30>systemd[1]: Reached target Paths.
<30>systemd[1]: Starting Encrypted Volumes.
[  OK  ] Reached target Encrypted Volumes.
<30>systemd[1]: Reached target Encrypted Volumes.
<30>systemd[1]: Starting Swap.
[  OK  ] Reached target Swap.
<30>systemd[1]: Reached target Swap.
<30>systemd[1]: Starting Root Slice.
[  OK  ] Created slice Root Slice.
<30>systemd[1]: Created slice Root Slice.
<30>systemd[1]: Starting Delayed Shutdown Socket.
[  OK  ] Listening on Delayed Shutdown Socket.
<30>systemd[1]: Listening on Delayed Shutdown Socket.
<30>systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
<30>systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
<30>systemd[1]: Starting Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
<30>systemd[1]: Listening on Journal Socket (/dev/log).
<30>systemd[1]: Starting User and Session Slice.
[  OK  ] Created slice User and Session Slice.
<30>systemd[1]: Created slice User and Session Slice.
<30>systemd[1]: Starting udev Control Socket.
[  OK  ] Listening on udev Control Socket.
<30>systemd[1]: Listening on udev Control Socket.
<30>systemd[1]: Starting udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
<30>systemd[1]: Listening on udev Kernel Socket.
<30>systemd[1]: Starting Journal Socket.
[  OK  ] Listening on Journal Socket.
<30>systemd[1]: Listening on Journal Socket.
<30>systemd[1]: Starting System Slice.
[  OK  ] Created slice System Slice.
<30>systemd[1]: Created slice System Slice.
<30>systemd[1]: Starting Increase datagram queue length...
<30>systemd[1]: Starting Restore / save the current clock...
<30>systemd[1]: Mounting POSIX Message Queue File System...
<30>systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required static device nodes...rrent kernel...
<30>systemd[1]: Starting udev Coldplug all Devices...
<30>systemd[1]: Mounting Debug File System...
<30>systemd[1]: Started Set Up Additional Binary Formats.
<30>systemd[1]: Mounted Huge Pages File System.
<30>systemd[1]: Starting system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
<30>systemd[1]: Created slice system-serial\x2dgetty.slice.
<30>systemd[1]: Starting system-getty.slice.
[  OK  ] Created slice system-getty.slice.
<30>systemd[1]: Created slice system-getty.slice.
<30>systemd[1]: Starting Load Kernel Modules...
<30>systemd[1]: Started File System Check on Root Device.
<30>systemd[1]: Starting LSB: Set keymap...
<30>systemd[1]: Starting Slices.
<6>Bluetooth: Core ver 2.16
<6>NET: Registered protocol family 31
<6>Bluetooth: HCI device and connection manager initialized
<6>Bl[  OK  ] Reached target Slices.
uetooth: HCI socket layer initialized
<6>Bluetooth: L2CAP socket layer initialized
<6>Bluetooth: SCO socket layer initialized
<30>systemd[1]: Reached target Slices.
<6>Bluetooth: HCI UART driver ver 2.2
<6>Bl[  OK  ] Mounted Debug File System.
uetooth: HCI H4 protocol initialized
<6>Bluetooth: HCI BCSP protocol initialized
<6>Bluetooth: HCILL protocol initialized
<6>Bluetooth: HCIATH3K protocol initialized
<30>systemd[1]: Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
<6>Bluetooth: RFCOMM TTY layer initialized
<6>Bluetooth: RFCOMM socket layer initialized
<6>Bluetooth: RFCOMM ver 1.11
<6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<30>systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Started Increase datagram queue length.
<6>8021q: 802.1Q VLAN Support v1.8
<6>a20-tp-hwmon a20-tp-hwmon: TP initialization success
<30>systemd[1]: Started Increase datagram queue length.
[  OK  ] Started Restore / save the current clock.
<30>systemd[1]: Started Restore / save the current clock.
[  OK  ] Started Create list of required static device nodes ...current kernel.
<30>systemd[1]: Started Create list of required static device nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
<30>systemd[1]: Started Load Kernel Modules.
[  OK  ] Started LSB: Set keymap.
<30>systemd[1]: Started LSB: Set keymap.
[  OK  ] Started udev Coldplug all Devices.
<30>systemd[1]: Started udev Coldplug all Devices.
<30>systemd[1]: Time has been changed
<30>systemd[1]: Mounting Configuration File System...
<30>systemd[1]: Mounting FUSE Control File System...
<30>systemd[1]: Starting Apply Kernel Variables...
<30>systemd[1]: Starting Create Static Device Nodes in /dev...
<30>systemd[1]: Starting Syslog Socket.
[  OK  ] Listening on Syslog Socket.
<30>systemd[1]: Listening on Syslog Socket.
[  OK  ] Mounted FUSE Control File System.
<30>systemd[1]: Mounted FUSE Control File System.
[  OK  ] Mounted Configuration File System.
<30>systemd[1]: Mounted Configuration File System.
[  OK  ] Started Apply Kernel Variables.
<30>systemd[1]: Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
<30>systemd[1]: Started Create Static Device Nodes in /dev.
<30>systemd[1]: Starting udev Kernel Device Manager...
<30>systemd-udevd[170]: starting version 215
[  OK  ] Started udev Kernel Device Manager.
<30>systemd[1]: Started udev Kernel Device Manager.
<30>systemd[1]: Starting Copy rules generated while the root was ro...
<30>systemd[1]: Starting LSB: Set preliminary keymap...
<30>systemd[1]: Starting LSB: Tune IDE hard disks...
[  OK  ] Started Copy rules generated while the root was ro.
<30>systemd[1]: Started Copy rules generated while the root was ro.
[  OK  ] Started LSB: Tune IDE hard disks.
<30>systemd[1]: Started LSB: Tune IDE hard disks.
[  OK  ] Found device /dev/ttyS0.
<30>systemd[1]: Found device /dev/ttyS0.
<30>systemd[1]: Starting Sound Card.
[  OK  ] Reached target Sound Card.
<30>systemd[1]: Reached target Sound Card.
<30>systemd[1]: Starting system-ifup.slice.
[  OK  ] Created slice system-ifup.slice.
<30>systemd[1]: Created slice system-ifup.slice.
[  OK  ] Started LSB: Set preliminary keymap.
<30>systemd[1]: Started LSB: Set preliminary keymap.
<30>systemd[1]: Starting Remount Root and Kernel File Systems...
<6>EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[  OK  ] Started Remount Root and Kernel File Systems.
<30>systemd[1]: Started Remount Root and Kernel File Systems.
<30>systemd[1]: Started Various fixups to make systemd work better on Debian.
<30>systemd[1]: Starting Load/Save Random Seed...
<30>systemd[1]: Starting Local File Systems (Pre).
[  OK  ] Reached target Local File Systems (Pre).
<30>systemd[1]: Reached target Local File Systems (Pre).
<30>systemd[1]: Mounting /tmp...
         Mounting /tmp...
[  OK  ] Started Load/Save Random Seed.
<30>systemd[1]: Started Load/Save Random Seed.
[  OK  ] Mounted /tmp.
<30>systemd[1]: Mounted /tmp.
<30>systemd[1]: Starting Local File Systems.
[  OK  ] Reached target Local File Systems.
<30>systemd[1]: Reached target Local File Systems.
<30>systemd[1]: Starting Armbian enhanced Log2Ram...
<30>systemd[1]: Starting Create Volatile Files and Directories...
<30>systemd[1]: Starting Remote File Systems.
[  OK  ] Reached target Remote File Systems.
<30>systemd[1]: Reached target Remote File Systems.
<30>systemd[1]: Starting LSB: Prepare console...
<30>systemd[1]: Starting LSB: Raise network interfaces....
[  OK  ] Started Create Volatile Files and Directories.
<30>systemd[1]: Started Create Volatile Files and Directories.
[  OK  ] Started Armbian enhanced Log2Ram.
<30>systemd[1]: Started Armbian enhanced Log2Ram.
[  OK  ] Started LSB: Prepare console.
<30>systemd[1]: Started LSB: Prepare console.
<30>systemd[1]: Starting LSB: Set console font and keymap...
<30>systemd[1]: Starting Journal Service...
[  OK  ] Started Journal Service.
<30>systemd[1]: Started Journal Service.
         Starting Trigger Flushing of Journal to Persistent Storage...
         Starting Update UTMP about System Boot/Shutdown...
<46>systemd-journald[314]: Received request to flush runtime journal from PID 1
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
<6>EMAC READ
<6>EMAC init 12544
<6>EMAC WRITE
<6>EMAC WRITE
<6>EMAC READ
<6>EMAC READ
<6>EMAC READ
<6>EMAC READ
<6>EMAC READ
<6>EMAC READ
<6>sunxi_emac sunxi_emac.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC501
[  OK  ] Started LSB: Raise network interfaces..
[  OK  ] Started LSB: Set console font and keymap.
         Starting ifup for eth0...
[  OK  ] Started ifup for eth0.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Basic System.
         Starting Entropy daemon using the HAVEGE algorithm...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting System Logging Service...
<1>Unable to handle kernel paging request at virtual address f164a4f7
[   13.139101] Unable to handle kernel paging request at virtual address f164a4f7
<1>pgd = ee9a4000
[   13.148281] pgd = ee9a4000
<1>[f164a4f7] *pgd=00000000[   13.153473] [f164a4f7] *pgd=00000000
<0>Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[   13.161690] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
<d>Modules linked in:[   13.169062] Modules linked in: a20_tp a20_tp 8021q 8021q garp garp stp stp llc llc hidp hidp rfcomm rfcomm hci_uart hci_uart bluetooth bluetooth [last unloaded: scsi_wait_scan] [last unlo]
CPU: 1    Not tainted  (3.4.113-sun7i #173)
[   13.192544] CPU: 1    Not tainted  (3.4.113-sun7i #173)
PC is at dup_mm+0x2c4/0x41c
[   13.200538] PC is at dup_mm+0x2c4/0x41c
LR is at dup_mm+0x300/0x41c
[   13.207093] LR is at dup_mm+0x300/0x41c
pc : [<c00352cc>]    lr : [<c0035308>]    psr: a00f0013
sp : ef03bec8  ip : 00000006  fp : eea3c37c
[   13.219969] pc : [<c00352cc>]    lr : [<c0035308>]    psr: a00f0013
[   13.219988] sp : ef03bec8  ip : 00000006  fp : eea3c37c
r10: eea3c390  r9 : eea3c38c  r8 : eea3c370
[   13.235869] r10: eea3c390  r9 : eea3c38c  r8 : eea3c370
r7 : ee91cfc0  r6 : f51e171e  r5 : f164a4df  r4 : eea3c370
[   13.246534] r7 : ee91cfc0  r6 : f51e171e  r5 : f164a4df  r4 : eea3c370
r3 : fff4350b  r2 : 00000000  r1 : f51e171e  r0 : ee91cfc0
[   13.258546] r3 : fff4350b  r2 : 00000000  r1 : f51e171e  r0 : ee91cfc0
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   13.271167] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c5387d  Table: 6e9a406a  DAC: 00000015
[   13.283021] Control: 10c5387d  Table: 6e9a406a  DAC: 00000015
PC: 0xc003524c:
[   13.290661]
[   13.290667] PC: 0xc003524c:
Any hints?
