  • parkmino changed the title to no wifi on RPi5
I also noticed the same issue. On a fresh install of Armbian on the RPi5 the wifi works fine. As soon as I run an `sudo apt-get upgrade`, one of the upgraded packages breaks the wifi connection on the next reboot.
Unfortunately for me, the fix in this thread didn't work for me. The wifi card see's the ssid's of all the networks around me, but when I try to connect, I see the following in the syslog:
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.7533] Config: added 'scan_ssid' value '1'
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.7533] Config: added 'bgscan' value 'simple:30:-70:86400'
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.7533] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.7533] Config: added 'auth_alg' value 'OPEN'
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.7533] Config: added 'psk' value '<hidden>'
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.9452] device (wlan0): supplicant interface state: disconnected -> scanning
Jun 22 17:31:10 adv-campi NetworkManager[792]: <info>  [1719091870.9453] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
Jun 22 17:31:20 adv-campi kernel: [  178.025819] ieee80211 phy0: brcmf_escan_timeout: timer expired
Jun 22 17:31:36 adv-campi NetworkManager[792]: <warn>  [1719091896.1016] device (wlan0): Activation: (wifi) association took too long, failing activation
Jun 22 17:31:36 adv-campi NetworkManager[792]: <info>  [1719091896.1016] device (wlan0): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Jun 22 17:31:36 adv-campi NetworkManager[792]: <warn>  [1719091896.1021] device (wlan0): Activation: failed for connection '***CENSORED***'
Jun 22 17:31:36 adv-campi NetworkManager[792]: <info>  [1719091896.1023] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jun 22 17:31:38 adv-campi kernel: [  195.689650] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jun 22 17:31:38 adv-campi kernel: [  195.698667] ieee80211 phy0: brcmf_cfg80211_get_channel: chanspec failed (-110)
Jun 22 17:31:38 adv-campi wpa_supplicant[871]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 22 17:31:38 adv-campi NetworkManager[792]: <info>  [1719091898.7612] device (wlan0): supplicant interface state: scanning -> disconnected
Jun 22 17:31:38 adv-campi NetworkManager[792]: <info>  [1719091898.7613] device (p2p-dev-wlan0): supplicant management interface state: scanning -> disconnected
Jun 22 17:31:39 adv-campi terminator.desktop[2526]: <window.Window object at 0xffff996cf800 (terminatorlib+window+Window at 0xaaaad8580510)> is not in registered window list
Jun 22 17:31:39 adv-campi systemd[1398]: app-gnome-terminator-2526.scope: Consumed 1.341s CPU time.
Jun 22 17:31:44 adv-campi NetworkManager[792]: <info>  [1719091904.4725] manager: rfkill: Wi-Fi hardware radio set disabled
Jun 22 17:31:44 adv-campi NetworkManager[792]: <info>  [1719091904.4726] device (wlan0): state change: disconnected -> unavailable (reason 'none', sys-iface-state: 'managed')
Jun 22 17:31:44 adv-campi systemd[1]: Starting Load/Save RF Kill Switch Status...
Jun 22 17:31:44 adv-campi systemd[1]: Started Load/Save RF Kill Switch Status.
Jun 22 17:31:47 adv-campi kernel: [  204.137565] brcmfmac: brcmf_set_channel: set chanspec 0x1001 fail, reason -110
Jun 22 17:31:47 adv-campi kernel: [  204.269717] brcmfmac: brcmf_dump_obss: dump_obss error (-52)
Jun 22 17:31:47 adv-campi NetworkManager[792]: <info>  [1719091907.2677] audit: op="radio-control" arg="wireless-enabled:off" pid=1873 uid=1000 result="success"
Jun 22 17:31:47 adv-campi NetworkManager[792]: <info>  [1719091907.2682] manager: rfkill: Wi-Fi now disabled by radio killswitch
Jun 22 17:31:47 adv-campi NetworkManager[792]: <info>  [1719091907.2709] device (p2p-dev-wlan0): state change: disconnected -> unavailable (reason 'supplicant-failed', sys-iface-state: 'managed')
Jun 22 17:31:47 adv-campi wpa_supplicant[871]: rfkill: WLAN soft blocked
Jun 22 17:31:47 adv-campi wpa_supplicant[871]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 22 17:31:47 adv-campi wpa_supplicant[871]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Jun 22 17:31:47 adv-campi wpa_supplicant[871]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 22 17:31:49 adv-campi systemd[1]: systemd-rfkill.service: Deactivated successfully.
Jun 22 17:31:50 adv-campi kernel: [  207.209533] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jun 22 17:31:50 adv-campi kernel: [  207.218553] ieee80211 phy0: brcmf_cfg80211_get_channel: chanspec failed (-110)
Jun 22 17:31:50 adv-campi wpa_supplicant[871]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 22 17:31:50 adv-campi wpa_supplicant[871]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
