pkfox Posted May 15, 2024 Posted May 15, 2024 Hi All, I wanted to add some dtoverlay lines to the pi's config.txt which was in /boot/firmware/config.txt and I notice the folder is empty ? WTF the pi is running ok - how can this be ? 0 Quote
Gunjan Gupta Posted May 15, 2024 Posted May 15, 2024 It can be as simple as /boot/firmware not being mounted. Do you see /boot/firmware in output of mount command? 0 Quote
pkfox Posted May 16, 2024 Author Posted May 16, 2024 (edited) @Gunjan Gupta - I rebooted and all was as it should be. Thanks for replying Edited May 16, 2024 by pkfox edit 0 Quote
