miha Posted April 1, 2017 Posted April 1, 2017 Hi, I wrote Armbian_5.25_Cubietruck_Ubuntu_xenial_default_3.4.113.img to sd-card and booted my cubietruck from the card. ssh in and user creation followed by reboot (rootfs resize) After that i performed apt get update&upgrade and started nand-sata-install. I have SSD hooked to CubieTruck and my goal is boot system from onboard memory (with 3.4-kernel nand is available but not with 4.9...) and roots to /dev/sda1. This was how previous setup was. sd-card slot is broken, I need to use tape to keep card on the reader, another reason why boot from nand would be nice. However, when i start and-sata-install, following is displayed on console: [ 112.701170] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 [ 112.710146] Dev Sunxi softw311 nand magic does not match for MBR 2: [ 112.719450] Dev Sunxi softw311 nand magic does not match for MBR 3: [ 112.725528] Dev Sunxi softw311 nand magic does not match for MBR 4: [ 112.733262] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. [ 112.743553] Dev Sunxi softw411 nand: part 1, start 65536, size 65536 [ 112.749216] Dev Sunxi softw411 nand: part 2, start 131072, size 14909440 [ 112.751266] nand: nand1 nand2 [ 112.764254] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 [ 112.770268] Dev Sunxi softw311 nand magic does not match for MBR 2: [ 112.776448] Dev Sunxi softw311 nand magic does not match for MBR 3: [ 112.782522] Dev Sunxi softw311 nand magic does not match for MBR 4: [ 112.790258] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. [ 112.800339] Dev Sunxi softw411 nand: part 1, start 65536, size 65536 [ 112.806096] Dev Sunxi softw411 nand: part 2, start 131072, size 14909440 [ 112.808112] nand: nand1 nand2 It's clear that my CubieTruck fails to boot from nand. I have searched around the web and conclusion is that i should install old ubuntu-server and flash with LiveSuite (which is not working with my MacOSsierra...) Is there any other possibilities to get system booting from /den/nand? Br miha
