I managed to make w1-GPIO work in Orange Pi Zero v3 for, for example, the DS18B20 sensor.
However, I have some doubts about setting the GPIO flags for w1-gpio. Many examples provide flags in the form
gpios = <&pio 0 7 (GPIO_ACTIVE_HIGH|GPIO_OPEN_DRAIN)>;
but in the dts file when I use this form it does not work (syntax error) so I have to provide the flags in digital form.
A description of flags and bits is here
https://elixir.bootlin.com/linux/v6.6.30/source/include/dt-bindings/gpio/gpio.h
If I would like to set GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN then the digital value for these bits will be for set bits: 0110000 =  48
because GPIO_OPEN_DRAIN it is (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_DRAIN)
Please help me and confirm whether I understood it correctly I wanted to get rid of the message in the logs for w1-gpio
[ 4.994183] gpio-74 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
which understands that I need to set the GPIO flag GPIO_OPEN_DRAIN in the dts file
I see one problem with this source https://www.kernel.org/doc/Documentation/devicetree/bindings/gpio/gpio.txt
where a number of bits to set is 6 in source https://elixir.bootlin.com/linux/v6.6.30/source/include/dt-bindings/gpio/gpio.h
number of bits to set is 7
I hope I posted this question in the right section, if not please move it
Edited by TRay
Reading many others documents about OPEN DRAIN flag , OZPI v3 and others like Raspberry Pi don't support Open DRAIN, but they should work in emulated mode, switching between input and output-driving-low. So for this reason if we set flag for GPIO with OPEN DARIN it looks not influence and not need setting this flag for w1-gpio for this SBC
Edited by TRay
