Hi, I have a question regarding the new Banana Pi (A20) boot script created in Armbian 5.25.
Many months ago I switched my roots from the SDCard to the sata disk using the sata-nand-install script, after that I used to switch between SD and HDD and vice versa, mostly for maintenance operations on the HDD (sometime the system gets corrupted and I have to restore the HDD partition with e2fsck from the SD).
Until Armbian 5.20 I used to edit the boot.cmd file pointing to the desired root device, recompile the boot.scr and then the system were loaded from the desired partition.
Now with Armbian 5.25 I'm not sure which file I have to edit to do the same, boot.cmd or ArmbianEnv.txt?
I've tried both but the boot didn't seem to be right and I don't understand if it's because my HDD is dead or because I badly edited the new boot script.
Could someone help me please?
Thanks!
For changing the boot device - only armbianEnv.txt
Hard to say anything without logs and exact description of your changes
So basically I should just edit armbianEnv.txt from
rootdev=UUID=64383220-a185-4473-b3ab-ef1612d4d94c
to
rootdev=/dev/sda2
and then just reboot?
Or I still need to recompile boot.scr?
rootdev parameter can be set using the dev path or the UUID method is mandatory?
Thanks again!
to
rootdev=/dev/sda2
Pretty much
No
Using UUID is more reliable than device node names that may change i.e. if additional USB storage was connected
Thank you very much for your help,
tried to edit the armbianEnv.txt but the system doesn't boot...I guess my HHD partition has been corrupted for good... :-\
