shushkata Posted May 25, 2024 Posted May 25, 2024 Hi all. I am new to Arm and Linux in general. Got me a Raspberry pi5 several days ago and was going trough different OS systems so i can settle on one final choice. Landed in the Armbian community and tested the Armbian Bookworn / Gnome distro and was amazed how smooth and good looking this is. The only problem i have is the lack of preinstalled Widevine support. I know (and also tested) that Raspberry OS does have DRM playback support trough Widevine. So it works with the latest 64bit Arm Linux Kernel, right ? So i even went and extracted the Widevine folder form the RpOS system.... Now, several days after i am clueless on how to install Widevine and make the Chcromium browser use it. Went trough a ton of content in the web but am not that advanced to do it myself. ( i have also tested a KDE plasma build that have this functionality already built in, but i really want to use the Armbian platform) Can someone help me trough the process ? 0 Quote
Bjoern12345 Posted October 26, 2024 Posted October 26, 2024 Hello, I wanted widivine in kodi, after some fails it found a solution. Maybe this helps you to get widevine working on arm aarch64 in web browser, too. First I used widevine-installer (needs squashfs-tools package) from here https://github.com/AsahiLinux/widevine-installer This should already work with chromium or firefox, didn't work in my case. I did not try further to solve web brower issue, cause I wanted to use kodi. I installed kodi via flatpak and setup widivine with inputstream-helper plugin. And again it failed and was not working 😞 Final solution was to copy libwidevinecdm.so created by widevine-installer (/var/lib/widevine/libwidevinecdm.so) to kodi cdm folder (/home/user/.var/app/tv.kodi.Kodi/data/cdm/libwidevinecdm.so) So should be possible to get widevine working in chrome or firefox, too !!! Good luck ! Bjoern 1 Quote
