Is it possible to turn off / on the voltage (5V) GPIO from the command line ? ....
So turn off eg 16x2 LCD power ....Is it possible only physically eg disconnecting the cable ( 2 , 4 - GPIO)
No, it is directly connected to power supply line. Which display do you have exactly? It is hard to suggest alternatives without knowing exact pinout.
When using the switch circuit, it's possible.
The switch circuit is possible by the photo switch or a transistor.
When the switch does a blue line, a backlight of LCD turns on /OFF.
