prajil Posted April 10, 2017 Posted April 10, 2017 hello friends, i am new here and also with orange pi zero. I'm using orange pi zero with Armbian_5.25_Orangepizero_Debian_jessie_default_3.4.113 image, it works fine, i made an mp3player with mplayer. The problem is that: the mplayer is paused when i press 'p' on keyboard, but it playing without audio out while press 'p' next time! please help me ...
prajil Posted April 13, 2017 Author Posted April 13, 2017 hello friends, i found my solution from the link below https://ubuntuforums.org/showthread.php?t=1889375 thanks
prajil Posted April 13, 2017 Author Posted April 13, 2017 And also there is an another problem occurred in 'orange pi zero' Arabian. i can't play two player at same time with single audio out. And also i found my solution from the link below https://ubuntuforums.org/showthread.php?t=1889375 thanks
RagnerBG Posted April 13, 2017 Posted April 13, 2017 11 hours ago, prajil said: And also there is an another problem occurred in 'orange pi zero' Arabian. i can't play two player at same time with single audio out. You basically can't do this with ALSA, without not very user-friendly solutions, like in your link. This is an old issue, long before i even touch Linux, for example. That's why there is Pulseaudio in modern Linux. Latest Desktop Armbian also have Pulseaudio, but you are using headless OpiZero and there is no Desktop image for it. But you can easily install pulseaudio in CLI version.
