OPUser Posted April 12, 2017 Posted April 12, 2017 Hello I have built Armbian new desktop image and SATA PMP patched kernel debs for OrangePi from the master branch on Ubuntu Xenial VBox host ./compile.sh PROGRESS_DISPLAY=plain FORCE_CHECKOUT="no" CREATE_PATCHES=yes\ BRANCH=default BOARD=orangepi KERNEL_ONLY=no RELEASE=jessie\ USE_GITHUB_UBOOT_MIRROR="yes" BUILD_DESKTOP=yes EXTERNAL_NEW=prebuilt and got this messages during kernel compilation HEAD detached at FETCH_HEAD nothing to commit, working directory clean [ warn ] Make your changes in this directory: [ /root/my_orangepi_kernel/sources/linux-sunxi/sunxi-3.4 ] [ warn ] Press <Enter> after you are done [ waiting ] [ warn ] No changes found, skipping patch creation fatal: ambiguous argument 'HEAD~': unknown revision or path not in the working tree. and include/linux/compiler-gcc.h:103:30: fatal error: linux/compiler-gcc5.h: No such file or directory I fixed the second one adding KERNEL_NEEDS_GCC='< 5.0' to /root/my_orangepi_kernel/lib/config/sources/sun7i.conf And at the end I got linux-image-3.4.104-sun7i_5.27_armhf.deb Few month ago I did same and I got 3.4.112 during the build. Is it the numbering issue or an effect of my kernel compilation error workaround? What can be the best way to fix that error? I had same error in the log during usb-redirector compilation: include/linux/compiler-gcc.h:103:30: fatal error: linux/compiler-gcc5.h: No such file or directory Thank you.
zador.blood.stained Posted April 12, 2017 Posted April 12, 2017 Using FORCE_CHECKOUT=no should be avoided, and this parameter may be reworked or removed in the future.
zador.blood.stained Posted April 12, 2017 Posted April 12, 2017 In fact all you needed to do is copy or symlink lib/patch/kernel/sun7i-default/port_multiplier.patch.disabled to userpatches/kernel/sun7i-default/port_multiplier.patch So no need to use FORCE_CHECKOUT and CREATE_PATCHES options.
OPUser Posted April 16, 2017 Author Posted April 16, 2017 I compiled jessie desktop image without use of FORCE_CHECKOUT but u-boot can't load kernel - it stops at "Starting Kernel..." message. kernel only compilation gave the same result. I decided to check if Ubuntu image from site works - it works but average load is too high, over 1.2. armbianmonitor -m shows 70% CPU load. But htop shows /sbin/init at 6% as a heaviest task. How can I check the rootcause?
