D Posted May 31 Share Posted May 31 Hi, I'm migrating from the OrangePi image to Armbian, and can't make the touchscreen working, it does not respond to any actions. It works pretty well on the OrangePi's image. Did I mess up something here? uname -a: Linux orangepizero2w 6.6.31-current-sunxi64 #1 SMP Fri May 17 10:02:40 UTC 2024 aarch64 GNU/Linux Touchscreen DTS: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target-path = "/"; __overlay__ { backlight_gpio: backlight_gpio { compatible = "gpio-backlight"; gpios = <&pio 8 14 0>; // PI14 default-on; }; /*backlight_pwm: backlight_pwm { compatible = "pwm-backlight"; brightness-levels = <0 25 50 75 100 125 150 175 200 225 255>; default-brightness-level = <6>; pwms = <&pwm 4 25000 0>; // PI14 pwm_names = "backlight"; status = "okay"; };*/ }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 5 0>; /*PH5=CS0 PH9=CS1*/ ili9341: ili9341@0 { compatible = "adafruit,yx240qv29", "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <48000000>; rotation = <270>; reset-gpios = <&pio 8 6 0>; /* PI6 */ dc-gpios = <&pio 7 4 0>; /* PH4 */ backlight = <&backlight_gpio>; }; ads7846: ads7846@0 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <2000000>; interrupts = <8 5 1>; /* PI5 - IRQ */ interrupt-parent = <&pio>; pendown-gpio = <&pio 8 5 0>; /* PI5 */ ti,swap-xy = <1>; ti,keep_vref_on = /bits/ 16 <1>; ti,x-min = /bits/ 16 <280>; ti,y-min = /bits/ 16 <350>; ti,x-max = /bits/ 16 <3850>; ti,y-max = /bits/ 16 <3850>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <255>; ti,x-plate-ohms = /bits/ 16 <133>; ti,debounce-max = /bits/ 16 <50>; ti,debounce-tol = /bits/ 16 <30>; ti,debounce-rep = /bits/ 16 <1>; wakeup-source; }; }; }; }; Xorg.0.log (fragment): [ 19.707] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0) [ 19.707] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall" [ 19.707] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 19.707] (II) LoadModule: "libinput" [ 19.708] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 19.733] (II) Module libinput: vendor="X.Org Foundation" [ 19.733] compiled for 1.21.1.3, module version = 1.2.1 [ 19.733] Module class: X.Org XInput Driver [ 19.733] ABI class: X.Org XInput driver, version 24.4 [ 19.733] (II) Using input driver 'libinput' for 'ADS7846 Touchscreen' [ 19.733] (**) ADS7846 Touchscreen: always reports core events [ 19.733] (**) Option "Device" "/dev/input/event0" [ 19.772] (II) event0 - ADS7846 Touchscreen: is tagged by udev as: Touchscreen [ 19.773] (II) event0 - ADS7846 Touchscreen: device is a touch device [ 19.773] (II) event0 - ADS7846 Touchscreen: device removed [ 19.824] (**) Option "config_info" "udev:/sys/devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input0/event0" [ 19.824] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6) [ 19.825] (**) Option "AccelerationScheme" "none" [ 19.825] (**) ADS7846 Touchscreen: (accel) selected scheme none/0 [ 19.825] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000 [ 19.825] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4 [ 19.828] (II) event0 - ADS7846 Touchscreen: is tagged by udev as: Touchscreen [ 19.829] (II) event0 - ADS7846 Touchscreen: device is a touch device [ 19.831] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0) [ 19.831] (**) ADS7846 Touchscreen: Applying InputClass "calibration" [ 19.831] (II) No input driver specified, ignoring this device. [ 19.831] (II) This device may have been added with another device file. [ 19.833] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 19.833] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 19.833] (II) Using input driver 'libinput' for 'sunxi-ir' [ 19.833] (**) sunxi-ir: always reports core events [ 19.833] (**) Option "Device" "/dev/input/event1" [ 19.836] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted September 17 Share Posted September 17 Hello I assume that the tft lcd is working 100%, displaying text and graphics. can you share what you get from the tests in my post here? also, what are your wiring connections? https://forum.armbian.com/topic/27457-connecting-banana-pi-m2-zero-with-ili9341-display-over-spi-on-latest-armbian-image/?do=findComment&comment=201947 Edit: your DTS seems to be missing a lot of connection definitions. Look at your DTS to the DTS that was posted last in my thread topic, and compare their structures. 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted 13 hours ago Share Posted 13 hours ago Did you ever solve your problem? 0 Quote Link to comment Share on other sites More sharing options...
