Hi.
i have two cheap TV boxes with rk3228a.
installed
armbian community 24.8.0 trunk 36 rk322x bookworm current 6.6.32 minimal img
and
loader "rk322x_loader_v1.10.238_256.bin"
using "rkdeveloptool"
with commands
rkdeveloptool db loadername.bin
rkdeveloptool wl 0x0 imagname.img
the first boot was fine and started normally.
when rebooted the device, it's just dead. only blue LED and blinking red LED. but nothing!
and the device wont go on Maskmod  to try another img or something!!
Edited by kuraimangetsu
spelling
If the board is not detected on your PC, try pressing the reset button behind the audio jack connector, and keeping it pressed for two seconds while giving power to the board and then try again with the male-to-male cable.
that what i did first, to install the img! but  now, it wont go on maskmod again
fixed my problem with maskmod
had to hold the RST button with the usb cable connected for 10sec [counted and tried for few times] to be able to enter it again!
the other problem
only the desktop version works!!
tried the minimal img
Armbian_community_24.8.0-trunk.6_Rk322x-box_bookworm_current_6.6.31_minimal.img.xz
 with no vail
only desktop ver works
Armbian_community_24.8.0-trunk.6_Rk322x-box_jammy_current_6.6.31_xfce_desktop.img.xz
Hello, both the versions you used share exactly the same kernel, so it is unclear to me the reason only the Jammy image boots.
Actually, I don't understand why you did not use the multitool to install the armbian image and doing maintenance, but however...
You can actually edit /boot/armbianEnv.txt and set verbosity=7 to have more kernel logging and perhaps something will pop up.
Hint: dmesg log is basic stuff to do debugging, if you can provide it, it could be very useful.
