Виктор Хомченко Posted June 7, 2024 Posted June 7, 2024 (edited) Hello everybody! I need help: I can't turn on the SPI interface in any way so that /dev/spidev0 or /dev/spidev1 appears. In armbian-config, there are generally only 7 lines in the hardware section, in which there is nothing interesting, an attempt to register spidev in armbianEnv.txt it also does not help, in dmesg and journalctl - silence... Where did the interface go? Edited June 7, 2024 by Виктор Хомченко 0 Quote
Виктор Хомченко Posted June 7, 2024 Author Posted June 7, 2024 (edited) root@proc01:/home/victor# cat /boot/armbianEnv.txt verbosity=1 extraargs=swiotlb=1024 overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb rootdev=UUID=cc500ad0-fef5-4af1-8ed7-68c3db5f4a19 rootfstype=ext4 console=serial overlay=spi-spidev param_spidev_spi_bus=1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u victor@proc01:~$ ls /dev/ | grep spi victor@proc01:~$ dmesg | grep spi victor@proc01:~$ Edited June 7, 2024 by Виктор Хомченко 0 Quote
Solution Виктор Хомченко Posted June 7, 2024 Author Solution Posted June 7, 2024 I answer myself: the overlays are here: https://github.com/radxa/overlays/tree/main You need to take the desired overlay, compile it using dtc and put it in the /boot/dtb/rockchip/overlay folder. Next, turn on the overlay in armbian-config and voila root@proc01:/home/victor# ls /dev/ | grep spi spidev1.0 0 Quote
solaris3308 Posted 2 hours ago Posted 2 hours ago Will you please give the detail step?I flash "Armbian 25.11.2 trixie" ,but I can't find any useful dtbo file. 0 Quote
