denprog Posted June 9, 2024 Posted June 9, 2024 Hello. I'm building an armbian image and want to add some partitions to the result disk. I use the post_create_partitions hook to do that. The documentation doesn't show how to use it, so I looked at the armbian's sources: https://github.com/armbian/build/blob/99815c0a8880d4e04fc64742412632e1d41c1334/lib/functions/image/partitioning.sh#L206 Here they create a string and pass it to sfdisk. In my hook I do a similar row to add two partitions: echo -ne "label:dos\nsize=1G\nsize=1G\n+\n" | sfdisk -a "${SDCARD}".raw --no-reread || exit_with_error "Partition fail." But building of the image fails with message: No free sectors available. Failed to add #3 partition: No space left on device. How to add partitions? 0 Quote
denprog Posted June 10, 2024 Author Posted June 10, 2024 Actually I have Orange Pi Zero2, not Zero... My command line is "./compile.sh BOARD=orangepizero2 BRANCH=current RELEASE=jammy KERNEL_CONFIGURE=no BUILD_DESKTOP=no BUILD_MINIMAL=yes ENABLE_EXTENSIONS=prepare_partitions". 0 Quote
anthony winner Posted June 17, 2024 Posted June 17, 2024 I have this in my userpatches/ extensions. It will create 4 partitions, RPICFG (~500mb) , armi_roota(2 /4 g), armi_rootb (2 /4 g), and armbi_data (the rest). I do this so I can use SWupdate to update the root fs as needed. Note: this currently works on a RasPi CM4, so some details may need to change for your board, likely in the boot partition. I also have code in the "firstBoot.sh that will stretch the data partition to the rest of the storage space. I also modify the root fs size if building for developer, due all the dev tools don't fit in 2g partition. # this will change the first root FS lable from "armbi_root" to "armbi_roota function pre_prepare_partitions__600_fix_rootfs_label() { display_alert "fix rootfs label" "${EXTENSION}" "info" ROOT_FS_LABEL="armbi_roota" } # this adds the 3rd and 4th partitions, as well as hooks in the userpatch partition hook function prepare_image_size__601_partition (){ display_alert "Adding partition function" "${EXTENSION}" "info" # this will allow the "CREATE_PARTITION_TABLE" function to be called declare -g USE_HOOK_FOR_PARTITION=yes local rootb_part=3 local data_part=4 } #This sets the partition sizes function prepare_image_size__600_image_size() { display_alert "partition size" "${EXTENSION}" "info" FIXED_IMAGE_SIZE=5000 local old_RFS=${rootfs_size} rootfs_size=2000 display_alert "devloper mode is >${DEVELOPER_MODE}<" "${EXTENSION}" "info" if [[ "$DEVELOPER_MODE" == "yes" ]]; then FIXED_IMAGE_SIZE=16000 rootfs_size=4000 display_alert "Developer extended rootfs_size is ${old_RFS}Mib, changeing to ${rootfs_size}MiB" "${EXTENSION}" "warning" else display_alert "Normal rootfs_size is ${old_RFS}Mib, changeing to ${rootfs_size}MiB" "${EXTENSION}" "info" fi } #this creates the new partition table function create_partition_table() { display_alert "Running partition function" "${EXTENSION}" "info" # stage: calculate partition size # local bootstart=$(($OFFSET * 2048)) # local rootstart=$(($bootstart + ($BOOTSIZE * 2048) )) # local bootend=$(($rootstart - 1)) # local rootstart2=$(($rootstart + ($rootfs_size * 2048) )) # local rootend=$(($rootstart2 - 1)) # local datastart2=$(($rootstart2 + ($rootfs_size * 2048) )) # local rootend2=$(($datastart - 1)) local next=$OFFSET # Create a script in a bracket shell, then pipe it to fdisk. { [[ "$IMAGE_PARTITION_TABLE" == "msdos" ]] && echo "label: dos" || echo "label: $IMAGE_PARTITION_TABLE" if [[ -n "$biospart" ]]; then # gpt: BIOS boot local type="21686148-6449-6E6F-744E-656564454649" echo "$biospart : name=\"bios\", start=${next}MiB, size=${BIOSSIZE}MiB, type=${type}" local next=$(($next + $BIOSSIZE)) fi if [[ -n "$uefipart" ]]; then # dos: EFI (FAT-12/16/32) # gpt: EFI System [[ "$IMAGE_PARTITION_TABLE" != "gpt" ]] && local type="ef" || local type="C12A7328-F81F-11D2-BA4B-00A0C93EC93B" echo "$uefipart : name=\"efi\", start=${next}MiB, size=${UEFISIZE}MiB, type=${type}" local next=$(($next + $UEFISIZE)) fi if [[ -n "$bootpart" ]]; then # Linux extended boot [[ "$IMAGE_PARTITION_TABLE" != "gpt" ]] && local type="ea" || local type="BC13C2FF-59E6-4262-A352-B275FD6F7172" if [[ -n "$rootpart" ]]; then echo "$bootpart : name=\"bootfs\", start=${next}MiB, size=${BOOTSIZE}MiB, type=${type}" local next=$(($next + $BOOTSIZE)) else # no `size` argument mean "as much as possible" echo "$bootpart : name=\"bootfs\", start=${next}MiB, type=${type}" fi fi # create main , and secondary root FS [[ "$IMAGE_PARTITION_TABLE" != "gpt" ]] && local type="83" || local type="0FC63DAF-8483-4772-8E79-3D69D8477DE4" echo "2 : name=\"rootfs_a\", start=${next}MiB, size=${rootfs_size}MiB, type=${type}" local next=$(($next + $rootfs_size)) echo "3 : name=\"rootfs_b\", start=${next}MiB, size=${rootfs_size}MiB, type=${type}" #and finally the data partition local next=$(($next + $rootfs_size)) echo "4 : name=\"data\", start=${next}MiB, type=${type}" } | run_host_command_logged sfdisk "${SDCARD}".raw || exit_with_error "Partition fail." } #this formats the 2 new partitons, and sets up the fstab file in the image function format_partitions__600_format_partitons() { display_alert "${EXTENSION} ${BOARD}" "format_partitions__600_format_partitons" "info" if [[ -n $rootpart ]]; then local rootdeviceb="${LOOP}p3" check_loop_device "${rootdeviceb}" display_alert "Creating second rootfs " "$ROOTFS_TYPE on 3" run_host_command_logged mkfs.${mkfs[$ROOTFS_TYPE]} ${mkopts[$ROOTFS_TYPE]} ${mkopts_label[$ROOTFS_TYPE]:+${mkopts_label[$ROOTFS_TYPE]}"armbi_rootb"} "${rootdeviceb}" [[ $ROOTFS_TYPE == ext4 ]] && run_host_command_logged tune2fs -o journal_data_writeback "${rootdeviceb}" if [[ $ROOTFS_TYPE == btrfs && $BTRFS_COMPRESSION != none ]]; then local fscreateopt="-o compress-force=${BTRFS_COMPRESSION}" fi wait_for_disk_sync "after mkfs" # force writes to be really flushed # store in readonly global for usage in later hooks rootb_part_uuid="$(blkid -s UUID -o value ${LOOP}p3)" declare -g -r ROOTB_PART_UUID="${rootb_part_uuid}" display_alert "Mounting root b fs" "$rootdevice (UUID=${ROOTB_PART_UUID})" mkdir -p "${MOUNT}/rfs_backup" run_host_command_logged mount ${fscreateopt} $rootdeviceb $MOUNT/rfs_backup # create fstab (and crypttab) entry local rootfsb if [[ $CRYPTROOT_ENABLE == yes ]]; then # map the LUKS container partition via its UUID to be the 'cryptroot' device echo "$ROOT_MAPPER UUID=${root_part_uuid} none luks" >> $SDCARD/etc/crypttab rootfsb=${rootdeviceb} # used in fstab else rootfsb="UUID=$(blkid -s UUID -o value ${rootdeviceb})" fi #ToDo: possibly remove the mount echo "$rootfsb /rfs_backup ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" echo "$rootfsb /rfs_backup ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" >> $SDCARD/etc/fstab local datadevice="${LOOP}p4" check_loop_device "${datadevice}" display_alert "Creating data rootfs " "$ROOTFS_TYPE on 4" run_host_command_logged mkfs.${mkfs[$ROOTFS_TYPE]} ${mkopts[$ROOTFS_TYPE]} ${mkopts_label[$ROOTFS_TYPE]:+${mkopts_label[$ROOTFS_TYPE]}"armbi_data"} "${datadevice}" [[ $ROOTFS_TYPE == ext4 ]] && run_host_command_logged tune2fs -o journal_data_writeback "${datadevice}" if [[ $ROOTFS_TYPE == btrfs && $BTRFS_COMPRESSION != none ]]; then local fscreateopt="-o compress-force=${BTRFS_COMPRESSION}" fi wait_for_disk_sync "after mkfs" # force writes to be really flushed display_alert "Mounting datafs" "$datadevice (UUID=${ROOT_PART_UUID})" mkdir -p "${MOUNT}/home" run_host_command_logged mount ${fscreateopt} $datadevice $MOUNT/home # store in readonly global for usage in later hooks data_part_uuid="$(blkid -s UUID -o value ${LOOP}p3)" declare -g -r DATA_PARTB_UUID="${data_part_uuid}" # create fstab (and crypttab) entry local datafs if [[ $CRYPTROOT_ENABLE == yes ]]; then # map the LUKS container partition via its UUID to be the 'cryptroot' device echo "$ROOT_MAPPER UUID=${ata_part_uuid} none luks" >> $SDCARD/etc/crypttab datafs=$datadevice # used in fstab else datafs="UUID=$(blkid -s UUID -o value $datadevice)" fi echo "$datafs /home ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" >> $SDCARD/etc/fstab fi # stage: create new fstab, with labels and not UUID rm -f $SDCARD/etc/fstab display_alert "${EXTENSION} ${BOARD}" "Adding comments to fstab" "info" echo "LABEL=armbi_roota / ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 1" >> $SDCARD/etc/fstab #echo "LABEL=armbi_rootb /rfs_backup ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" >> $SDCARD/etc/fstab echo "LABEL=armbi_data /home ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" >> $SDCARD/etc/fstab echo "tmpfs /tmp tmpfs defaults,nosuid 0 0" >> $SDCARD/etc/fstab echo "LABEL=RPICFG ${UEFI_MOUNT_POINT} vfat defaults 0 2" >> $SDCARD/etc/fstab } 0 Quote
denprog Posted June 20, 2024 Author Posted June 20, 2024 @anthony winner thanks a lot for sharing your script. One little thing I don't understand: echo "$datafs /home ${mkfs[$ROOTFS_TYPE]} defaults,noatime${mountopts[$ROOTFS_TYPE]} 0 2" >> $SDCARD/etc/fstab here $datafs will contains something like "/dev/loop19p2", but it should be a real partition name then the device runs. 0 Quote
anthony winner Posted June 20, 2024 Posted June 20, 2024 That came from some cut and paste code, and truth be told did not look at that section too hard. But the code just above it will set "datafs" as ether a uuid or some other depending if CRYPTROOT_ENABLE (I don't so did not test his path) is enabled. Also notice later I rewrite the fstab file completely to use labels and not uuid's, as in my workflow the UUID's might change as I do FS updates. 0 Quote
