Some of you probably saw that I added recently the OrangePi-Prime to the build process.
Unfortunately, I'm still struggling to get the WiFi.
It is even worst than the WiFi issue still present on OrangePiWin.
For the OrangePi-Prime, even the DT doesn't process the WiFi entries, and the mmc1 is still "disabled" in /proc/device-tree at boot time.
The strange thing is that if I load a small overlay to change the mmc1 status to "okay", the kernel start processing it.
But, unfortunately, I'm seeing "sunxi-mmc 1c10000.mmc: no support for card's volts" error, although I didn't found obvious errors in vqmmc-supply setting of mmc1.
I will have to dig further, but start running out of ideas ...
