nsc117 Posted April 27, 2017 Posted April 27, 2017 Hello everyone, First of all, sorry for my poor English. Quick description of my problem: I need to install OMV on Orange Pi Plus 2E's EMMC. At the beginning I used the image of the following URL: http://simplenas.com/download/other/orange-plus But it is clear that this image is prepared for Orange pi plus,I successfully installed this image to Orange Pi Plus 2E and successfully run on the TF card, but when I cloned image to the EMMC , it can not start. then i used the armbian image of the following URL: https://www.armbian.com/orange-pi-plus-2e/ i install OMV by apt-get,but webui failed to start after Reboot. at last I found a link in the OMV official forum : http://kaiser-edv.de/tmp/NumpU8/ But unfortunately this link does not contain image for Orange Pi Plus 2E EMMC I downloaded the image for orangepi zero, but it can not run on Orange Pi Plus 2E EMMC. Will armbian official can provide a OMV image for Orange Pi Plus 2E EMMC? thanks a lot! Sorry for my poor English again!
tkaiser Posted April 27, 2017 Posted April 27, 2017 Here you go https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card OMV_3_0_72_Orangepiplus2e_3.4.113.7z https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb This will only work with Etcher to burn the OS image and then nand-sata-install later to transfer to eMMC. And if you're finished please provide the output from 'sudo armbianmonitor -u' in this thread.
nsc117 Posted April 28, 2017 Author Posted April 28, 2017 Thanks for your help! I have successfully started image from EMMC under your guidance. The following is output from 'sudo armbianmonitor -u' root@orangepiplus2e:~# armbianmonitor -u Network/firewall problem detected. Please fix this or upload /var/log/armhwinfo.log manually. /var/log/armhwinfo.log has been uploaded to http://sprunge.us/YHNX
