moonshiner Posted June 27, 2024 Posted June 27, 2024 I built an image for the `orangepi-z-2w` via `./compile.sh build BOARD=orangepizero2w BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=bookworm`. The wifi connects (shows as active), however, I am unable to get on the internet (pinging results in `network is unreachable`, also can't ping the device itself). Am I building wrong? Thanks! Some notes: - I've been using `Armbian_24.2.6_Orangepizero2w_bookworm_current_6.6.28.img.xz` in the past (downloaded from armbian.com), and the wifi works just fine. 0 Quote
robertoj Posted September 4, 2024 Posted September 4, 2024 In “minimal” images, there’s no armbian-config to set up networking easily you need to configure it with netplan setting files. See https://docs.armbian.com/User-Guide_Networking/ and apt install wpasupplicant if you don’t have it 0 Quote
