External SD Card using SPI on Orange Pi Zero 2W
Hello,
I have connected a microSD module to the SPI1 CS0 pins
Is there a way to mount an SPI device? I tried, but I got this error: mount: /mnt/sdcard: /dev/spidev1.0 is not a block device.
What is the best way to easily manage files on this secondary SD card?
12 минут назад, kreestyahn сказал:
Can you publish the connection diagram of this device. What's in the brief?
15 минут назад, kreestyahn сказал:
First, you need to write an overlay for the DTS.
Compile it and add it to /boot/dtb*/overlay, and a line to load into armbianEnv.txt the file.
After that, the SD card will be automatically mounted as /dev/mmcblkXp1
I have created an sun50i-h616-spi-sd.dts:
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            status = "okay";
            mmc@0 {
                reg = <0>;
                compatible = "mmc-spi-slot";
                voltage-ranges = <3300 3300>;
                spi-max-frequency = <50000000>;
                status = "okay";
compiled it and added into /boot/dtb/allwinner/overlay
orangepiEnv.txt:
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun50i-h616
rootdev=UUID=6cd6cb54-48bc-4b6a-a615-2abfb7d74fe0
rootfstype=ext4
overlays=pi-i2c1 spi-sd
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
only the main SD is detected:
root@orangepizero2w:/ # ls /dev/mmc*
/dev/mmcblk1  /dev/mmcblk1p1
root@orangepizero2w:/ # dmesg | grep -i spi
dmesg | grep -i mmc
[    1.415702] spi-nor spi0.0: ZB25VQ128A (16384 Kbytes)
[    1.451348] mmc_spi spi1.0: SD/MMC host mmc0, no WP, no poweroff, cd polling
[    1.482498] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    1.482663] sunxi-mmc 4020000.mmc: Got CD GPIO
[    1.508525] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.546705] mmc1: host does not support reading read-only switch, assuming write-enable
[    1.548649] mmc1: new high speed SDHC card at address 0001
[    1.549859] mmcblk1: mmc1:0001 EITSD 7.50 GiB
[    1.552553]  mmcblk1: p1
[    1.712888] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.731008] mmc2: new high speed SDIO card at address 8800
[    3.149516] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none.
[    6.629778] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none.
Quote
I can't show you the physical connections because the orange pi is built into a custom board that I don't have access to right now, but the microSD module it connected to the SPI1-MOSI, -MISO, -CLK, -CS0 pins.
46 минут назад, kreestyahn сказал:
mmc@0 {
                reg = <0>;
Pins are recorded for the mmc0 node
dts/allwinner/sun50i-h616.dtsi#L275
bat
mmc0_pins:
Add fragment0: aliases
By analogy with this aliases
/omit-if-no-ref/ - This line says that they are missing from your dtb
Add fragment1:
spi1_pins:
			spi1_pins: spi1-pins {
				pins = "PH6", "PH7", "PH8";
				function = "spi1";
			spi1_cs0_pin: spi1-cs0-pin {
				pins = "PH5";
				function = "spi1";
Your fragment has now become the third. Add a description of the pins to it by analogy with this:
pinctrl-names
Like this?
/dts-v1/;
/plugin/;
    fragment@0 {
        target-path = "/aliases";
        __overlay__ {
            spi0 = "/soc/spi@5010000";
            spi1 = "/soc/spi@5011000";
    fragment@1 {
        target = <&spi1>;
        __overlay__ {
                function = "spi1";
                pins = "PH5";
                function = "spi1";
    fragment@2 {
        target = <&spi1>;
        __overlay__ {
            #size-cells = <0>;
            pinctrl-0 = <&spi1_pins>;
            pinctrl-names = "default", "default";
            status = "okay";
            mmc@0 {
                reg = <0>;
                status = "okay";
6 часов назад, kreestyahn сказал:
fragment@2 {
        target = <&spi1>;
        __overlay__ {
            #size-cells = <0>;
            status = "okay";
    fragment@2 {
        target = <&spi1>;
        __overlay__ {
            #size-cells = <0>;
            pinctrl-0 = <&spi1_pins>, <&spi1_cs0_pin>;
            status = "okay";
And try to experience
now it looks like this:I replaced the target = <&spi1>;  to target-path = </soc/spi@5011000>; because i got errors (Reference to non-existent node or label "spi1").
/dts-v1/;
        fragment@0 {
                __overlay__ {
        fragment@1 {
                target-path = "/soc/spi@5011000";
                __overlay__ {
                                pins = "PH6\0PH7\0PH8";
                                function = "spi1";
                                pins = "PH5";
                                function = "spi1";
        fragment@2 {
                __overlay__ {
                        #address-cells = <0x01>;
                        #size-cells = <0x00>;
                        pinctrl-names = "default\0default";
                        status = "okay";
                        mmc@0 {
                                reg = <0x00>;
                                voltage-ranges = <0xce4 0xce4>;
                                spi-max-frequency = <0x2faf080>;
                                status = "okay";
Now I could compile it without any error, but in /dev there is still only one mmcblk.
root@orangepizero2w:allwinner/overlay # dmesg | grep -i 'spi'
[    1.415511] spi-nor spi0.0: ZB25VQ128A (16384 Kbytes)
[   24.548702] platform 5011000.spi: deferred probe pending
Quote
The error disappears and the SPI1 pins' mode set back to ALT4 when only "spi1-cs0-spidev" overlay is enabled.
But if only "spi-sd" or both is enabled it set them back to "OFF" and the error appears.
@kreestyahn
Maybe start from the beginning.
Disable all overlays.
Download the OS.
On a running OS, extract the DTS:
dtc --sort -I fs -O dts  /sys/firmware/devicetree/base > dts-base.txt
Connect the overlay. Reboot.
On a running OS, the DTS is extracted to another file.
Compare.
