Fex Posted May 7, 2017 Posted May 7, 2017 While analog audio output (through the GPIO connector) works out of the box using the legacy kernel 3.4.113-sun7i, I could not get it to work with the stable kernel 4.9.12-sunxi. Since the driver is not activated in the stable kernel, I added the following to the dts: &codec { status = "okay"; }; This lead to the following `dmesg` output: sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok `aplay -l` gives: **** List of PLAYBACK Hardware Devices **** card 0: sun4icodec [sun4i-codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 However when I play back some audio file, no sound is generated. Also using the legacy kernel, there is a particular point during boot time, when the power line hum goes away. In the stable kernel this does not happen; the hum stays. Does anybody know to fix this?
Fex Posted May 8, 2017 Author Posted May 8, 2017 I found the solution: Unmute "Power Amplifier DAC" and "Power Amplifier Mute". Why those are muted per default is beyond me :-) See http://linux-sunxi.org/Audio_Codec
