kirant400 Posted July 20, 2024 Posted July 20, 2024 Hi, I am not able to make Radxa Camera 8M to work with Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img and Armbian_24.5.1_Radxa-zero3_noble_vendor_6.1.43.img gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/a2t/test.jpg Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Additional debug info: ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.001604801 Setting pipeline to NULL ... Freeing pipeline ... root@radxa-zero3:~# v4l2-ctl -i /dev/video0 --list-formats VIDIOC_S_INPUT: failed: Inappropriate ioctl for device ioctl: VIDIOC_ENUM_FMT Type: Video Capture Multiplanar [0]: 'UYVY' (UYVY 4:2:2) [1]: '422P' (Planar YUV 4:2:2) [2]: 'NV16' (Y/UV 4:2:2) [3]: 'NV61' (Y/VU 4:2:2) [4]: 'YM16' (Planar YUV 4:2:2 (N-C)) [5]: 'NV21' (Y/VU 4:2:0) [6]: 'NV12' (Y/UV 4:2:0) [7]: 'NM21' (Y/VU 4:2:0 (N-C)) [8]: 'NM12' (Y/UV 4:2:0 (N-C)) [9]: 'YU12' (Planar YUV 4:2:0) [10]: 'YM24' (Planar YUV 4:4:4 (N-C)) root@radxa-zero3:~# v4l2-ctl --device=/dev/video0 --all Driver Info: Driver name : rkisp_v5 Card type : rkisp_mainpath Bus info : platform:rkisp-vir0 Driver version : 2.4.0 Capabilities : 0x84201000 Video Capture Multiplanar Streaming Extended Pix Format Device Capabilities Device Caps : 0x04201000 Video Capture Multiplanar Streaming Extended Pix Format Media Driver Info: Driver name : rkisp-vir0 Model : rkisp0 Serial : Bus info : platform:rkisp-vir0 Media version : 6.1.43 Hardware revision: 0x00000000 (0) Driver version : 6.1.43 Interface Info: ID : 0x0300000e Type : V4L Video Entity Info: ID : 0x0000000d (13) Name : rkisp_mainpath Function : V4L2 I/O Pad 0x01000010 : 0: Sink Link 0x02000011: from remote pad 0x1000004 of entity 'rkisp-isp-subdev' (Unknown V4L2 Sub-Device): Data, Enabled Priority: 2 Format Video Capture Multiplanar: Width/Height : 0/0 Pixel Format : '' Field : Any Number of planes : 0 Flags : Colorspace : Default Transfer Function : Default YCbCr/HSV Encoding: Default Quantization : Default Selection Video Capture: crop, Left 0, Top 0, Width 0, Height 0, Flags: Selection Video Capture: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags: Selection Video Output: crop, Left 0, Top 0, Width 0, Height 0, Flags: Selection Video Output: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags: What should be done to get the image 0 Quote
Cronoses Posted August 19, 2024 Posted August 19, 2024 Same problem, at first I used DietPi OS but I got another error, no hardware recognition. I tried Radxa OS for Radxa Zero 3W but the CLI version is apparently buggy... And I finally arrived at the same point as you, same problem with the same configuration... # Setup the WiFi and SSH before flashing mkdir -p armbian_mount/boot armbian_mount/root sudo losetup -Pf Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img losetup -a sudo mount /dev/loop12p1 armbian_mount/boot sudo mount /dev/loop12p2 armbian_mount/root sudo touch armbian_mount/boot/ssh sudo nano armbian_mount/root/etc/netplan/10-dhcp-all-interfaces.yaml ``` network: version: 2 renderer: networkd ethernets: eth0: dhcp4: true optional: true wifis: wlan0: dhcp4: true optional: true access-points: "YOUR_WIFI_SSID": password: "YOUR_WIFI_PASSWORD" ``` sudo umount armbian_mount/boot sudo umount armbian_mount/root sudo losetup -d /dev/loop12 # This is my cmd (with Arch Linux) for flashing the OS on the eMMC sudo rkdeveloptool ld sudo rkdeveloptool db rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin sudo rkdeveloptool ef sudo rkdeveloptool wl 0 Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img sudo rkdeveloptool rd # Wait 5s and connect to your Radxa with SSH ssh root@YOUR_IP sudo apt-get upgrade && sudo apt-get update sudo apt-get install gstreamer1.0-tools gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly sudo apt-get install v4l-utils armbian-add-overlay radxa-zero3-rpi-camera-v2.dts sudo reboot # More info cmd/bug: gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/test.jpg ``` root@radxa-zero3:~# gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/test.jpg Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Additional debug info: ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.003362617 Setting pipeline to NULL ... Freeing pipeline ... ``` root@radxa-zero3:/home# gst-launch-1.0 v4l2src device=/dev/video0 ! fakesink ``` Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory. Additional debug info: ../sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Buffer pool activation failed ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Execution ended after 0:00:00.009337640 Additional debug info: ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Setting pipeline to NULL ... Freeing pipeline ... ``` root@radxa-zero3:/home# dmesg | grep video ``` videodev: Linux video capture interface: v2.00 mpp_service mpp-srv: 6849c1e28b7b author: Ding Wei 2023-12-28 video: rockchip: mpp: px30: fix issue combo_init when device probe usbcore: registered new interface driver uvcvideo rockchip-dmc dmc: video_4k_rate = 780000000 rockchip-dmc dmc: video_4k_10b_rate = 780000000 WARNING: CPU: 3 PID: 1673 at drivers/media/common/videobuf2/videobuf2-core.c:835 vb2_core_reqbufs+0x310/0x408 __video_do_ioctl+0x260/0x37c video_usercopy+0x2b8/0x5e4 video_ioctl2+0x20/0x30 ``` root@radxa-zero3:/home# dmesg | grep v4l2 ``` rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw! CPU: 3 PID: 1673 Comm: v4l2-ctl Not tainted 6.1.43-vendor-rk35xx #1 v4l2_ioctl+0x50/0x78 ``` root@radxa-zero3:/home# GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video0 ! fakesink ``` Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... 0:00:00.214107090 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:4675:gst_v4l2_object_probe_caps:<v4l2src0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument New clock: GstSystemClock 0:00:00.216999881 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:4485:gst_v4l2_object_get_crop_rect:<v4l2src0:src> Failed to get default crop rectangle with VIDIOC_G_SELECTION: Invalid argument 0:00:00.217261509 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:3228:gst_v4l2_object_reset_compose_region:<v4l2src0:src> Failed to get default compose rectangle with VIDIOC_G_SELECTION: Invalid argument 0:00:00.222463456 4321 0xaaaae4668400 WARN v4l2bufferpool gstv4l2bufferpool.c:848:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold 0:00:00.224169730 4321 0xaaaae4668400 ERROR v4l2bufferpool gstv4l2bufferpool.c:712:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool0:src> error with STREAMON 19 (No such device) 0:00:00.224277065 4321 0xaaaae4668400 ERROR bufferpool gstbufferpool.c:572:gst_buffer_pool_set_active:<v4l2src0:pool0:src> start failed 0:00:00.224536068 4321 0xaaaae4668400 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_decide_allocation:<v4l2src0> error: Failed to allocate required memory. 0:00:00.224573694 4321 0xaaaae4668400 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory. Additional debug info: ../sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Buffer pool activation failed 0:00:00.225619333 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3352:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation 0:00:00.225778585 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop:<v4l2src0> error: Internal data stream error. 0:00:00.225824378 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4) ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Execution ended after 0:00:00.012100543 Additional debug info: ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Setting pipeline to NULL ... Freeing pipeline ... ``` 0 Quote
Viktor Nikitin Posted November 12, 2024 Posted November 12, 2024 (edited) Did you manage to launch the camera? I used the following DTS Taken from here, But it hasn't worked out yet https://github.com/radxa-pkg/radxa-overlays/tree/main/arch/arm64/boot/dts/rockchip/overlays And loaded via sudo armbian-add-overlay /dts-v1/; /plugin/; / { metadata { title = "Enable Radxa Camera 8M 219"; compatible = "radxa,zero3"; category = "camera"; exclusive = "csi2_dphy0"; description = "Enable Radxa Camera 8M 219."; }; }; &{/} { clk_cam_24m: external-camera-clock-24m { status = "okay"; compatible = "fixed-clock"; clock-frequency = <24000000>; clock-output-names = "clk_cam_24m"; #clock-cells = <0>; }; camera_pwdn_gpio: camera-pwdn-gpio { status = "okay"; compatible = "regulator-fixed"; regulator-name = "camera_pwdn_gpio"; regulator-always-on; regulator-boot-on; enable-active-high; gpio = <&gpio3 22 0>; }; }; &i2c2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c2m1_xfer>; #address-cells = <1>; #size-cells = <0>; camera_imx219: camera-imx219@10 { status = "okay"; compatible = "sony,imx219"; reg = <0x10>; clocks = <&clk_cam_24m>; clock-names = "xvclk"; rockchip,camera-module-index = <0>; rockchip,camera-module-facing = "back"; rockchip,camera-module-name = "RADXA-CAMERA-8M"; rockchip,camera-module-lens-name = "default"; port { ucam_out0: endpoint { remote-endpoint = <&mipi_in_ucam0>; data-lanes = <1 2>; }; }; }; }; &csi2_dphy_hw { status = "okay"; }; &csi2_dphy0 { status = "okay"; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; #address-cells = <1>; #size-cells = <0>; mipi_in_ucam0: endpoint@1 { reg = <1>; remote-endpoint = <&ucam_out0>; data-lanes = <1 2>; }; }; port@1 { reg = <1>; #address-cells = <1>; #size-cells = <0>; dphy0_out: endpoint@1 { reg = <1>; remote-endpoint = <&isp0_in>; }; }; }; }; &rkisp_vir0 { status = "okay"; port { #address-cells = <1>; #size-cells = <0>; isp0_in: endpoint@0 { reg = <0>; remote-endpoint = <&dphy0_out>; }; }; }; &rkisp { status = "okay"; }; &rkisp_mmu { status = "okay"; }; &rkcif_mmu { status = "okay"; }; &rkcif { status = "okay"; }; Edited November 12, 2024 by Viktor Nikitin 0 Quote
Viktor Nikitin Posted December 14, 2024 Posted December 14, 2024 I think there is some error in the driver need to compare the source code from Radxa Debian B6 and Armbian Connect dtbo or compile dts for the desired camera (I tested both Raspberry camera V2 and Radxa 8M) enter the command (pre-install the v4l-utils package): media-ctl -d /dev/media0 -p -v in Debian b6 will be at the end of the command output: In Armbian it will be like this: Apparently, something was not initialized... 0 Quote
Morgan Kohler Posted October 24, 2025 Posted October 24, 2025 Hello, has anyone managed to get this camera to work on zero 3? 0 Quote
Karl Kopf Posted March 14 Posted March 14 I had similar issues with the original camera. But after days of testing even with the official radxa image I think I found the possible problem. There is a batch of boards with a wrong csi connector, the pins are not correct. I found it here: https://github.com/radxa-build/radxa-zero3/issues/15 I send a mail to my supplier and they will send me a fixed cable, I can give an update if it's fixed. 0 Quote
