RMG Posted July 24 Posted July 24 Hello all, did any body able to login to Cinnamon version (screen shot below from here ) ? The box is A95X F3 Air first edition. For me it Bootes well and after root and user passwords are set it shows up desktop login screen and then after user login the desktop simply goes blank. On reboot again user login screen appears on the desktop but again blank screen after login. On the other hand the Armbian 24.8.0-trunk.399 Bookworm Gnome worked fine. I don't want any troubleshooting or run through logs and spend time on this but if any body faced such issue before just reply back if this happened with your box as well. 0 Quote
