  On 9/2/2017 at 3:38 PM, digitalsuper8 said:
So here's a more detailed explanation for getting the Nanopi Neo Air to act as wifi accesspoint after boot.
I used the FergusL scripts for inspiration and for understanding the contents of the various conf files needed.
So after disabling hostapd and dnsmasq I wrote the following bash script, in the directory /usr/local/bin/. It's called neoaccesspoint.
sudo nano /usr/local/bin/neoaccesspoint
#!/bin/bash
PATH="$PATH:/usr/bin/"
case "$1" in
start)
# Assumption: NetworkManager systemd service is stopped and disabled
# Assumption: dnsmasq is disabled from startup
# Assumption: hostapd is disabled from startup
# We first have to bring wlan0 down
echo "Bringing wlan0 down"
ifdown wlan0
# Then remove the dhd module and load it again in operating mode 2
echo "removing module dhd and doing modprobe dhd op_mode2"
rmmod dhd
modprobe dhd op_mode=2
# we then have to bring wlan0 up again for it to get an IP address
echo "bringing wlan0 up again"
ifup wlan0
# We then bring up hostapd
echo "starting hostapd"
/bin/systemctl start hostapd
# And we start dnsmasq
echo "starting dnsmasq"
#/usr/sbin/dnsmasq
/bin/systemctl start dnsmasq
stop)
# type any commmand
echo "Stopping MyAP_Startup service: stopping dnsmasq and hostapd and bringing down wlan0"
/bin/systemctl stop hostapd
/bin/systemctl stop dnsmasq
ifdown wlan0
restart)
$0 stop
$0 start
esac
exit 0
Then I created a service file in /lib/systemd/system/
sudo nano /lib/systemd/system/neoairaccesspoint.service
the contents:
[Unit]
#This file has to be in /etc/systemd/system/
Description=Manage the neoairaccesspoint script
# Example After statement, this unit only starts after the speficied units are active
#After=syslog.target network.target
[Service]
#Type=forking
Type=oneshot
ExecStart=/usr/local/bin/neoairaccesspoint start
RemainAfterExit=true
ExecStop=/usr/local/bin/neoairaccesspoint stop
ExecReload=/usr/local/bin/neoairaccesspoint restart
# We probably don't want to specify the user here
#User=npi
[Install]
WantedBy=graphical.target
I enabled this service by the following commands:
sudo systemctl daemon-reload
sudo systemctl enable neoairaccesspoint.service
This should do it after reboot:
sudo systemctl reboot
Hope it works for you. Of course you have to have your conf files correct for:
hostapd.conf
dnsmasq.conf
and
/etc/network/interfaces
Expand
There is an error - service try to start /usr/local/bin/neoairaccesspoint, but file is named neoaccesspoint.
Also at Armbian 5.31 dnsmasq is not as service and must be started with /usr/sbin/dnsmasq. Becouse of that at stop must be killed process by ID dnsmasq like
kill -9 `cat /var/run/dnsmasq.pid`
Edited by Димитър Мазнеков
