jrd6g Posted July 31, 2024 Posted July 31, 2024 (edited) Hey Everyone, I'm sorry if this has been answered elsewhere. I recently purchased a Radxa Rock 5B+ and I installed the debian bookworm test build provided by radxa on there getting started page. https://docs.radxa.com/en/rock5/rock5b/getting-started/install-os/boot_from_sd_card https://github.com/radxa-build/rock-5b-plus-6_1/releases/download/rsdk-t4/rock-5b-plus-6_1_bookworm_kde_t4.output.img.xz I was mainly intent on using the HDMI with gstreamer using custom resolutions, but found that when using custom resolutions they cannot use the YCrCb pixel format only RGB8. It seems based on the following comment that RGB8 videoconvert hardware acceleration is missing from the default GPU drivers so one needs custom drivers. https://forum.radxa.com/t/hdmi-input-on-rock-5b/16242/4 https://forum.radxa.com/t/rk3588-kodi-rkmpp-accelerated-decoding-working-out-of-box/12785 Looking at the ppa they want you to add it seems like it only supports ubuntu and reading more they recommend you install armbian jammy on the rock 5B. I did find one github repo that appears to have the raw scripts related to rockchip-multimedia-config and a folder called debian https://github.com/amazingfate/rockchip-multimedia-config But looking at the files it seems like it relies on the device-tree files, which I feel may be different between the 5B and 5B+. So my two questions are 1) is there a working build of armbian ubuntu jammy or noble, that will install on the Rock 5B+ and work as well as it does for the Rock 5B. 2) Does anyone know if the rockchip-multimedia-config ppa with custom drivers will work on the Rock 5B+ ? Any other tips you all may have would be much appreciated. If I can provide any more details from my end just let me know. Edited July 31, 2024 by jrd6g grammatical errors 0 Quote
jrd6g Posted July 31, 2024 Author Posted July 31, 2024 (edited) I Just tried the "Ubuntu 24.04 (Noble)Gnometrunk MESA / VPUSHA ASC1.3GB" Image from "May 25, 2024" and it didn't work. https://dl.armbian.com/rock-5b/archive/Armbian_24.5.1_Rock-5b_noble_vendor_6.1.43_gnome-oibaf_desktop.img.xz EDIT: I also tried the latest nightly "Ubuntu 24.04 (Noble)Gnome MESA / VPUstable6.1.75SHA ASC1.4GB" and it gave me the same error "Blutooth: hc11: BCM: Reset failed (-110)" https://github.com/armbian/os/releases/download/24.8.0-trunk.488/Armbian_24.8.0-trunk.488_Rock-5b_noble_vendor_6.1.75_gnome-kisak_desktop.img.xz I guess I will need to wait for a 5B+ specific image. If you guys are beta testing one let me know where I can download it and I'll be happy to give it a go. Edited July 31, 2024 by jrd6g tested one other image and it didn't work 0 Quote
jrd6g Posted July 31, 2024 Author Posted July 31, 2024 Alternatively if there is no working armbian image planned for the 5B+, is there anyway to apply the same "rockchip-multimedia-config" path to the debian bookworm release for the 5B+? 0 Quote
NicoD Posted August 6, 2024 Posted August 6, 2024 Hi. I'm not sure if anyone has this 5B+. Might be there's a dtb file for it. You need to adjust /boot/armbianEnv.txt To point to a dtb that's for your device. I just don't know/think there's one yet for that. They make way too many versions of the same what makes supporting it all a hell. 1 Quote
jrd6g Posted August 6, 2024 Author Posted August 6, 2024 I got a reply on the radxa forum saying they should be sending a board to a maintainer and support should be added, they just don't know when. https://forum.radxa.com/t/armbian-the-best-option/14979/21 I agree there are so many of them it is impossible to keep up.... 0 Quote
hatsch Posted October 2, 2024 Posted October 2, 2024 On 7/31/2024 at 3:08 PM, jrd6g said: i just received my radxa rock 5b plus board. i'd like to run armbian on it. has anyone yet made progress on adding that board yet? i'd be happy to build and test. 1 Quote
jrd6g Posted October 2, 2024 Author Posted October 2, 2024 I haven't made any progress, if you can build an image and share it I'de be happy to help test as well. I just don't know how to build an image. 0 Quote
jrd6g Posted October 2, 2024 Author Posted October 2, 2024 Here was the thread I opened at the radxa forum where amazingfate gave me some links to prior github commits to support other radxa boads. https://forum.radxa.com/t/rock-5b-poor-hdmi-in-performance-with-bgr3-color-format-and-colorspace-conversion/22191/7 It might be worth looking at them if you run into difficulties. 0 Quote
NicoD Posted October 2, 2024 Posted October 2, 2024 @jrd6gBuilding your own images is easy to do. You need an x86 or arm64 device with Ubuntu 22.04/Armbian Jammy. Follow these 4 steps. apt-get -y -qq install git git clone --depth=1 --branch=main https://github.com/armbian/build cd build ./compile.sh https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
jrd6g Posted October 2, 2024 Author Posted October 2, 2024 (edited) Thanks I'll need to look into this more. I guess it will probably need a bunch of cross compilers and what not. Perhaps that's why they recommend using a VM or docker environment. Then I guess it's just a matter of adding the dtb, dts files like this (but the latest ones merged from the armbian repo and the rockchip repo for the rockpi 5b+). https://github.com/armbian/linux-rockchip/pull/129/files Then adding the csc board config file (seems they end in a ".conf" extension now unlike the original commit in this case that ended in ".csc"). https://github.com/armbian/build/pull/6551/files This seems to be the command to compile just the single board https://github.com/armbian/build/pull/6551 "./compile.sh BOARD=rock-5-itx BRANCH=vendor BUILD_DESKTOP=no BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=bookworm KERNEL_GIT=shallow" If anyone else wants to try to build it in the meantime though I'll be happy to test whatever pull request they might make. Personal Notes: Also unrelated (just putting these notes here for my own record to help me remember) but I need the legacy kernel support so I probably need to revert the changes made here for my own local build, unless there is a way to manually specify the "legacy" kernel when you build. https://github.com/armbian/build/commit/0bc5d27701286cca8a76820a0263b4d8a42b5b56 There's some interesting details on this pull request about the different build parameters that might let me specify LEGACY. https://github.com/armbian/build/pull/6881 "./compile.sh kernel BOARD=nanopi-r6s BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no RELEASE=trixie" So I think for my build what I will probably need is. "./compile.sh BOARD=rock-5b-plus BRANCH=legacy BUILD_DESKTOP=yes BUILD_MINIMAL=no DEB_COMPRESS=xz EXPERT=yes KERNEL_CONFIGURE=no RELEASE=jammy KERNEL_GIT=shallow" Edited October 2, 2024 by jrd6g 0 Quote
mmib Posted October 22, 2024 Posted October 22, 2024 hi, any update on this? Still see no 5b plus support on armbian 0 Quote
jrd6g Posted October 22, 2024 Author Posted October 22, 2024 Yeah sorry I'm too busy right now I don't think I'm going to be able to try to it any time soon. I see on my other thread you said something about needing a uboot boot config. I didn't get that far and don't have experience with uboot so I can't be of any assistance. You may want to post here too, incase someone on this forum knows more. 0 Quote
jrd6g Posted November 12, 2024 Author Posted November 12, 2024 Looks like meco has merged the rock 5b+ build scripts a week ago. https://forum.radxa.com/t/armbian-the-best-arm-framework/14979/33 I still haven't tried it but I am very thankful for him doing it! 0 Quote
Sławomir Gajowniczek Posted November 13, 2024 Posted November 13, 2024 @mmib What are you talking about ? I was able to run the Radxa 5B image fine with my 5+ sbc about 1mo ago. Today reinstalling on nvme.... 0 Quote
Sławomir Gajowniczek Posted November 13, 2024 Posted November 13, 2024 And I've tried with 6.10 and 6.1 kernels. However I'm stick to 6.1 because of the RNNK. 0 Quote
