Rob Latour Posted August 1, 2024 Posted August 1, 2024 (edited) I am running the current version of Armbian (and Open Media Vault) on a Raspberry Pi 5. Attached to it is a 2.5GB Ethernet adapter - this one in particular: https://www.amazon.ca/dp/B0CD1FDKT1 It lists as having a speed of 2500Mb/s but doesn't in practice: sudo ethtool enx6c1ff7045a00 Settings for enx6c1ff7045a00: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full 2500baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full 2500baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full 2500baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 2500Mb/s Duplex: Full Auto-negotiation: on Port: MII PHYAD: 32 Transceiver: internal Supports Wake-on: pumbg Wake-on: g Current message level: 0x00007fff (32767) drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol Link detected: yes However, I am getting less than 1GB data transfer speeds (tested with iPerf3) Accepted connection from 192.168.4.4, port 53760 [ 5] local 192.168.1.10 port 5201 connected to 192.168.4.4 port 53766 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 63.6 MBytes 529 Mbits/sec [ 5] 1.01-2.00 sec 63.5 MBytes 537 Mbits/sec [ 5] 2.00-3.01 sec 64.2 MBytes 536 Mbits/sec [ 5] 3.01-4.01 sec 63.6 MBytes 531 Mbits/sec [ 5] 4.01-5.02 sec 63.6 MBytes 532 Mbits/sec [ 5] 5.02-6.01 sec 63.0 MBytes 529 Mbits/sec [ 5] 6.01-7.01 sec 62.1 MBytes 521 Mbits/sec [ 5] 7.01-8.01 sec 63.8 MBytes 535 Mbits/sec [ 5] 8.01-9.01 sec 62.5 MBytes 527 Mbits/sec [ 5] 9.01-10.01 sec 63.8 MBytes 536 Mbits/sec [ 5] 10.01-10.01 sec 128 KBytes 466 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.01 sec 634 MBytes 531 Mbits/sec receiver (however, with another computer I get 2.5GB speed with the same iPerf3 server as was used for the above tests). The odd thing is that I believe last week I was getting much higher transfer speeds. I have done sudo updates, upgrades, dist-upgrades and OMV updates since then however. Suggestions on where to look, what to do to resolve would be appreciated. Edit: I tried replacing /etc/udev/rules.d/50-usb-realtek-net.rules with the contents of https://raw.githubusercontent.com/wget/realtek-r8152-linux/master/50-usb-realtek-net.rules and rebooting - but that did not help Edit 2: well that took me all day. I use OPNSense and had turned on Intrusion Detection with many rules. Seems as if it really bogged down the network traffic. I disabled it for testing and then suddenly I could get the expected though-put. Server listening on 5201 (test #20) ----------------------------------------------------------- Accepted connection from 192.168.4.4, port 33826 [ 5] local 192.168.1.10 port 5201 connected to 192.168.4.4 port 33832 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 279 MBytes 2.32 Gbits/sec [ 5] 1.01-2.00 sec 276 MBytes 2.33 Gbits/sec [ 5] 2.00-3.01 sec 280 MBytes 2.33 Gbits/sec [ 5] 3.01-4.01 sec 279 MBytes 2.33 Gbits/sec [ 5] 4.01-5.01 sec 275 MBytes 2.33 Gbits/sec [ 5] 5.01-6.00 sec 276 MBytes 2.33 Gbits/sec [ 5] 6.00-7.01 sec 280 MBytes 2.33 Gbits/sec [ 5] 7.01-8.00 sec 275 MBytes 2.33 Gbits/sec [ 5] 8.00-9.01 sec 280 MBytes 2.33 Gbits/sec [ 5] 9.01-10.00 sec 276 MBytes 2.33 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.00 sec 2.71 GBytes 2.33 Gbits/sec receiver Hope this will be of help to others. Edited August 2, 2024 by Rob Latour update info on things I've tried 0 Quote
