Posted (edited)
Hi all
Cannot make usable wol on my orange pi 5 plus.
Os: Armbian 24.5.1 Bookworm with Linux 6.1.75-vendor-rk35xx
WOL tested in magic or unicast settings or all flags enabled (phy, unicast, multicast, broadcast, arp, magic)
Test sending wol packets with running tcpdump -i enP3p49s0 '(udp and port 7) or (udp and port 9)'  show that orange pi successfully receive wol packets on speeds 1000 or even 10 mbps while powered on. But after sending orange pi to suspend or power off I cannot bring it online via  WOL. So I suppose network component outside orange pi is ok and it is something wrong with orange pi.
Any ideas?
Edited by dma
  • dma changed the title to Wake on lan (WOL) is not working on orange pi 5 plus
For me with an opi5+ with kernel 6.10.1 (edge) - ethtool reports
Supports Wake-on: pumbg
	Wake-on: d
but I was not able to wake up the opi5+ in freeze with either wakeonlan or ping.
Posted (edited)
I did that, but unfortunately no good either: either using wakeonlan to the MAC address or unicast to the IP address(+MAC) after changing to g.
I'll try a different armbian box on the weekend, running the vendor kernel rather than edge.
Edited by ozacas
extra comment
I was able to use the vendor kernel on the following armbian system, but not opi5+ (rk3588 vendor kernel tho')
acas@t6:~$ hostnamectl
 Static hostname: t6
       Icon name: computer
      Machine ID: 8a38793a5b9543f2a8467803940786e8
         Boot ID: bf966b42e4cb458f80e1ac5fad8d312b
Operating System: Armbian-unofficial 24.8.0-trunk noble
          Kernel: Linux 6.1.75-vendor-rk35xx
    Architecture: arm64
however, upon restore some filesystems (usb) were missing so it was not an indentical state prior to the suspend.
