Jose L Moffa Posted August 7, 2024 Posted August 7, 2024 Hello everyone, I'm currently working on a bananaPi M2S and trying to set up serial communication through the GPIO port on my device. I am using the provided overlay for UART-A. The overlay seems to work as it registers the serial device, as indicated by the dmesg output: bash [ 0.000277] printk: console [tty1] enabled [ 0.734433] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart [ 0.734458] printk: console [ttyAML0] enabled [ 0.735241] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 15, base_baud = 1500000) is a meson_uart [ 0.735395] serial serial0: tty port ttyAML6 registered [ 2.663304] systemd[1]: Created slice Slice /system/serial-getty. [ 3.140660] systemd[1]: Found device /dev/ttyAML0. However, the device /dev/ttyAML6 does not appear in the /dev folder. Here are the steps I've taken so far: Loaded the UART-A overlay. Verified registration through dmesg logs, which show that ttyAML6 is indeed registered. What I've checked: I ran ls /dev/ttyAML* and /dev/tty* but didn't find ttyAML6. Questions: Is there a known issue with this overlay or an additional step I'm missing to make the device node appear in /dev? Are there specific udev rules I need to add or modify to automatically create the device node? Any help or pointers would be greatly appreciated! Thank you in advance! 0 Quote
