sicxnull Posted August 11 Share Posted August 11 Currently working on a build for this device. It boots and is about 90% functional on 6.6 and 6.7 Kernel https://github.com/sicXnull/armbian-build/tree/X96Q-TVBOX-LPDDR3 Working - Desktop - Ethernet - Wifi Not working - DTS could use some work. Right now it does not detect internal EMMC so installing to EMMC is not an option. - Likely other things i've missed. I've uploaded two images to my git. Full w/Mate Desktop Minimal/Server Feel free to compile this yourself if you don't trust my images, it's encouraged. Changes are on the X96Q-TVBOX-LPDDR3 Branch Full W/Desktop ./compile.sh build BOARD=x96q-tvbox BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm Minimal/Server ./compile.sh build BOARD=x96q-tvbox BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm 1 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 19 Author Share Posted August 19 (edited) Update - PR Merged https://github.com/armbian/build/pull/7101 Please use the main repo to compile this. I'd edit the OG post but i cannot for some reason ./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm Edited August 20 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
svsruof Posted August 26 Share Posted August 26 How can I install this image on device? I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens. 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 26 Author Share Posted August 26 (edited) Quote How can I install this image on device? I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens. Power off unit. Burn to SD card, insert SD card, power on. You don't need to press the button in the AV port Your board looks different and has a different ramchip. I'm assuming it's not the LPDDR3 version but i could be wrong. Edited August 26 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
عبدالملك Posted August 27 Share Posted August 27 (edited) Sir, I want to ask you if I need a computer and how to install the system exactly? Edited August 27 by عبدالملك 0 Quote Link to comment Share on other sites More sharing options...
svsruof Posted August 28 Share Posted August 28 My device start with adnroid if i dont press the button 0 Quote Link to comment Share on other sites More sharing options...
bladyle Posted August 29 Share Posted August 29 Just tested your build and it working good. When I compiled with cinnamon there was a problem with cinnamon panels. I have noticed two problem only for now: - one of the usb ports don't work for me ( the one farther from sd card slot) - i have display flickering on 4k resolution, if lower resolution is selected no problem 0 Quote Link to comment Share on other sites More sharing options...
Ciremya_ Posted August 29 Share Posted August 29 Hello sicxnull, I've been following your topic since the beginning as I bought the same Android STB and have also been trying to run it on Linux since August 14th ! With termux on the stock android there seems to be 2Gb of RAM, but on your Armbian “Minimal/Server” build I'm getting down to 914Mb. On stock Android : total used free shared buffers Mem: 1.9G 907M 1.0G 6.4M 524K -/+ buffers/cache: 906M 1.0G Swap: 1.4G 138M 1.3G On your Armbian Build : Any clues about this gap? Is it because RAM is shared with graphics? cya~ 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 29 Author Share Posted August 29 (edited) 10 hours ago, bladyle said: Just tested your build and it working good. When I compiled with cinnamon there was a problem with cinnamon panels. I have noticed two problem only for now: - one of the usb ports don't work for me ( the one farther from sd card slot) - i have display flickering on 4k resolution, if lower resolution is selected no problem Confirmed on my end too, only 1 of the USB ports work. Ill take a look at the dts. I honestly only tested on 1080p monitor, so the 4k thing never came up for me, ill see what i can find out. I'm no pro with building DTB's, and it's my hope others can contribute to this box and make it perfect, but i'll continue to learn and contribute as time goes on. 5 hours ago, Ciremya_ said: Hello sicxnull, I've been following your topic since the beginning as I bought the same Android STB and have also been trying to run it on Linux since August 14th ! With termux on the stock android there seems to be 2Gb of RAM, but on your Armbian “Minimal/Server” build I'm getting down to 914Mb. On stock Android : total used free shared buffers Mem: 1.9G 907M 1.0G 6.4M 524K -/+ buffers/cache: 906M 1.0G Swap: 1.4G 138M 1.3G On your Armbian Build : Any clues about this gap? Is it because RAM is shared with graphics? cya~ Odd, i just fired up bookworm w/cinnamon. I will upload 24.11 6.6.44 to my repo or you can compile it yourself from the main armbian repo Edited August 29 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 1 Share Posted September 1 (edited) Hi sicxnull I was looking at your DTS.. why is ehci0 and ohci0 disabled? &ehci0 { + status = "disabled"; +&ohci0 { + status = "disabled"; +}; For your internel emmc you probably have to set the correct gpio. Check your original android DTS see if it's setting PF6 or another gpio PI16. cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ Also, if you install to emmc you might need this u-boot patch to boot armbian. Not sure if the H313/H616 has the same emmc boot problems as H618. https://github.com/NickAlilovic/build/blob/main/patch/u-boot/u-boot-sunxi/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch Edited September 2 by Nick A 1 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted September 2 Author Share Posted September 2 (edited) On 9/1/2024 at 4:29 PM, Nick A said: Hi sicxnull I was looking at your DTS.. why is ehci0 and ohci0 disabled? &ehci0 { + status = "disabled"; +&ohci0 { + status = "disabled"; +}; Honestly, i took the dtb from a OPi Zero3 (i think) so that was likely disabled by default. i believe enabling will fix the USB issue listed above (will test and fix if so). Still learning here when it comes to customizing the DTS. On 9/1/2024 at 4:29 PM, Nick A said: For your internel emmc you probably have to set the correct gpio. Check your original android DTS see if it's setting PF6 or another gpio PI16. cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ I will check this out, along with your other recommendations. Much appreciated! I opened this thread for feedback like this so the box can be 100% sometime in the future. Edited September 2 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 2 Share Posted September 2 (edited) H313/H616 is very similar to H618. If you read the H618 thread you might find some useful information. Edited September 3 by Nick A 0 Quote Link to comment Share on other sites More sharing options...
jschwart Posted Monday at 04:31 PM Share Posted Monday at 04:31 PM I understand that the device tries to boot from SD card if it sees one over the internal flash? The internal flash stays intact in that case? Is there a way to determine which X96-Q version one has without opening it up? Maybe though an adb shell? 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted Monday at 09:02 PM Author Share Posted Monday at 09:02 PM 4 hours ago, jschwart said: I understand that the device tries to boot from SD card if it sees one over the internal flash? The internal flash stays intact in that case? Yes it will boot from SD card first 4 hours ago, jschwart said: Is there a way to determine which X96-Q version one has without opening it up? Maybe though an adb shell? Easiest way os to just pop the cover off on the bottom, it's just held on by some clips and look at the board. 0 Quote Link to comment Share on other sites More sharing options...
zra123 Posted Tuesday at 07:15 AM Share Posted Tuesday at 07:15 AM Hello, I have X96Q 2\16 BA301-141 V5.1 DDR3L, miniarch starts and installs into memory, tried your images, according to uart it says, no ddr support. Help me start 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted Tuesday at 09:01 PM Author Share Posted Tuesday at 09:01 PM This image is for LPDDR3 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted 21 hours ago Share Posted 21 hours ago (edited) You need to edit these patches or create your own. Then add them to the armbian build. u-boot: https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/163-add-x96-q-ddr3-v5.1-defconfig.patch Linux Kernel: https://github.com/warpme/minimyth2/blob/master/script/kernel/linux-6.10/files/0651-arm64-dts-allwinner-h313-add-x96q-v5.1-TVbox.patch Edited 20 hours ago by Nick A 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 11 hours ago Author Share Posted 11 hours ago (edited) Been doing some digging the last few days and see that Miniarch has a fantastic setup for X96-q LPDDR3 so i ended up switching over to those DTS files with minimal changes needed USB and EMMC both work now. No Wifi on edge, but will look into that further. Installing to EMMC will break it, will look into this. https://github.com/armbian/build/pull/7276 Will upload some builds to my fork. Edited 3 hours ago by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted 2 hours ago Share Posted 2 hours ago Quote Installing to EMMC will break it, will look into this. Have you tried Miniarch's EMMC patch? https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 2 hours ago Author Share Posted 2 hours ago 1 minute ago, Nick A said: Have you tried Miniarch's EMMC patch? No, but i'm about to 😎 Thanks @Nick A! 0 Quote Link to comment Share on other sites More sharing options...
