sicxnull Posted August 11 Share Posted August 11 Currently working on a build for this device. It boots and is about 90% functional on 6.6 and 6.7 Kernel https://github.com/sicXnull/armbian-build/tree/X96Q-TVBOX-LPDDR3 Working - Desktop - Ethernet - Wifi Not working - DTS could use some work. Right now it does not detect internal EMMC so installing to EMMC is not an option. - Likely other things i've missed. I've uploaded two images to my git. Full w/Mate Desktop Minimal/Server Feel free to compile this yourself if you don't trust my images, it's encouraged. Changes are on the X96Q-TVBOX-LPDDR3 Branch Full W/Desktop ./compile.sh build BOARD=x96q-tvbox BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm Minimal/Server ./compile.sh build BOARD=x96q-tvbox BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm 1 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 19 Author Share Posted August 19 (edited) Update - PR Merged https://github.com/armbian/build/pull/7101 Please use the main repo to compile this. I'd edit the OG post but i cannot for some reason ./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm Edited August 20 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
svsruof Posted August 26 Share Posted August 26 How can I install this image on device? I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens. 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 26 Author Share Posted August 26 (edited) Quote How can I install this image on device? I recorded the image on an SD card, inserted it into the device, pressed the button in the AV input and turned on the power. The X96q splash screen appeared, quickly disappeared and nothing else happens. Power off unit. Burn to SD card, insert SD card, power on. You don't need to press the button in the AV port Your board looks different and has a different ramchip. I'm assuming it's not the LPDDR3 version but i could be wrong. Edited August 26 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
عبدالملك Posted August 27 Share Posted August 27 (edited) Sir, I want to ask you if I need a computer and how to install the system exactly? Edited August 27 by عبدالملك 0 Quote Link to comment Share on other sites More sharing options...
svsruof Posted August 28 Share Posted August 28 My device start with adnroid if i dont press the button 0 Quote Link to comment Share on other sites More sharing options...
bladyle Posted August 29 Share Posted August 29 Just tested your build and it working good. When I compiled with cinnamon there was a problem with cinnamon panels. I have noticed two problem only for now: - one of the usb ports don't work for me ( the one farther from sd card slot) - i have display flickering on 4k resolution, if lower resolution is selected no problem 0 Quote Link to comment Share on other sites More sharing options...
Ciremya_ Posted August 29 Share Posted August 29 Hello sicxnull, I've been following your topic since the beginning as I bought the same Android STB and have also been trying to run it on Linux since August 14th ! With termux on the stock android there seems to be 2Gb of RAM, but on your Armbian “Minimal/Server” build I'm getting down to 914Mb. On stock Android : total used free shared buffers Mem: 1.9G 907M 1.0G 6.4M 524K -/+ buffers/cache: 906M 1.0G Swap: 1.4G 138M 1.3G On your Armbian Build : Any clues about this gap? Is it because RAM is shared with graphics? cya~ 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted August 29 Author Share Posted August 29 (edited) 10 hours ago, bladyle said: Just tested your build and it working good. When I compiled with cinnamon there was a problem with cinnamon panels. I have noticed two problem only for now: - one of the usb ports don't work for me ( the one farther from sd card slot) - i have display flickering on 4k resolution, if lower resolution is selected no problem Confirmed on my end too, only 1 of the USB ports work. Ill take a look at the dts. I honestly only tested on 1080p monitor, so the 4k thing never came up for me, ill see what i can find out. I'm no pro with building DTB's, and it's my hope others can contribute to this box and make it perfect, but i'll continue to learn and contribute as time goes on. 5 hours ago, Ciremya_ said: Hello sicxnull, I've been following your topic since the beginning as I bought the same Android STB and have also been trying to run it on Linux since August 14th ! With termux on the stock android there seems to be 2Gb of RAM, but on your Armbian “Minimal/Server” build I'm getting down to 914Mb. On stock Android : total used free shared buffers Mem: 1.9G 907M 1.0G 6.4M 524K -/+ buffers/cache: 906M 1.0G Swap: 1.4G 138M 1.3G On your Armbian Build : Any clues about this gap? Is it because RAM is shared with graphics? cya~ Odd, i just fired up bookworm w/cinnamon. I will upload 24.11 6.6.44 to my repo or you can compile it yourself from the main armbian repo Edited August 29 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 1 Share Posted September 1 (edited) Hi sicxnull I was looking at your DTS.. why is ehci0 and ohci0 disabled? &ehci0 { + status = "disabled"; +&ohci0 { + status = "disabled"; +}; For your internel emmc you probably have to set the correct gpio. Check your original android DTS see if it's setting PF6 or another gpio PI16. cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ Also, if you install to emmc you might need this u-boot patch to boot armbian. Not sure if the H313/H616 has the same emmc boot problems as H618. https://github.com/NickAlilovic/build/blob/main/patch/u-boot/u-boot-sunxi/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch Edited September 2 by Nick A 1 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted September 2 Author Share Posted September 2 (edited) On 9/1/2024 at 4:29 PM, Nick A said: Hi sicxnull I was looking at your DTS.. why is ehci0 and ohci0 disabled? &ehci0 { + status = "disabled"; +&ohci0 { + status = "disabled"; +}; Honestly, i took the dtb from a OPi Zero3 (i think) so that was likely disabled by default. i believe enabling will fix the USB issue listed above (will test and fix if so). Still learning here when it comes to customizing the DTS. On 9/1/2024 at 4:29 PM, Nick A said: For your internel emmc you probably have to set the correct gpio. Check your original android DTS see if it's setting PF6 or another gpio PI16. cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ I will check this out, along with your other recommendations. Much appreciated! I opened this thread for feedback like this so the box can be 100% sometime in the future. Edited September 2 by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 2 Share Posted September 2 (edited) H313/H616 is very similar to H618. If you read the H618 thread you might find some useful information. Edited September 3 by Nick A 0 Quote Link to comment Share on other sites More sharing options...
jschwart Posted Monday at 04:31 PM Share Posted Monday at 04:31 PM I understand that the device tries to boot from SD card if it sees one over the internal flash? The internal flash stays intact in that case? Is there a way to determine which X96-Q version one has without opening it up? Maybe though an adb shell? 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted Monday at 09:02 PM Author Share Posted Monday at 09:02 PM 4 hours ago, jschwart said: I understand that the device tries to boot from SD card if it sees one over the internal flash? The internal flash stays intact in that case? Yes it will boot from SD card first 4 hours ago, jschwart said: Is there a way to determine which X96-Q version one has without opening it up? Maybe though an adb shell? Easiest way os to just pop the cover off on the bottom, it's just held on by some clips and look at the board. 0 Quote Link to comment Share on other sites More sharing options...
zra123 Posted Tuesday at 07:15 AM Share Posted Tuesday at 07:15 AM Hello, I have X96Q 2\16 BA301-141 V5.1 DDR3L, miniarch starts and installs into memory, tried your images, according to uart it says, no ddr support. Help me start 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted Tuesday at 09:01 PM Author Share Posted Tuesday at 09:01 PM This image is for LPDDR3 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted yesterday at 04:49 AM Share Posted yesterday at 04:49 AM (edited) You need to edit these patches or create your own. Then add them to the armbian build. u-boot: https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/163-add-x96-q-ddr3-v5.1-defconfig.patch Linux Kernel: https://github.com/warpme/minimyth2/blob/master/script/kernel/linux-6.10/files/0651-arm64-dts-allwinner-h313-add-x96q-v5.1-TVbox.patch Edited yesterday at 05:22 AM by Nick A 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted yesterday at 02:54 PM Author Share Posted yesterday at 02:54 PM (edited) Been doing some digging the last few days and see that Miniarch has a fantastic setup for X96-q LPDDR3 so i ended up switching over to those DTS files with minimal changes needed USB and EMMC both work now. No Wifi on edge, but will look into that further. Installing to EMMC will break it, will look into this. https://github.com/armbian/build/pull/7276 Will upload some builds to my fork. Edited yesterday at 10:33 PM by sicxnull 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted yesterday at 11:21 PM Share Posted yesterday at 11:21 PM Quote Installing to EMMC will break it, will look into this. Have you tried Miniarch's EMMC patch? https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted yesterday at 11:22 PM Author Share Posted yesterday at 11:22 PM 1 minute ago, Nick A said: Have you tried Miniarch's EMMC patch? No, but i'm about to 😎 Thanks @Nick A! 0 Quote Link to comment Share on other sites More sharing options...
going Posted 11 hours ago Share Posted 11 hours ago 12 часов назад, Nick A сказал: Have you tried Miniarch's EMMC patch? https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch This is a bad patch. The problem is different. 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted 9 hours ago Share Posted 9 hours ago Do you have any info on what the problem might be? 1 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 6 hours ago Author Share Posted 6 hours ago 2 hours ago, Nick A said: Do you have any info on what the problem might be? yes, any feedback you have @going would be great. This board is like 95% ready to go at this point. solving EMMC boot would be huge 0 Quote Link to comment Share on other sites More sharing options...
bladyle Posted 5 hours ago Share Posted 5 hours ago Quote Been doing some digging the last few days and see that Miniarch has a fantastic setup for X96-q LPDDR3 so i ended up switching over to those DTS files with minimal changes needed USB and EMMC both work now. No Wifi on edge, but will look into that further. Sound good. Will wait to upload some builds to test them although i need wifi so need stable kernel I guess. 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 5 hours ago Author Share Posted 5 hours ago 2 minutes ago, bladyle said: Sound good. Will wait to upload some builds to test them although i need wifi so need stable kernel I guess. Should have some up tonight. 0 Quote Link to comment Share on other sites More sharing options...
going Posted 5 hours ago Share Posted 5 hours ago 23 часа назад, sicxnull сказал: Installing to EMMC will break it, will look into this. https://github.com/armbian/build/pull/7276 You are incorrectly adding patches to the build system. Patches should be extracted using the "git format-patch" command and should contain small explanations of what and for what reason these changes were made. You should not add the patch somewhere in the middle of the series list. This can lead to subsequent patches being applied incorrectly and becoming inapplicable. As a result, we get a compilation error at best, or incorrectly compiled code at worst. 0 Quote Link to comment Share on other sites More sharing options...
going Posted 5 hours ago Share Posted 5 hours ago 1 час назад, sicxnull сказал: 3 часа назад, Nick A сказал: Do you have any info on what the problem might be? yes, any feedback you have @going would be great. This board is like 95% ready to go at this point. solving EMMC boot would be huge CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x40 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 This should be present in the default configuration for the device. And please post the UART output if possible. If that's not possible, then I won't be able to help. 0 Quote Link to comment Share on other sites More sharing options...
going Posted 5 hours ago Share Posted 5 hours ago 18 часов назад, Nick A сказал: Have you tried Miniarch's EMMC patch? https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/107-sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch This patch is bad. It changes the general code and has an impact on other devices. Armbian cannot afford such behavior. I apologize for the short remark. Most likely, the TV set-top box already has a boot code in eMMC on the boot0 partition. This prevents the Armbian code, which is located on the first main section, from running. 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 4 hours ago Author Share Posted 4 hours ago 34 minutes ago, going said: You are incorrectly adding patches to the build system. Patches should be extracted using the "git format-patch" command and should contain small explanations of what and for what reason these changes were made. You should not add the patch somewhere in the middle of the series list. This can lead to subsequent patches being applied incorrectly and becoming inapplicable. As a result, we get a compilation error at best, or incorrectly compiled code at worst. okay. thanks for the feedback. 0 Quote Link to comment Share on other sites More sharing options...
sicxnull Posted 4 hours ago Author Share Posted 4 hours ago 19 minutes ago, going said: Most likely, the TV set-top box already has a boot code in eMMC on the boot0 partition. This prevents the Armbian code, which is located on the first main section, from running. Nope. Miniarch installs to EMMC fine. Either way, i'll figure it out. 0 Quote Link to comment Share on other sites More sharing options...
