HDMI output (on UHD-monitor)
Slackstick
Hello,
installed nightly image on OPI PC 2. I get a black monitor saying "no signal" and screen is black. But it does not go into sleep mode.
Dmesg output is :
[    1.273359] simple-framebuffer 7e05c000.framebuffer: framebuffer at 0x7e05c000, 0x1fa4000 bytes, mapped to 0xffff00000a000000
[    1.273367] simple-framebuffer 7e05c000.framebuffer: format=x8r8g8b8, mode=3840x2160x32, linelength=15360
[    1.420280] Console: switching to colour frame buffer device 480x135
[    1.566153] simple-framebuffer 7e05c000.framebuffer: fb0: simplefb registered!
AFAIK simple-framebuffer uses a framebuffer already initialized by the bootloader. So I suppose parameters between both don't match.
Same problem with OPI PC and mainline.
Is there a way to get hdmi output?
Thanks.
Which kernel and u-boot version? OPi PC2 uses an old u-boot and it will be 1.5-2 months before we switch to a new one with a supported display driver.
Display driver in u-boot 2017.05 had all known issues fixed already so it should work.
Welcome message for PC2 is:
Welcome to ARMBIAN 5.27.170529 nightly Ubuntu 16.04.2 LTS 4.11.1-sun50iw2
Kernel is:
Linux orangepipc2 4.11.1-sun50iw2 #29 SMP Sun May 28 03:59:44 CEST 2017 aarch64 aarch64 aarch64 GNU/Linux
Don't know how to get u-boot version, but install is from nightly 170529.
BTW, crappy OPi distribution showed a picture, so hardware should be o.k.
