robertoj Posted August 25 Share Posted August 25 I am experimenting with a cheap ILI9341 screen and mi OrangePi Zero LTS https://www.aliexpress.us/item/2251832431328471.html I found these recent instructions to be able to display graphics here: https://ryjelsum.me/homelab/xpt2046-ili9341-opi-zero/ with a reference to a previous experience (without mentioning success) https://hackaday.io/project/190371-g-edm/log/217902-first-success-with-armbian-nanopi-and-ili9341-touch and independently, I found these instructions and experiences here: https://docs.armbian.com/User-Guide_Allwinner_overlays/ https://forum.armbian.com/topic/27457-connecting-banana-pi-m2-zero-with-ili9341-display-over-spi-on-latest-armbian-image/ <-just found it and it has some success with BananaPi M2 Zero https://tech-de.netlify.app/articles/de547180/index.html https://4pda.to/forum/index.php?showtopic=782242&st=5060#entry112401076 I connected with wires as shown in instructions: https://forum.armbian.com/topic/28674-text-version-of-orange-pi-zero-pinout/ And the LCD's LED input pin to 3.3V I activated the spi-add-cs1 overlay in arbian-config I copied the dts for opiZ into ~/ili9341/ili9341-touch-double-spi-cs.dts Then, I executed: cd ili9341 armbian-add-overlay ili9341-touch-double-spi-cs.dts Then, I rebooted, and my LCD just looks gray. My armbianEnv looks like this: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=spi-add-cs1 tve usbhost2 usbhost3 rootdev=UUID=7d9a7016-73db-4f9c-a5bd-e3e5ab53ffc4 rootfstype=ext4 user_overlays=ili9341-touch-double-spi-cs usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u my armbianmonitor -u: https://paste.armbian.com/arogurekiv I am still not done checking against the experiences with Bpi M2-0, but I ask here: anyone has experience with ILI9341+XPT2046, in either OrangePi Zero or Zero 3? Should I downgrade to Linux 6.1.53? 1 Quote Link to comment Share on other sites More sharing options...
robertoj Posted September 3 Author Share Posted September 3 Just to keep track of my progress: OrangePi Zero can drive a ILI9341, with this ili9341-spi1.dts, with the fb_ili9341.ko driver (not the drm driver). Works on Linux 6.1.104 and Linux 6.6.44 Pin connections inside the DTS code: Spoiler /* OrangePi Zero -> ILI9341 LCD connections SPI CLOCK = PA14 SPI DO (LCD MISO) = PA16 (OPIZ MISO) SPI DI (LCD MOSI) = PA15 (OPIZ MOSI) LCD DATA/CONTROL = PA18 LCD RESET = PA2 CHIP SELECT = PA13 VCC = 3.3V PIN GND = GND PIN */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PA18", "PA2"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 0 13 0>; /* PA13 chip select */ num-chipselects = <1>; display: display@0 { /*compatible = "adafruit,yx240qv29","ilitek,ili9341";*/ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <40000000>; rotate = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 0 2 1>; /* PA2 reset pin*/ dc-gpios = <&pio 0 18 0>; /* PA18 Data control pin */ debug = <3>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; and this armbianEnv.txt Spoiler verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 rootdev=UUID=677917ab-5341-4634-b556-aafaeaa83c52 rootfstype=ext4 user_overlays=ili9341-spi1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 1 Quote Link to comment Share on other sites More sharing options...
robertoj Posted September 4 Author Share Posted September 4 Investigating why fb_ili9341 works but ili9341 does not. With this ili9341-spi1.dts, fb_ili9341 gets loaded and TFT shows images perfectly Spoiler /* OrangePi Zero -> ILI9341 LCD connections SPI CLOCK = PA14 SPI DO (LCD MISO) = PA16 (OPIZ MISO) SPI DI (LCD MOSI) = PA15 (OPIZ MOSI) LCD DATA/CONTROL = PA18 LCD RESET = PA2 CHIP SELECT = PA13 VCC = 3.3V PIN GND = GND PIN */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PA18", "PA2"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 0 13 0>; /* PA13 chip select */ num-chipselects = <1>; display: display@0 { /*compatible = "adafruit,yx240qv29","ilitek,ili9341";*/ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <40000000>; rotate = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 0 2 1>; /* PA2 reset pin*/ dc-gpios = <&pio 0 18 0>; /* PA18 Data control pin */ debug = <3>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; here's the armbian-monitor -u result https://paste.armbian.com/vimetexiqe Other results in this successful DTS: Spoiler roberto@orangepizero:~$ lsmod |grep ili fb_ili9341 12288 1 fbtft 36864 1 fb_ili9341 roberto@orangepizero:~$ sudo cat /proc/device-tree/soc/spi@1c69000/status okay roberto@orangepizerosudo cat /sys/kernel/debug/pinctrl/1c20800.pinctrl/pinmux-pinspins Pinmux settings per pin Format: pin (name): mux_owner gpio_owner hog? pin 0 (PA0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 1 (PA1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 2 (PA2): (MUX UNCLAIMED) 1c20800.pinctrl:2 pin 3 (PA3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 4 (PA4): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA4 pin 5 (PA5): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA5 pin 6 (PA6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 7 (PA7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 8 (PA8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 9 (PA9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 10 (PA10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 11 (PA11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 12 (PA12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 13 (PA13): 1c69000.spi 1c20800.pinctrl:13 function spi1 group PA13 pin 14 (PA14): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA14 pin 15 (PA15): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA15 pin 16 (PA16): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA16 pin 17 (PA17): (MUX UNCLAIMED) 1c20800.pinctrl:17 pin 18 (PA18): (MUX UNCLAIMED) 1c20800.pinctrl:18 pin 19 (PA19): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 20 (PA20): (MUX UNCLAIMED) 1c20800.pinctrl:20 pin 21 (PA21): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 64 (PC0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 65 (PC1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 66 (PC2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 67 (PC3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 68 (PC4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 69 (PC5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 70 (PC6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 71 (PC7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 72 (PC8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 73 (PC9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 74 (PC10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 75 (PC11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 76 (PC12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 77 (PC13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 78 (PC14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 79 (PC15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 80 (PC16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 96 (PD0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 97 (PD1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 98 (PD2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 99 (PD3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 100 (PD4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 101 (PD5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 102 (PD6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 103 (PD7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 104 (PD8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 105 (PD9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 106 (PD10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 107 (PD11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 108 (PD12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 109 (PD13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 110 (PD14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 111 (PD15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 112 (PD16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 113 (PD17): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 128 (PE0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 129 (PE1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 130 (PE2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 131 (PE3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 132 (PE4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 133 (PE5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 134 (PE6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 135 (PE7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 136 (PE8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 137 (PE9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 138 (PE10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 139 (PE11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 140 (PE12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 141 (PE13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 142 (PE14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 143 (PE15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 160 (PF0): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF0 pin 161 (PF1): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF1 pin 162 (PF2): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF2 pin 163 (PF3): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF3 pin 164 (PF4): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF4 pin 165 (PF5): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF5 pin 166 (PF6): (MUX UNCLAIMED) 1c20800.pinctrl:166 pin 192 (PG0): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG0 pin 193 (PG1): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG1 pin 194 (PG2): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG2 pin 195 (PG3): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG3 pin 196 (PG4): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG4 pin 197 (PG5): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG5 pin 198 (PG6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 199 (PG7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 200 (PG8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 201 (PG9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 202 (PG10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 203 (PG11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 204 (PG12): (MUX UNCLAIMED) 1c20800.pinctrl:204 pin 205 (PG13): (MUX UNCLAIMED) (GPIO UNCLAIMED) When I change the DTS to (notice the differences in compatible and rotate/rotation lines) Spoiler /* OrangePi Zero -> ILI9341 LCD connections SPI CLOCK = PA14 SPI DO (LCD MISO) = PA16 (OPIZ MISO) SPI DI (LCD MOSI) = PA15 (OPIZ MOSI) LCD DATA/CONTROL = PA18 LCD RESET = PA2 CHIP SELECT = PA13 VCC = 3.3V PIN GND = GND PIN */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PA18", "PA2"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 0 13 0>; /* PA13 chip select */ num-chipselects = <1>; display: display@0 { compatible = "adafruit,yx240qv29","ilitek,ili9341"; /*compatible = "ilitek,ili9341";*/ reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <40000000>; rotation = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 0 2 1>; /* PA2 reset pin*/ dc-gpios = <&pio 0 18 0>; /* PA18 Data control pin */ debug = <3>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; The TFT remains 100% white. Here's the armbianmonitor -u: https://paste.armbian.com/segulokeso Other tests in this failed attempt: Spoiler roberto@orangepizero:~$ sudo cat /proc/device-tree/soc/spi@1c69000/status okay roberto@orangepizero:~$ lsmod|grep ili ili9341 12288 0 panel_ilitek_ili9341 16384 0 drm_mipi_dbi 20480 2 ili9341,panel_ilitek_ili9341 oberto@orangepizero:~$ sudo cat /sys/kernel/debug/pinctrl/1c20800.pinctrl/pinmux-pins Pinmux settings per pin Format: pin (name): mux_owner gpio_owner hog? pin 0 (PA0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 1 (PA1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 2 (PA2): (MUX UNCLAIMED) 1c20800.pinctrl:2 pin 3 (PA3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 4 (PA4): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA4 pin 5 (PA5): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA5 pin 6 (PA6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 7 (PA7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 8 (PA8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 9 (PA9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 10 (PA10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 11 (PA11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 12 (PA12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 13 (PA13): 1c69000.spi 1c20800.pinctrl:13 function spi1 group PA13 pin 14 (PA14): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA14 pin 15 (PA15): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA15 pin 16 (PA16): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA16 pin 17 (PA17): (MUX UNCLAIMED) 1c20800.pinctrl:17 pin 18 (PA18): (MUX UNCLAIMED) 1c20800.pinctrl:18 pin 19 (PA19): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 20 (PA20): (MUX UNCLAIMED) 1c20800.pinctrl:20 pin 21 (PA21): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 64 (PC0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 65 (PC1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 66 (PC2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 67 (PC3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 68 (PC4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 69 (PC5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 70 (PC6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 71 (PC7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 72 (PC8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 73 (PC9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 74 (PC10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 75 (PC11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 76 (PC12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 77 (PC13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 78 (PC14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 79 (PC15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 80 (PC16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 96 (PD0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 97 (PD1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 98 (PD2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 99 (PD3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 100 (PD4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 101 (PD5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 102 (PD6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 103 (PD7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 104 (PD8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 105 (PD9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 106 (PD10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 107 (PD11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 108 (PD12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 109 (PD13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 110 (PD14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 111 (PD15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 112 (PD16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 113 (PD17): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 128 (PE0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 129 (PE1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 130 (PE2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 131 (PE3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 132 (PE4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 133 (PE5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 134 (PE6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 135 (PE7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 136 (PE8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 137 (PE9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 138 (PE10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 139 (PE11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 140 (PE12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 141 (PE13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 142 (PE14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 143 (PE15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 160 (PF0): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF0 pin 161 (PF1): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF1 pin 162 (PF2): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF2 pin 163 (PF3): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF3 pin 164 (PF4): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF4 pin 165 (PF5): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF5 pin 166 (PF6): (MUX UNCLAIMED) 1c20800.pinctrl:166 pin 192 (PG0): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG0 pin 193 (PG1): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG1 pin 194 (PG2): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG2 pin 195 (PG3): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG3 pin 196 (PG4): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG4 pin 197 (PG5): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG5 pin 198 (PG6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 199 (PG7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 200 (PG8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 201 (PG9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 202 (PG10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 203 (PG11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 204 (PG12): (MUX UNCLAIMED) 1c20800.pinctrl:204 pin 205 (PG13): (MUX UNCLAIMED) (GPIO UNCLAIMED) In both cases, I used sudo armbian-add-overlay ili9341-spi1.dts, and my armbianEnv remained the same: Spoiler verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 rootdev=UUID=54388674-edbe-4032-83b8-1f048fe55a29 rootfstype=ext4 user_overlays=ili9341-spi1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted September 5 Author Share Posted September 5 I tried this DTS, to try to declare, reserve, or pin mux the chip select (I don't know what the added block does) Spoiler /* OrangePi Zero -> ILI9341 LCD connections SPI CLOCK = PA14 SPI DO (LCD MISO) = PA16 (OPIZ MISO) SPI DI (LCD MOSI) = PA15 (OPIZ MOSI) LCD DATA/CONTROL = PA18 LCD RESET = PA2 CHIP SELECT = PA13 VCC = 3.3V PIN GND = GND PIN */ /dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target = <&pio>; __overlay__{ spi1_cs0: spi1_cs0 { pins = "PA13"; function = "gpio_out"; output-high; }; display_pins: display_pins { pins = "PA18", "PA2"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; cs-gpios = <&pio 0 13 0>; /* PA13 chip select */ num-chipselects = <1>; display: display@0 { pinctrl-1 = <&spi1_cs0>; /* Mux the PI to make sure they are set in spi Mode */ reg = <0>; compatible = "adafruit,yx240qv29","ilitek,ili9341"; /*compatible = "ilitek,ili9341";*/ spi-max-frequency = <40000000>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&display_pins>; rotation = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; dc-gpios = <&pio 0 18 0>; /* PA18 Data control pin */ reset-gpios = <&pio 0 2 1>; /* PA2 reset pin*/ debug = <4>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; The TFT screen did not work (100% white), but at least I see more pins used in pinctrl (PA2, PA18) Spoiler roberto@orangepizerosudo cat /sys/kernel/debug/pinctrl/1c20800.pinctrl/pinmux-pinspins Pinmux settings per pin Format: pin (name): mux_owner gpio_owner hog? pin 0 (PA0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 1 (PA1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 2 (PA2): spi0.0 1c20800.pinctrl:2 function gpio_out group PA2 pin 3 (PA3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 4 (PA4): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA4 pin 5 (PA5): 1c28000.serial (GPIO UNCLAIMED) function uart0 group PA5 pin 6 (PA6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 7 (PA7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 8 (PA8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 9 (PA9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 10 (PA10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 11 (PA11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 12 (PA12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 13 (PA13): 1c69000.spi 1c20800.pinctrl:13 function spi1 group PA13 pin 14 (PA14): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA14 pin 15 (PA15): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA15 pin 16 (PA16): 1c69000.spi (GPIO UNCLAIMED) function spi1 group PA16 pin 17 (PA17): (MUX UNCLAIMED) 1c20800.pinctrl:17 pin 18 (PA18): spi0.0 1c20800.pinctrl:18 function gpio_out group PA18 pin 19 (PA19): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 20 (PA20): (MUX UNCLAIMED) 1c20800.pinctrl:20 pin 21 (PA21): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 64 (PC0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 65 (PC1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 66 (PC2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 67 (PC3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 68 (PC4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 69 (PC5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 70 (PC6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 71 (PC7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 72 (PC8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 73 (PC9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 74 (PC10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 75 (PC11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 76 (PC12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 77 (PC13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 78 (PC14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 79 (PC15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 80 (PC16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 96 (PD0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 97 (PD1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 98 (PD2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 99 (PD3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 100 (PD4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 101 (PD5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 102 (PD6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 103 (PD7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 104 (PD8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 105 (PD9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 106 (PD10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 107 (PD11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 108 (PD12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 109 (PD13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 110 (PD14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 111 (PD15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 112 (PD16): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 113 (PD17): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 128 (PE0): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 129 (PE1): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 130 (PE2): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 131 (PE3): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 132 (PE4): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 133 (PE5): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 134 (PE6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 135 (PE7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 136 (PE8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 137 (PE9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 138 (PE10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 139 (PE11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 140 (PE12): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 141 (PE13): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 142 (PE14): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 143 (PE15): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 160 (PF0): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF0 pin 161 (PF1): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF1 pin 162 (PF2): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF2 pin 163 (PF3): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF3 pin 164 (PF4): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF4 pin 165 (PF5): 1c0f000.mmc (GPIO UNCLAIMED) function mmc0 group PF5 pin 166 (PF6): (MUX UNCLAIMED) 1c20800.pinctrl:166 pin 192 (PG0): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG0 pin 193 (PG1): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG1 pin 194 (PG2): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG2 pin 195 (PG3): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG3 pin 196 (PG4): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG4 pin 197 (PG5): 1c10000.mmc (GPIO UNCLAIMED) function mmc1 group PG5 pin 198 (PG6): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 199 (PG7): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 200 (PG8): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 201 (PG9): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 202 (PG10): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 203 (PG11): (MUX UNCLAIMED) (GPIO UNCLAIMED) pin 204 (PG12): (MUX UNCLAIMED) 1c20800.pinctrl:204 pin 205 (PG13): (MUX UNCLAIMED) (GPIO UNCLAIMED) 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted Thursday at 04:32 PM Author Share Posted Thursday at 04:32 PM So, I temporarily quit the effort to make ili9341.ko work, and continue with fb_ili9341.ko (Note: try changing the reset HIGH/LOW polarity, as advised in https://forums.raspberrypi.com/viewtopic.php?t=358240&start=25 ) To make this work with the orangepi zero 3, the DTS needed would be changed in the pinout, and the compatible line: Spoiler /* OrangePi Zero 3 -> ILI9341 LCD connections SPI CLOCK = PH6 SPI DO (LCD MISO) = PH8 (OPIZ MISO) SPI DI (LCD MOSI) = PH7 (OPIZ MOSI) LCD DATA/CONTROL = PC7 * LCD RESET = PC14 * could be any GPIO pin I want CHIP SELECT = PH9 VCC = 3.3V PIN 17 GND = GND PIN 20 */ /dts-v1/; /plugin/; /{ compatible = "**************"; /*what is the H618*/ fragment@0 { target = <&pio>; __overlay__{ display_pins: display_pins { pins = "PC7", "PC14"; /* reset, DC pins, order does not matter*/ function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */ cs-gpios = <&pio 7 9 0>; /* PH9 chip select, H=7 */ num-chipselects = <1>; display: display@0 { /*compatible = "adafruit,yx240qv29","ilitek,ili9341";*/ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-1 = <&display_pins>; spi-max-frequency = <40000000>; rotate = <270>; /* rotate for ili9341, rotation for yx240qv29 */ bgr=<0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 2 14 1>; /* PC14 reset pin*/ dc-gpios = <&pio 2 7 0>; /* PC7 Data control pin */ debug = <3>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x28 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x28 0x1000011 0x1000029>; }; }; }; __overrides__ { rotate = <&display>,"rotate:0"; fps = <&display>,"fps:0"; debug = <&display>,"debug:0"; }; }; Now I need to try this at home 0 Quote Link to comment Share on other sites More sharing options...
